Old 4th January 2006, 03:58   #1
Suyog_007's Avatar
Arrow Query Regarding Yamaha Power Box
hey Guys Can Any One Tell Me Whats The Use Of Power Box In Yamaha M Useing A Yamaha Rx100 N It Dosent Have A Power Box On It One Of My Friend Suggested Me To Fit A Power Box On It Will Fitting A Power Box Increase The Performance Of My Bike N The Fule Consumption Also Pls Suggest The Need Full
thanks...
Note From Moderators - Please follow the default formatting for posting. (No typing entire posts in bold.. (thats for mods only))
Suyog_007 is offline   Reply With Quote
Old 4th January 2006, 04:22   #2
nitrous's Avatar
Thanked: 285 Times
Why're u posting this in bold???
I dont know what a powerbox is.
Old 4th January 2006, 23:24   #3
Suyog_007's Avatar
Its the pipe which is present in between the carb n the engine
Old 4th January 2006, 23:47   #4
Mpower's Avatar
Thanked: 1,687 Times
Its an intake resonator. In teh KB it was called Delta powerbox or something. Shogun also has it.
Mpower is offline   (1) Thanks Reply With Quote
Old 5th January 2006, 00:00   #5
Suyog_007's Avatar
can u pls explain its work cose m confused what do u suggest shall i fit one on my RX100
Old 5th January 2006, 00:01   #6
Suyog_007's Avatar
how will it improve the performance of my bike
Old 5th January 2006, 04:54   #7
Mpower's Avatar
I think the RX-135/G/Z had a powerbox from the factory. You can try that on your bike. The box itself sits below the fuel tank. It's supposed to improve teh mid range throttle response.
Old 6th January 2006, 02:33   #8
Suyog_007's Avatar
ok its just to improve the throttel response will it increase the power of my bike or not
Old 6th January 2006, 05:10   #9
Hey! Suyog
The power box you are referring to is nothing but the YEIS system.
Y = Yamaha (Obviously)
E = Energy
I = Induction
S = System
The name that I go about referring to it is a boost bottle (picked the term up from a friend). Its a small bottle which has to be mounted above the cylinder. I am not quite sure of the technical details for the reason for this set up. But from what I was able to grasp this is a much simpler solution to the problem that the EXUP system tries to negate on the high end YAM bikes.
Claims to this YEIS system is 10-15% savings on fuel consumption and the engine responds better even at low RPM. I do not believe that it boosts your power, but it does make your engine seem more "Alive"
TheCockroach is offline   (1) Thanks Reply With Quote
Old 6th January 2006, 05:51   #10
Suyog_007's Avatar
Hey roach thankyou very much ill definately get one for my bike
Old 6th January 2006, 06:36   #11
Your Welcome Mate!
But do bear in mind the volume of the bottle and the positioning of the bottle is important. I am not sure which bottle can be used for the rx100 but when you do install it you have to make sure that it is placed above the cylinder.
Physics man Don't ask!
Old 6th January 2006, 12:47   #12
cbr1000f's Avatar
Originally Posted by TheCockroach
Your Welcome Mate!
hi suyog this is tavish here.. remember
well actually what is does is ... the fuel and air mixture travel from the manifold to the reed block/piston in pulses.
now a little before entering the cylinder the pulses negate ie change direction and travel the other way.
the boost bottle stores these pulses and doubles the charge!
it isnt really required on the newer carbureatted bikes.
you could try one on your rx if its stock.would help.
mine is lying around here incase you interested.
cbr1000f is offline   (1) Thanks Reply With Quote
Old 7th January 2006, 02:21   #13
Suyog_007's Avatar
hey guys i just got one from my friend its of RX135 n i have placed it above the head below the fuel tank. well my bike is not a stock one as i use it for dirt raceing so i have shaved the block n the compression is reduced so it has more power now n have even changed the air filter so this boost bottle will make some difference i hope
[SIZE=2][/SIZE]
[SIZE=2][/SIZE]
[SIZE=2]THANKYOU GUYS[/SIZE]
[SIZE=2]i do apperetiate that[/SIZE]
Old 14th April 2011, 14:26   #14
Thanked: 31 Times
Default Re: Query Regarding Yamaha Power Box
Sorry to bump up this old thread. Could not find any comments on ill effects of installing power box on RX100.
I was thinking to install this Power Box on my RX100, but a mechanic says that it will cause piston rings to wear out more quickly since RX100 does not have helper rings.
Can someone please shed some light on it?
Thanks.
vaasu is offline   Reply With Quote
Old 14th April 2011, 21:28   #15
Thanked: 47 Times
I have used the induction resonator in my RX100 for more than 60000km. It does improve the mid range torque and marginally the fuel consumption. No bad effects.
Suresh
Suresh Stephen is offline   (1) Thanks Reply With Quote
Spider Diesel Tuning Box VS. Pete's Tuning Box - Spider Box feedback on pg 2 Endeavour333 Modifications & Accessories 130 11th September 2017 01:24
suggestions regarding making of subwoofer box beanstalk_230 In-Car Entertainment 123 15th April 2011 23:21
My experience of buying a PSI (Petes) Power Box directly from the UK! PearlYamaha Modifications & Accessories 28 2nd September 2010 22:26
needed help regarding petes digital tuning box autozoniac Modifications & Accessories 4 28th February 2010 23:15
Power difference with Pete's box for Sumo/qualis apachelongbow Technical Stuff 7 12th May 2006 20:28
