Old 5th November 2005, 09:40   #1
hellmet's Avatar
Thanked: 638 Times
Lightbulb Good Headlights
Its been talked about in the car forums,not in bikes....
All mobikers must have faced this problem...
from Tata Sumoz,Indicaz,and of course the lorries.
U r blinded and you slow down
The headlight beam just isn't enuff for night riding.
But it cud be improved...with better lights,mods.
I have halogen 35W fitted...but it still isn't enuff..
Anyone with experience in this segment ...
can you throw some light on this too....??
hellmet is offline   Reply With Quote
Old 5th November 2005, 09:45   #2
mclaren1885's Avatar
Thanked: 35 Times
Infractions: 0/1 (10)
well a friend of mine has used the crystal visons from philips in his pulsar,so i think it can be done..
Old 5th November 2005, 10:25   #3
hellmet's Avatar
Thanked: 638 Times
Well...all bikes use 35W
But Philips is nowhere under 45W.
Wudn't that cause burden on the battery then?
Does any one know about the extra coilings that
many talk about to increase Wattage(power)??
Old 9th November 2005, 02:11   #4
fieroid's Avatar
Thanked: 287 Times
my fiero uses a AC wiring (other fieros have DC) and a higher rating coil which supports only a 55/60w bulb....it will fuse a 35w the moment i turn on the light.....
infact this was from TVS, dont know if anyone makes kits outside!
fieroid is offline   Reply With Quote
Old 9th November 2005, 09:27   #5
jkdas's Avatar
Thanked: 1,436 Times
avenger and eliminator had 60/55W by default ; one of the best headlights in business
Old 10th November 2005, 10:40   #6
hellmet's Avatar
Thanked: 638 Times
Hey Thanks Dude,I'll find out at TVS soon.
Old 10th November 2005, 10:43   #7
jkdas's Avatar
make his bike one of the kind in india. and abt the kit too i think teh same. anyway enquire and post abt it here
Old 10th November 2005, 13:22   #8
veyron1's Avatar
Thanked: 38 Times
if i remember correctly, only the eliminator had 60/55 W bulb run on the battery; the avenger has a 35/35 W being run on the alternator...
as for the low light problem, i'm afraid just replacing the bulb with a higher wattage one might not solve the problem; you might have to rewire the electricals, and make your headlight run on the battery to get required results- but mind, that's a hefty job, including fitting a higher amp battery (at least 5 amp).
as for a low-cost solution, you'll have to make do with a 45W bulb, which will give a marginal increase in brightness.
speaking of the best lamps in the business, i've found four that are the best of the current crop; (the now defunct) eliminator, royal enfield bullet, pulsar, and zma.... i'm referring to stock bikes, of course....
veyron1 is offline   Reply With Quote
Old 10th November 2005, 15:12   #9
jkdas's Avatar
no you are wrong
I own an avenger and its NOT connected via battery.
Old 10th November 2005, 17:00   #10
veyron1's Avatar
Thanked: 38 Times
if you read my post carefully, JK, you shall see what i said;
Old 10th November 2005, 17:05   #11
jkdas's Avatar
sorry mate. i apologize
Old 10th November 2005, 19:44   #12
fieroid's Avatar
Thanked: 287 Times
I would not recommend a 55/60 on a victor as u might want to go for extra coil winding! however opt for a good 35/35 phillips halogen which will serve ur purpose much better.
Old 11th November 2005, 04:00   #13
motomaverick's Avatar
Thanked: 868 Times
yeah having a 35w halogen is also not enuff. infact in unicorn the prob is worse. very very weak headlamps
Old 19th December 2005, 00:42   #14
Awaiting Email Confirmation
lancer_mania's Avatar
can someone help me out.a friend of mine wants to change his bulb on his kinetic honda.can you suggest a good one that will be brighter.if possible a whitish bulb.
lancer_mania is offline   Reply With Quote
Old 20th December 2005, 13:22   #15
revtech's Avatar
Thanked: 35 Times
for a kinetic you dont have many options.you can either get a normall bulb for about 15 - 20 bucks or a halogen for about 45 - 60.the only thing is the reflectors in the kinetic , marvel and the older activas arent good enough to spread the light properly and hence you only get a spot instead of a wide spread beam.thats what i have heard.but when you get it opened up make sure you clean the reflector and the inner part of the cover well.i had done this some time back and put the normal bulb for 15 bucks and the light was really bright and lit up the road well.hope that helped.
Rev
revtech is offline   Reply With Quote
Baleno Headlights GS300 Modifications & Accessories 67 26th March 2018 10:12
poor headlights in Getz !! chandan Technical Stuff 11 5th October 2009 19:42
Turn your headlights off and only use the horn! Rtech Street Experiences 37 13th April 2006 16:04
Info on Baleno Headlights nipun_kr The Indian Car Scene 8 21st August 2005 14:35
