Old 16th August 2010, 09:49   #1
ricky_1605's Avatar
Thanked: 47 Times
Default Urgent Thunderbird help needed!!!
Hey guys, I gave my bike for servicing in Vadodara on Saturday morning. As i am new to this city so i asked about the mechanic from a guy who lives in my society. He said " His guy is the best mechanic in Vadodara". I wanted to get the bike serviced in front of my eyes but it had a lot of work:
1. General Servicing
2. Decompress was not working
3. Headlight bulb change (only high beam was working)
4. Tail light changed to HD likes
5. Speedometer was not working
6. Removal of rust from engine and leg guard and polishing
So i had to leave it with him for the day.
He told me i will get the bike on sunday at 2.00 p.m. So i reached his shop at 1.30 p.m. and the bike was ready except for the rust removal and polishing which took another 1.5 - 2 hrs.
Although 3-4 things are still left to be done like:
1. Silencer change to Indori
2. New Battery
3. New Battery cover panel
4. New Toolbox chrome panel
In the morning i saw some engine oil leaking so i cleaned it up and came to office. After reaching office again i saw some engine oil and that is getting me worried help.
ricky_1605 is offline   Reply With Quote
Old 16th August 2010, 09:54   #2
bblost's Avatar
Thanked: 6,980 Times
There are two bolts under the engine. Check if either one of them is loose.
Also check if the thread is seated correctly.
Also if this is the older thunderbird as in non-tbts, check if the leakage is happening from under the clutch cover.
Old 16th August 2010, 11:07   #3
ricky_1605's Avatar
Thanked: 47 Times
The oil is leaking neither from the clutch nor from under the engine. Its leaking from the timing cover. It was not leaking before the servicing.
Old 16th August 2010, 11:23   #4
Thanked: 23 Times
Get the Packet Seal changed.
That will stop the leakage.
its green in color, placed ahead of the tappet cover as shown in the snap.
Jaxy is offline   Reply With Quote
Old 16th August 2010, 12:27   #5
ricky_1605's Avatar
Thanked: 47 Times
The oil is leaking from the spot marked in white in the image.
Old 16th August 2010, 12:38   #6
bblost's Avatar
You need to go back to the mechanic for this.
The cover needs to be opened and if I remember correctly there is a rubber tube kind of gasket there.
Its needs to be checked.
Old 16th August 2010, 12:48   #7
schitre05's Avatar
Thanked: 82 Times
yes, by the picture it seems the gasket is the culprit, may be it was not fitted properly in the first place. Ask the mechanic to open the cover and change the gasket.
hope this solves the issue
cheers!!
schitre05 is offline   Reply With Quote
Old 16th August 2010, 13:20   #8
ricky_1605's Avatar
Thanked: 47 Times
Thanks bblost and schitre. I'll go to the garage in the evening, will update soon.
Can you guys help me with the battery and silencer?
Old 16th August 2010, 13:29   #9
bblost's Avatar
Silencer. Stick to original.
Battery get an Exide or Amco. You can also buy an exide online.
http://www.exidereachout.com/OA_HTML...DspRte.jsp?a=b
But I have not used this service.
Do not buy Amaron bike battery. It is very very bad.
Old 16th August 2010, 15:23   #10
aargee's Avatar
Thanked: 2,143 Times
Just like to shed what I heard on why Amaron is bad; it may or may not be true.
Amaron batteries are actually very good ones, however, the bad part is that they need precise voltage to be charged, IIRC 14V. Most of our Indian motorcycles do not give a steady 14V as input; may be 13.9, sometimes more than 14V. There's nothing wrong when it goes below 14V, it takes more time to charge which it gets during regular rides. However when there's an excess of 14V as input, it is then, the battery begins to start giving problems.
This is what one of the experienced mech & a battery dealer told me.
Old 16th August 2010, 16:36   #11
ricky_1605's Avatar
Thanked: 47 Times
Thanks bblost. I am thinking of going for Exide only. Any suggestions about general or maintenance free?
I am going to the mechanic in evening will update soon.
Last edited by bblost : 17th August 2010 at 09:08. Reason: back 2 back post. Please use edit post if posting within 20 mins. Thanks.
Old 16th August 2010, 18:38   #12
aargee's Avatar
From what I've been told, go for the general one & do not settle in for the maintainence free. Even the car batteries that they say that are maintainence free require the water level to be checked occasionally.
Old 17th August 2010, 08:52   #13
ricky_1605's Avatar
Thanked: 47 Times
I went to the mechanic yesterday evening. It was the tappet that was leaking because i got the decompression wire removed so there was a minor leak.
I just reached office and noticed that again . It seems i have to go again today.
Thanks aargee, I will go for general one only.
Old 18th August 2010, 08:58   #14
ricky_1605's Avatar
Thanked: 47 Times
Guys, got the tappet cover replaced and now the leakage has stopped. But now i don't have decompress because the tappet cover doesn't have the opening for decompression wire.
Old 18th August 2010, 09:41   #15
aargee's Avatar
@Ricky, BBlost & other RE gurus - I know what's the tappet & what's to be done to for tappet noise, I'm not aware of this decompress. what's this decompress & wire stuff? Could you throw some light on this pls?
Urgent help needed. please help-Santro Xing not starting iron.head Technical Stuff 3 12th May 2012 08:27
Thunderbird Production Year - help needed Amit_D Motorbikes 7 23rd May 2007 14:24
Help Help Urgent Help!!! abhibh In-Car Entertainment 12 11th April 2006 12:15
Urgent Help needed for choosing H.U and Basstube! Puffdamgcdragon In-Car Entertainment 7 11th October 2005 13:09
Fast decision your help needed urgent Montoya Sedans 72 17th May 2005 01:36
