Old 7th July 2010, 18:22   #16
Leepower's Avatar
Thanked: 70 Times
Problem identified: Clutch plates had gone kaputt!!! I am replacing them with CI 500's clutch plates. The Bull 350's plates are a joke. Hope 500's plates last for a while!!!
By the way Sudarshan, do you have any clue about where I can get this engine compression gauge???
Leepower is offline   Reply With Quote
Old 7th July 2010, 19:13   #17
Thanked: 825 Times
Hi, engine compression gauge is a usefull tool, but unless you are a DIY( do it yourself ) type of guy it is not worth buiying, but if you still insist checkout following places
1) Bombay Tools
2) Pardawala ( opp to Bombay Tools )
Thease are the shops at Laxmi rd. Satranjiwala chowk ( near Bohri aalee or Sonya Maruti Chowk )
Also you need to have the Factory spec.s of correct compression range ( service limits ) for your Model.
Yours Sudarshan
P.S. I have one gauge ,& will show you how it works ( if you wish )
Sudarshan is offline   Reply With Quote
Old 7th July 2010, 19:25   #18
Leepower's Avatar
Thanked: 70 Times
I would love to Sudarshan if that's not too inconventient for you. But first let me get my Bull up and running!!!
Old 7th July 2010, 20:35   #19
anjan_c2007's Avatar
Thanked: 5,253 Times
(1) So was the clutch plate really faulty? If the clutch is gone, the engine moves to higher rpm's (judge from the engine sound as your Bullet does not have a RPM meter I am sure) but the speeds get lower. So say the engine makes sound as if it was running @ 50 kmph in normal health, but now with the clutch gone, the same sound level will propel the bike move @ 25-30 kmph.There is evidently a power loss whcih the driver feels.
(2) Whereas before doing a compression test and so on for the engine health and piston condition check the engine oil consumption first. With a bad engine oil consumption becomes progressively excessive. I had a jeep that consumed 1 litre of oil for every 100 kms run when the engine condition was bad.
Now this excess oil consumed due to a poor engine compression emits an excessive whitish grey smoke. So you can check on the smoke quality and the oil consumption with the dip stick.If there are abnormalities then go for the compression test and engine work.
About the pillion 'dharle tar chavte & sodle tar palte' I relish the sense of humour within. Please consider this too "pan kaam kari masha hi chavte ani manjar hi palte".
anjan_c2007 is offline   Reply With Quote
Old 8th July 2010, 19:05   #20
Leepower's Avatar
Thanked: 70 Times
Problem Solved. My Bull is back to behaving like my Bull ie dug-duging smoothly and climbing hills without any effort. Did a test run on Kondhwa-Katraj road and she passed it with flying colours!!!
Old 10th July 2010, 20:56   #21
So OK believe the clutch was gone and has been replaced?
Old 3rd August 2012, 09:58   #22
adrian's Avatar
Thanked: 602 Times
Default Re: Piston trouble - Enfield Bullet?
Yours Sudarshan
Hi, one doubt regarding the usage of the compression gauge. You have to kick 5-6 times with throttle at WOT and the ignition turned off. What about the fuel valve ? Should it be open or closed ?
regards adrian
adrian is offline   Reply With Quote
Old 3rd August 2012, 13:10   #23
ebonho's Avatar
Thanked: 3,182 Times
I don't think it makes a difference bro. Kick till the needle stops going higher.
ebonho is offline   (1) Thanks Reply With Quote
Old 3rd August 2012, 14:50   #24
deutscheafrikar's Avatar
Thanked: 324 Times
regards adrian
Yep Throttle wide open so that air can get in. Or else your reading will be false. Fuel tap won't make a difference. But you need to have the engine warmed up.
You need to note each of the readings.
Bring the kick start lever to compression and then give it a healthy kick
The first kick should be half of the final reading you will/have reach/ed
And each succesive kick should move the compression reading up by about half the previous number that the gauge increases by.
Before all this you also need to know healthy compression of your engine
deutscheafrikar is offline   (2) Thanks Reply With Quote
The story of another Green Bullet in my life - My Enfield Bullet 500 arjithin Motorbikes 35 20th February 2016 20:26
Royal Enfield UCE500 Engine gets a Forged 535cc Piston Kit from Hitchcock Motorcycles jkdas Motorbikes 0 11th April 2011 10:11
Bullet gearbox trouble nakedflame Technical Stuff 3 8th January 2008 10:06
How do piston rings work? jat Technical Stuff 10 5th November 2006 07:33
The Worlds Fastest Car Ever (Piston 0 - 60) Psycho The International Automotive Scene 9 31st July 2004 17:56
