Old 23rd August 2010, 01:35   #1
amtak's Avatar
Thanked: 382 Times
Default Button start and Horn problem
Hi all,
My 2008 HH Hunk is off late giving me trouble. Sometimes, either the horn or the Electric start is not functioning properly and I have to kick start the bike.
I have already changed the battery and still the problem exists. It is important to know that my headlamp is directly connected to the battery. Is this causing the above mentioned issues?
PS: I am not using the bike much but only for weekend rides.
Please assist.
Amtak
amtak is offline   Reply With Quote
Old 23rd August 2010, 08:37   #2
Sankar's Avatar
Thanked: 4,654 Times
When you say horn and electric start is not working, is it because of a partially drained battery? Does the indicators work? Does the horn give out any feeble sound? Does the horn work after some riding?
Hunk does not come with a battey powered headlamp from the factory, so if you've rewired the headlight to be powered by the battery, the battery would get drained as the stock charging system won't be able to keep up especially if you ride with headlights on. Using the bike only on weekends will not keep the battery charged.
Old 23rd August 2010, 11:07   #3
Randhawa's Avatar
Thanked: 270 Times
I dont know much about your bike but is the headlight on your bike AC or DC?
Randhawa is offline   Reply With Quote
Old 23rd August 2010, 12:20   #4
amtak's Avatar
Thanked: 382 Times
My bike initially came with AC wiring. I have rewired the bulb to run on DC as I had a lot of highway running where I needed stable lighting.
Secondly, the indicators work flawlessly where as only the horn and the button start die after some riding. If the vehicle is stopped, I need to kick start it and the horn works at its on whimps and fancies.
Do you think it would be a good idea to remove the DC work model from the bike and bring it back to stock? The headlamp too is not changed.
What to do if remote key fob fails and vehicle is equipped with Start-Stop button? arjab Technical Stuff 33 3rd February 2018 22:39
Push Button Start / Ignition jesal Modifications & Accessories 114 28th July 2013 12:18
Niken Gear Knob With engine start button? swarnava.m Modifications & Accessories 3 25th May 2012 15:07
Swift VDi Horn problem samigo Technical Stuff 6 18th October 2010 16:46
Cold start vs warm start, is there a difference? Shan2nu Technical Stuff 6 18th May 2010 18:32
