Old 5th January 2011, 14:31   #16
voodoochild's Avatar
Thanked: 175 Times
Default Re: Help Required on Yezdi Deluxe
Srini,
The cause of your problem is glaringly obvious. Its the local bore-piston kit!!
The factory bores and pistons were matched by codes A to D based on thermal expansion characteristics, A being the best quality. Now if you're using local stuff, its obvious these haven't been matched the same way. Tolerances are certainly maintained, but no one can vouch for the quality of the metallurgy.
I would say, before trying anything on the bore (lapping, honing etc), try some home-grown remedies first, Burt Munro ishtyle! Try boiling your piston. It might settle the seizing issue temporarily. It seems to have worked with a friend's bike,and doesnt harm the bike in any way. Inspect the rings for scoring marks, and replace if necessary. If this doesnt work, THEN try the lapping.
As RT13 has already said, one-thou would need to be done extremely precisely. One effect of increasing your bore-piston clearance would be knocking/ticking sounds when engine is cold-started. This sound should disappear when engine warms up and piston has expanded. Reduced performance when cold, and drop in fuel efficiency are also to be expected.
Last option:Just look for a good second-hand bore-piston kit, or atleast a good Mahle piston (preferably not D quality).
Keep us updated.
Rahul
PS: What was the needle position on your Pacco during the seizures?
voodoochild is offline   Reply With Quote
help!! 84' yezdi roadking manual required. howler Motorbikes 10 30th January 2017 12:16
Force Motors launches Trax Cruiser Deluxe and Toofan Deluxe Aditya Commercial Vehicles 2 23rd October 2015 14:37
Hero HF Deluxe and HF Deluxe ECO launched Aditya Motorbikes 8 1st June 2015 16:59
Yezdi 175 Deluxe (CDI) Owner's manual available alok_balsekar Motorbikes 2 31st March 2013 12:31
Registeration help Required (PASSING) in for BRAND NEW YEZDI Bombay shivshanker Indian Car Dealerships 3 23rd July 2009 18:36
