Old 17th August 2010, 11:04   #31
4x4addict's Avatar
Thanked: 2,668 Times
@sinner:
I feel you can rule out the clutch plates as this is not a symptom of clutch plates. Spark plugs are cheap so change the plugs and wires first. If that doesn't help the most likely culprit in the CDI.
4x4addict is offline   Reply With Quote
Old 17th August 2010, 18:04   #32
sinner's Avatar
Thanked: 17 Times
Thanks 4X4..
2 Aargee : when i did the testing on open lid i had about 1/4 fuel in the tank.
I'll be checking the spark plug and stuff on thursday so will update you guys then. Hopefully this time with pictures (of the spark plug).
sinner is offline   Reply With Quote
Old 17th August 2010, 18:30   #33
aargee's Avatar
Thanked: 2,142 Times
If possible, do check the ignition coil and CDI test in addition. Pls do not dismiss Gordon's point on BS26 carbs, it is also very much valid & worth giving a try.
Some more point, though weird, worth giving a try. Check if the existing main jets on your carbs are stock & is not broken or does not have any hairline crack. What I intend to say here is, MAY BE, B.A.S.S would've mistakenly swapped your jets with some other Avenger.
Also try to check & update on the pickup & top speed factor. When checking the top speed, check the engine heat in addition.
Old 19th August 2010, 11:01   #34
glomus123's Avatar
Thanked: 47 Times
Since aargee and others have pointed out the vacuum issue / petrol supply, could it be any block in the fuel tap and associated supply line? Had a very bad fuel tap issue in my bike years back, the tap was was only rotating outside, not really opening the hole, causing a very low petrol flow, which works for sometime and later make the bike stop.
My two cents.
glomus123 is offline   Reply With Quote
Old 19th August 2010, 16:37   #35
Gordon's Avatar
Thanked: 197 Times
How do you check a vaccum leak? I've read you've to spray WD40 on suspected areas. But what are the suspected areas?
Gordon is offline   Reply With Quote
Old 20th August 2010, 11:43   #36
sinner's Avatar
Thanked: 17 Times
I finally (most probably) have a cure to the never ending problem that Iíve been facing with my bike. Yesterday I took my bike to the one guy Iíve been wanting to for a very long time. Mr Tony in Malad.
We did a little brain storming to figure out what the problem could be, we checked :
- Spark plug wear. It was little on the black side, guess it was running rich, right ?
- Kachra in the Carb and fuel tap. It had very little kachra, not enough to cause problems for 4 months
- Fuel LID for the air passage. Certified to be sufficient
On closely inspecting and carefully cleaning the Carb we found that the Diaphragm that sits on top of the Carb had a small hole caused by usual wear and tear.
( Iíll try to post the pic, I kept the broken piece as a souvenir)
Thatís it.
We replaced the diaphragm and the bike is running fine 30 Kms on the odo and most of It in the heavy Mumbai traffic.
I know I should have taken the bike to him at the first place. Iíll now refer to Mr Tony as my Bike Doctor.
Happy Riding for me now.
Old 20th August 2010, 12:02   #37
aargee's Avatar
Good to hear the problem being resolved @Sinner; most importantly Thanks for sharing the incident with us. I'm glad you're going to enjoy your ride.
Avenger 180CC - My Bike, My Life & The Revenge of the !Avengerous Savvy Mechanics traveloholic Motorbikes 13 5th July 2018 22:37
Pulsar 180cc Acceleration Problem Wayne D Motorbikes 25 17th December 2014 09:58
Acceleration issue in my Bajaj Pulsar 180 UG3 sagarpadaki Motorbikes 31 19th March 2012 14:17
Headlight Upgrade for Avenger 180cc manishalive Motorbikes 2 13th October 2010 18:20
Exhaust Modification for my Avenger 180cc manishalive Motorbikes 0 27th September 2010 20:31
