Old 24th December 2012, 19:05   #61
bulletboy76's Avatar
Thanked: 49 Times
Default Re: Converting Light Crank to Heavy Crank in Royal Enfield Standard Bullet 350 1996 M
What is the reason you want to change to a heavier crank? I think the heavier crank will also need a better crank-bearing.
I am not aware if anyone has done such conversion, but theoratically - this should be possible as Electra / C350 share the same crank case as STD UCE. This is with assuption that you will use the crank of STD uce and will not go for some after-market stuff (welding extra plates etc to increase the weight).
On -ves of heavier crank:
1. Initial pickup will be sluggish as compared to earlier version
2. There may be a slight drop in mileage
+ves:
1. The bullet will chug along happily at lower RPMs. 40 - 45 KMPH will be easily possible on 5th gear
2. Thump - while this is highly subjective - I feel that the STD uce's thump is slightly different than that of electra UCE. I do not have any data points on comparision and this is purely my perseption!
Cheers and happy thumping!
bulletboy76 is offline   Reply With Quote
Old 26th April 2013, 19:07   #62
Thanked: 49 Times
Has anyone tried to convert any UCE bulls to Heavy Crank? I am aware that the STD 350 UCE does come with a heavy crank, but has anyone thought of adding still more weight?
Old 8th October 2013, 00:38   #63
Leepower's Avatar
Thanked: 70 Times
Hi guys, and I restarting this whole heavy crank debate again. My simple query is how much was the actual weight of a 1960 to late 70s Bullet's crank. My mech claims it was 18 kgs. Is he correct???
Leepower is offline   Reply With Quote
Old 9th October 2013, 20:41   #64
Leepower's Avatar
Thanked: 70 Times
Hi guys, Is there any mech in Pune who can do this heavy crank conversion??? I have a friend who needs to make his 89 Bullet's crank heavier.
And my earlier query is still unanswered: What is how much was the actual weight of a 1960 to late 70s Bullet's crank. My mech claims it was 18 kgs. Is he correct???
Thanks in advance
Enfield Bullet - Standard 350 or 500? hsparida Motorbikes 56 25th April 2016 07:59
Reasonable charges or Royal loot? 1977 Enfield Standard 350 repairs DAART Motorbikes 10 16th June 2015 21:18
Royal Enfield Bullet - Standard 350 - production to be stopped? naveenroy Motorbikes 89 10th February 2011 17:57
Can a front disc brake be fitted on Bullet 350 standard model from enfield OEM parts? sidindica Motorbikes 27 26th August 2010 15:53
Tak Tak Tak Sound from my Enfield Bullet Standard 350 1996 Model navin_v8 Motorbikes 5 13th May 2010 10:45
