Old 11th July 2010, 12:14   #31
aargee's Avatar
Thanked: 2,143 Times
@Dcustom - Good luck;
So how about the casing? Are you intending to use the same casing or planning to build a custom one?
Also, I've one more confusion, if you've the engine already in place, I hope you'll be stripping down the engine to reduce the bulkiness isn't it? Appreciate if you shed some light on this pls? Tks.
Old 13th July 2010, 12:46   #32
Thanked: 448 Times
gearbox case will be chopped smaller,as the place left empty by differential will serve no purpose.similar to what i have done with the Zen box. casing will be customized in and around lay shaft aswell.
Ac compressor may be removed saving something like 5kg weight,apart from that not too much weight reduction planned on the engine unit yet.However these things are last things to be done just before painting and stuff,so i ll live it quater mile at a Time.
dustom_99 is offline   Reply With Quote
Old 15th July 2010, 13:58   #33
theMAG's Avatar
Thanked: 1,574 Times
The best in-your-face project I've seen! Awesome stuff and all the very best.
Old 16th July 2010, 10:53   #34
Thanked: 40 Times
Hi
Though most of the stuff you had said went over my head i really hope that you nail the record. All the best mate.
drrajasaravanan is offline   Reply With Quote
Old 17th July 2010, 14:45   #35
SRK
SRK's Avatar
Thanked: 356 Times
Best of Luck for your Project!
Looking forward to see your name in the record books.
"The Fastest Indian on a diesel bike"
SRK is offline   Reply With Quote
Old 17th July 2010, 15:03   #36
Thanked: 448 Times
Thanks everyone,front forks have been ordered,final drive is on its way via USPS,gearbox has gone for machining,i am procuring some material and prepairing my garage for this mega build.
can any one tell me where can i find a alloy wheel which is 10" or more in width,any of the size(16",17",18") will do.
Old 7th September 2010, 11:31   #37
theexperthand's Avatar
Thanked: 1,242 Times
@dustom_99 any updates? what is the current status of your project? This is a very intresting project - dont let this thred run dry without updates.
theexperthand is offline   Reply With Quote
Old 7th September 2010, 15:22   #38
SPEEDY_RACER's Avatar
Thanked: 172 Times
dustom_99 any updates? on this...
SPEEDY_RACER is offline   Reply With Quote
Old 9th September 2010, 16:01   #39
Thanked: 9 Times
It appears Dustom has made his bike and burning the rubber big time
captrajesh is offline   Reply With Quote
Old 16th September 2010, 13:09   #40
Thanked: 448 Times
Hiya folks, well not yet burning the rubber,but good progress has been made,done up whole drive train,transmiting all of 280 NM to rear wheel without hiccups and jerks,actually i did components which would transmit about 400NM just to be on safer side,so over engineered every bit of drive set up.
in a couple of days may be next monday i would starts on frame fabrication,which has already been done up in soft copies.
i know its a huge delay,but its all due to MONEYPENNEY.its hard to find it for such projects here in india.by dec we shud have first ride of the FAT MAN.
oh yes and the Zen bike has also been done up fully now,re made the whole frame,it had rear suspension related issues,she will get he paint job soon, i will post some videos.
hey did any one find the alloy wheel, i asked you guys to help me out for,also a motorcycle dealer is askin for 27000/ for a 240/40 metzeller tyre,(bachoo motorcycle tyres ) in mumbai.it seems to be toooooooo damn expensive for me.let me know if some one can get me a wide rear tyre(ofcourse i wud pay for it)
Old 2nd November 2010, 17:39   #41
ferrariKSA's Avatar
Thanked: 26 Times
Hi Dustom_99
I can arrange for you a used Front or Rear Alloy for Maserati Quattroporte 20" for your project.
The tyre fittment will be 245/35 ZR20 for the front and 285/30 ZR20 for the Rear.
All the best
A.H
Farooq
ferrariKSA is offline   Reply With Quote
Old 3rd November 2010, 11:06   #42
Thanked: 448 Times
Hey thanks a lot,I would only require a rear alloy, that too only one for now.
The name "Maserati" spells trouble for my bank account! guess its going to be too expensive to egt even one 20incher.
Please Advice how much i would need to shell out if you are willing for a deal.
For now i have started the project with an 18incher 245,however it can be changed to a wider one.
Thanks again
Old 4th November 2010, 15:57   #43
Thanked: 9 Times
@ferrariksa, nice to see some help coming dustom's way.
@ dustom 99, you must post more often seeking help. After all, mother feeds only the crying baby.
Old 9th January 2011, 14:02   #44
Thanked: 448 Times
Default re: Project: Creating the world's fastest TurboDiesel Motorcycle! Road test video added
Gear ratios have been set as following-
1st gr-at 800 rmp (idle) = 11km/h
At 4000 rpm = 54km/h.
2nd gr - at 850 rpm =21km/h
At 4000 rmp = 99.7 km/h.
3rd gr - at 4000 rpm = 171 km/h
4th gr - at 4000 rpm = 224 km/h
5th gr = torque below critical value.
5th gr is currently redundant, it may be useful when we remap or use higher boost with remap.
On paper 5th gr wil propel the motorcycle to speed over 300kph ,but currently power isnt adequate to get above 240kph or so.
Acceleration figs (virtual sim)
0-100 kph = 5.2 secs
80-140 kph = 6.9 secs.
80-180 kph = 17.6 secs.
(Air drag at 0% headwind & rolling ressistance taken into account)
Losses due to squitting & suspention travel not considered , tyre-surface contact assumed to be infinite friction type.
Design of smallest possible swingarm is under way.
Old 11th January 2011, 00:18   #45
Tejas Ingle's Avatar
Thanked: 310 Times
Thought of the bike used in Batman comes to me on reading this. It seems it will be of similar dimensions.
All the best...
Have you thought about the design? Post some sketches that would give us an idea.
Tejas Ingle is offline   Reply With Quote
New Land Cruiser 70 series-turbodiesel V8[euro4] rahul_intlad The International Automotive Scene 17 15th July 2012 08:49
Creating India’s fastest GTR rghai6 Super-Cars & Imports in India 67 1st November 2010 14:33
Worlds fastest EV : Rather fastest Elec-Supercar ac 427 The International Automotive Scene 0 18th July 2008 17:08
