Old 23rd August 2011, 01:53   #76
jocreative's Avatar
Default Re: Royal Enfield Bobber Home Project - Advice Needed
Hello Thread! A lot has happened since March 2011 .
I have moved to Dubai and was busy settling down, hence the lack of updates.
Well, since I was out of town, my mod-mechanic guy is kinda on slack-mode but I made sure most of the work was done before I left. I will be visiting again later this month to see how its going, or else will take it home, and then bring it to Dubai after I get a motorcycle license here, and continue the paint work here.
@NDMS Pranav: Sorry for the late reply. Here is a small illustration that could help explain the process.
jocreative is offline   Reply With Quote
Old 27th August 2011, 20:50   #77
jocreative's Avatar
Updated pics of my Springer Bobber Royal Enfield Machismo.
Left to do -
Engine Clean, wiring and startup.
Fixing Head, tail and turn signal lights.
Chrome engine.
Paint body.
jocreative is offline   (1) Thanks Reply With Quote
Old 29th August 2011, 11:52   #78
Rennjit's Avatar
Thanked: 77 Times
@ jocreative, credits to Springer front for the distinct looks.
Imo, the down tube may be bought back to stock stance or a wide mount plates be used & also a different exhaust pipe to go with new looks.
Rennjit is offline   Reply With Quote
Old 29th August 2011, 12:52   #79
jocreative's Avatar
Thanks Rennjit. I love how the springer gives it a unique look.
Silly question: What do you mean by down tube?
Regarding the exhaust, I wanted to have double exhaust with a straight tube design but this is what the modders ended up with . I guess I will have to wait and see how it sounds.
Old 29th August 2011, 17:46   #80
Rennjit's Avatar
Thanked: 77 Times
Default Re: Bobber Home Project
@ jocreative: down tube is item you marked #2 in post #76 pic. Imo a Uce exhaust pipe (not silencer) may look good than stock long bend pipe here.
Old 30th August 2011, 10:07   #81
jocreative's Avatar
Ah. I have seen those exhausts on other custom bullets. Not a big fan of those.
The plates cannot get any wider, but maybe you meant a different shape so that it doesn't stick out or give the overall bike a good shape. It looks fine to me. I just hope all the custom parts are sturdily fit and can handle some rough wind.
Old 31st August 2011, 12:06   #82
ac 427's Avatar
Thanked: 114 Times
hey jocreative,
Awesome project.
Love the front shocks - looks awesome. Big Thumbs up for it.
But your rear mudguard needs to be much much shorter.
Also for the seat i would recommend a old school seat (just the seat and springs visible - no foam)
The exhaust too if you can get it upswept will look awesome.
cheers,
ac
ac 427 is offline   Reply With Quote
Old 2nd May 2012, 17:50   #83
cogentr's Avatar
Awesome, mouth watering!! Apologies for waking this thread up but what is the status now, how far has it progressed?
Fully done up would be quite a sight.
cogentr is offline   Reply With Quote
Old 2nd May 2012, 18:03   #84
jocreative's Avatar
Hey Congentr, Sadly the project hasn't moved much since March last year.
I had to move to Dubai, and no body was there to monitor the people working on this so they had a great time slacking!
The current progress is that they are getting the wiring and other stuff done. I am just doing a basic paint job and trying to get it in running condition for now. I hope there is no damage on the tires for being idle for so long.
I would love to bring it to Dubai where I could do further mods and a better paint job.
Old 30th August 2012, 21:57   #85
Thanked: 57 Times
Originally Posted by jocreative View Post
Both of these will then be modded to increase the spokes to 72.
Where did youget this done? Looks good
Also check the front tyre i think its fit incorectly
davids4x4mm550 is online now   Reply With Quote
Old 31st August 2012, 11:22   #86
jocreative's Avatar
Front tire looks fine. What's wrong? They did reduce the mudguards size a bit more.
The spokes were done by a local spoke expert in Trivandrum. He has modified his bullet to have 80+ spokes too. Looks awesome. Costs around Rs 2-3000 if you want to get it done quickly and keep him motivated.
Old 1st September 2012, 00:17   #87
Thanked: 57 Times
Looks awesome.
The thread direction should be the other way me thinks . Just get the arrow marked on the tyre checked. i Might be wrong
Your right it looks killer and will add more strength to the rim.
Old 3rd September 2012, 14:15   #88
jeepster's Avatar
Thanked: 983 Times
David the tyre is fitted correctly!
The front tyre always have reverse tread.
So if you are using rear tyre on the front , you should fit it in reverse direction.
BTW jocreative you are doing a fantastic job .
rgds,
Nikhil
jeepster is offline   Reply With Quote
Old 3rd September 2012, 14:18   #89
jocreative's Avatar
Thanks Nikhil.
Waiting on the wiring and the final stuff to be done. Hopefully in the next few months.
Old 3rd September 2012, 19:50   #90
Thanked: 57 Times
rgds,
Nikhil
Wow this is news i never knew. i have allways fit tyres on according to the arrow mark.
Wont the tyres get eaten into faster?
Royal Enfield Bobber Project krcustoms Motorbikes 93 13th April 2017 14:15
Barebone 500 - Royal Enfield Bobber Gordon Motorbikes 43 26th June 2012 14:57
