Old 11th January 2011, 15:06   #46
Thanked: 448 Times
Default re: Project: Creating the world's fastest TurboDiesel Motorcycle! Road test video added
Hehe! No it wont be as big as batman's ride. Batmans ride is just too awesome to be compared to mine.
This one will not be too long,atleast not as long as some of the bullet choppers.
Wheelbase will be around 75inch/1900mm. Weight around 290 to 320kg,torque around 300nm.
May be in future I will get a bigger turbo and a remap. then it will be close to 400nm.
dustom_99 is offline   Reply With Quote
Old 11th January 2011, 15:39   #47
Randhawa's Avatar
Thanked: 270 Times
Originally Posted by dustom_99 View Post
Thanks everyone,front forks have been ordered,final drive is on its way via USPS,gearbox has gone for machining,i am procuring some material and prepairing my garage for this mega build.
can any one tell me where can i find a alloy wheel which is 10" or more in width,any of the size(16",17",18") will do.
Why don't you get it machined from aluminium. Will that be strong enough for your bike?
Randhawa is offline   Reply With Quote
Old 11th January 2011, 16:37   #48
n_aditya's Avatar
Thanked: 2,779 Times
Gear ratios have been set as following-
1st gr-at 800 rmp (idle) = 11km/h
At 4000 rpm = 54km/h.
2nd gr - at 850 rpm =21km/h
At 4000 rmp = 99.7 km/h.
3rd gr - at 4000 rpm = 171 km/h
4th gr - at 4000 rpm = 224 km/h
Just imagining these speeds gives me goosebumps.
Wishing you success in your project and many years of safe and happy riding.
Old 11th January 2011, 17:47   #49
_raVan_'s Avatar
Thanked: 487 Times
All the best with your project dude. Do post some videos or pictures as to how you are progressing
_raVan_ is offline   Reply With Quote
Old 13th January 2011, 21:53   #50
Tejas Ingle's Avatar
Thanked: 310 Times
I have a question.
How do you manage to balance the bike? I mean, scooters are not balanced as they have more weight on one side. Similarly, a car engine wont be symmetrical, and will have balancing issues (I guess).
Tejas Ingle is offline   Reply With Quote
Old 15th January 2011, 13:32   #51
Thanked: 448 Times
Yes, car motors are not symtrcal, but even bigger problem is final drive and rear disc brake assy.
As they are mounted towards one side,and have considerable weight.
All this stuff makes the motorbike heavier on one side,giving it tendency to pull towards heavier side at higher speeds,and tendency to fall onto one side at slower speeds.
I counter this problem by mounting the motor and gearbox in an offset position to the central vertical plane of the motorcycle.
What I mean to say is the centre axes of motorcycle (if you join a straight line passing through centre vertical plane of front tyre and rear tyre) , does not pass through centre of gravity of the engine and gearbox unit.
This offset counters the weight on the other side.
Difficult part is calculating how much offset is needed,and is calculated using ' COG CALCULATION FOR NON UNIFORM BODIES'
This method yeilds close idea, but not exact results because material inside the engine block is not uniform,some places it is steel,some cast iron,and aluminium ,also some places are hollow.
Anyway
This is not a mathematics forum,so we leave that aside .
Offset value is generally quite small & of the order of 10 to 25mm,which makes offset very hard to spot.
If you get the maths and fabrication right,you can endup with a bike that you can ride sleeping with your hands in your pocket.;-)
Old 25th January 2011, 18:10   #52
Thanked: 9 Times
Good work Dustom99 Keep it going. All the best.
captrajesh is offline   Reply With Quote
Old 4th February 2011, 22:06   #53
Thanked: 448 Times
Current pics...
Rear suspension still to be done.
All mechanical systems are go!
Project: Creating the world's fastest TurboDiesel Motorcycle! Road test video added-dsc00932.jpg
Project: Creating the world's fastest TurboDiesel Motorcycle! Road test video added-dsc00934.jpg
Project: Creating the world's fastest TurboDiesel Motorcycle! Road test video added-dsc00939.jpg
dustom_99 is offline   (1) Thanks Reply With Quote
Old 4th February 2011, 22:16   #54
Alter_Ego's Avatar
Thanked: 98 Times
Its turning out to be one real mean machine.Love the rear looks.
Colour pics D
Alter_Ego is offline   Reply With Quote
Old 4th February 2011, 22:28   #55
Thanked: 448 Times
Default Re: Project: Creating the real beast! worlds fastest TurboDiesel Motorcycle!
Sorry no colour pics for now,i have knowinly put up low quality low light pics. Do not want to reveal all systems as I have applied for some patents. Thanks and stick by.
Old 4th February 2011, 22:58   #56
selfdrive's Avatar
Thanked: 2,495 Times
Default Re: Project: Creating the real beast! worlds fastest TurboDiesel Motorcycle! Pics on
Wow, hats off to you on such a fabulous job! How much time did you spend on designing the beast before actually implementing it? And did you have to do any rework at all?
selfdrive is offline   Reply With Quote
Old 5th February 2011, 06:39   #57
Sem80-88's Avatar
Thanked: 389 Times
Excellent project, single disc setup seems a bit weak. Are you planning to upgrade or you want to stick with the single disc. I could find a twin disc set up for you from the breakers yard if you want.
Sem80-88 is offline   Reply With Quote
Old 5th February 2011, 08:52   #58
Thanked: 448 Times
I would love to upgrade! Specially if you could find front end of some cruiser or touring bike-like rocket 3 or something.. Thanks
(Please pm me if you find one)
Old 7th February 2011, 12:41   #59
Thanked: 448 Times
Well to be truthfull designs for various subsystems started several years ago, but actual design started when I bought getz crdi, It was only then I had the actual dimentions of the engine and gearbox.
Last oct and nov cad was done and physical design started in dec10. Before that I had given gearbox and rear hub for machining.
Not too much rework till now apart from some missaligned brackets and retaping work, I guess my share of rework awaits me at sheet metal body work stage,as I am not too good at it.
Old 9th February 2011, 15:42   #60
fuhrer's Avatar
hey dustom, the other day i was telling a friend of mine about your project, that is when he told me about the movie the world's fastest indian, hope to see a book or movie based on you in the future with a similar title. hats off to you bro.
fuhrer is offline   Reply With Quote
New Land Cruiser 70 series-turbodiesel V8[euro4] rahul_intlad The International Automotive Scene 17 15th July 2012 08:49
Creating India’s fastest GTR rghai6 Super-Cars & Imports in India 67 1st November 2010 14:33
Worlds fastest EV : Rather fastest Elec-Supercar ac 427 The International Automotive Scene 0 18th July 2008 17:08
