Old 13th October 2010, 16:11   #1
manishalive's Avatar
Thanked: 734 Times
Default Headlight Upgrade for Avenger 180cc
Guys,
My Avenger 180cc 4 years Old is running on stock setup (bulb and Reflector).
Now my reflector is corroded. I am due for a change. Can some one sujjest me a Good beam (Glass + reflector) to go into my bike also need suggestion on which bulbs to go for to have better output. I got many from the internet, not sure which one is the best of the lot (cost and efficieny wise)
Philips crystal vision bulbs
Philips Vision Plus H4 Bulb (also referred to as +50 bulb)
Philips 55/60 Xtreme Power H4
Osram Nightbreaker
Philips Xtreme 60/55W
Is there any other one good product available. I dont want to fiddle with the bikes wiring and therefore looking for one 2 one replacemet.
Another line of thought is Making the Light DC as opposed to current operation on AC. What is all required to be done for that.
I know that the Eliminator and the Current 220 Avenger both have DC Headlight, can I swap the rectifier off them?
Also what wiring change is required to run on a DC setup and since will be using the same wattage thicker wire will not be required. I think some were near the battery there will be a point / connector where I will be able to switch over from Ac to DC.
Mods: Please merge if there is an existing thread to it.
Old 13th October 2010, 16:56   #2
sagarpadaki's Avatar
Thanked: 1,337 Times
Avenger has got one of the best head lamps around.If the new avengers reflector fits your 180 avy then go for it.Otherwise stick to the stock reflector.
For bulbs i suggest you go for philips Xtreme power 55/60 watts.Its very good.
You can change the bike to DC by fiddling with the stator plate poles.I suggest you stay away from it since it wont make much of a difference.
sagarpadaki is online now   Reply With Quote
Old 13th October 2010, 18:20   #3
Thanked: 734 Times
Thanks for the reply, is there a difference between the old and the new one?. The size is the same so it should fit.
Also how to adjust the headlight beam, from the two screws given on the cover.
Avenger 180CC - My Bike, My Life & The Revenge of the !Avengerous Savvy Mechanics traveloholic Motorbikes 13 5th July 2018 22:37
Exhaust Modification for my Avenger 180cc manishalive Motorbikes 0 27th September 2010 20:31
Bajaj Avenger 180cc: Unresolving issue with acceleration (Not a carburetor problem) Mansha Motorbikes 36 20th August 2010 12:02
Pulsar 180cc DTSI Cosmetic Mods in Banagalore prince_pervez Technical Stuff 2 10th October 2007 21:28
Suzuki planning a 150/180cc Bike?? malteshashrit Motorbikes 2 21st March 2007 00:07
