Old 19th April 2011, 16:28   #16
TaurusAl's Avatar
Thanked: 329 Times
Default Re: Query Regarding Yamaha Power Box
RTZ has it fitted at the bottom of the fuel tank. Guess its best when the bikes have it company fitted.
Do 4 strokes also have intake resonators ?
TaurusAl is offline   (1) Thanks Reply With Quote
Old 19th April 2011, 21:51   #17
alok_balsekar's Avatar
Thanked: 34 Times
Originally Posted by Suyog_007 View Post
hey Guys Can Any One Tell Me Whats The Use Of Power BoxNote From Moderators - Please follow the default formatting for posting. (No typing entire posts in bold.. (thats for mods only))
Hi there,
In carburetted engines, when the throttle is opened suddenly the, air-flow in the carburettor increases significantly but the corresponding fuel mixture is weak initially. There is a lag in the bikes performance.
In some bikes, this is dealt with an accelerated fuel pump (as far as I can recollect what it is called) for eg the CBZ Keihin carb which pumps in excess fuel in the venturi when the airflow exceeds a specific limit.
One method of dealing with the issue is to get a resonator. It is simply a box (dimensions and shape are precisely calculated) which stores the air-fuel mix during normal running. When the accelerator is rammed open, the resonator feeds the cylinder ensuring that the lean mix from the carb is some what compensated.
This is a design feature and if the rx100 did not come with a resonator and the 135 did then it is due to some reasons only the designers would know.
Hope I have the correct explanation here
alok_balsekar is offline   (1) Thanks Reply With Quote
Spider Diesel Tuning Box VS. Pete's Tuning Box - Spider Box feedback on pg 2 Endeavour333 Modifications & Accessories 130 11th September 2017 01:24
suggestions regarding making of subwoofer box beanstalk_230 In-Car Entertainment 123 15th April 2011 23:21
My experience of buying a PSI (Petes) Power Box directly from the UK! PearlYamaha Modifications & Accessories 28 2nd September 2010 22:26
needed help regarding petes digital tuning box autozoniac Modifications & Accessories 4 28th February 2010 23:15
Power difference with Pete's box for Sumo/qualis apachelongbow Technical Stuff 7 12th May 2006 20:28
