Old 13th February 2010, 11:55   #136
Thanked: 48 Times
Originally Posted by JayPrashanth View Post
Naveen,
Usually, your air screw should be turned out 2.5-3 full turns anti clockwise from a fully closed position. This is the ideal setting. If you want to richen it, you can turn it anticlockwise for one or two more turns maximum. Experiment within this boundary till you cure the popping. If you richen it further than that, you risk fouling your plug.
Cheers,
Jay
Dear Jay,
If you turn the pilot air screw anticlockwise, I thought the mixture will become leaner not richer. Also the ideal setting is specific to each machine state of tune which includes the spark plug gaps, cb gaps advance tappet clearances Jet sizes, carburettor float level etc. Normally following is the procedure for tuning the carburettor.
!. set the CB gaps, plug gaps tappet etc to company spec
2. Start the engine and warm up
3. Close the pilot air screw completely( you need to increase the idling to sustain the engine)
4. start opening the air screw CCW slowly till you can see the engine rpm increasing . that is the optimum seting.
5. Reduce the idling
Trust this helps
Suresh
Suresh Stephen is offline   Reply With Quote
Old 13th February 2010, 15:40   #137
Thanked: 1,573 Times
Originally Posted by Suresh Stephen View Post
Dear Jay,
Trust this helps
Suresh
Suresh,
Anti-clockwise = Counter clockwise = rich.
Your manual mentions ccw which is the same as acw.
Cheers,
Jay
JayPrashanth is offline   Reply With Quote
Old 13th February 2010, 23:21   #138
Thanked: 48 Times
Suresh,
Cheers,
Jay
Dear Jay,
Iam aware that acw and ccw are the same. When you turn the pilot air screw CCW, You are taking the screw outwards (unscrewing). When the pilot air screw is unscrewed, it bleeds more air into the circuit and thereby makes the mixture leaner. Iam sure that you know that this is the finer control of the Stochiometric (A/F) ratio of the engine
Suresh
Old 14th February 2010, 09:08   #139
Thanked: 16 Times
Dear Jay,
Suresh
@Suresh - On the BS29, the so called pilot air screw aka F/A adjustment screw meters fuel and not air. Turning the screw CCW meters more fuel through and vice-versa. Yes, on some carbs the F/A adj screw does meter air like you mention above, in which case what you say holds true.
On the same topic, does anybody know whether the F/A screw on the VM28 meters fuel or is it air?
Beast_of_Burden is offline   Reply With Quote
Old 14th February 2010, 22:09   #140
Thanked: 48 Times
[quote=Beast_of_Burden;1731500]@Suresh - On the BS29, the so called pilot air screw aka F/A adjustment screw meters fuel and not air. Turning the screw CCW meters more fuel through and vice-versa. Yes, on some carbs the F/A adj screw does meter air like you mention above, in which case what you say holds true.
Thanks,
I did not know that sorry for the confusion
Suresh
Old 17th February 2010, 15:10   #141
naveenroy's Avatar
Thanked: 782 Times
......... When the pilot air screw is unscrewed, it bleeds more air into the circuit and thereby makes the mixture leaner. Iam sure that you know that this is the finer control of the Stochiometric (A/F) ratio of the engine
Suresh
Originally Posted by Beast_of_Burden View Post
@Suresh - On the BS29, the so called pilot air screw aka F/A adjustment screw meters fuel and not air.....
But mine is the BS26 - is there a difference in the A/F mixture screw on this one and the BS29?
naveenroy is offline   Reply With Quote
Old 17th February 2010, 18:45   #142
No difference.
Cheers,
Jay
Old 24th February 2010, 15:07   #143
Thanked: 120 Times
Infractions: 0/1 (5)
Friends,
Anybody has the pictures of various types of RE silencers?
Another question:
Is it possible to fit the New classic 500 silencer into TBTS?
Thanks,
agbenny is offline   Reply With Quote
Old 24th February 2010, 15:27   #144
blackfire_9's Avatar
Thanked: 187 Times
The screw in the non-CV carburettors (VM24 & VM28) on the Bullet are air bleeds, i.e. they monitor the amount of air into the engine at idle.
Also, thanks for sharing the information about the CV carurettors, didn't know that.
Happy thumping,
Prakhar
Old 26th February 2010, 03:09   #145
Thanked: 175 Times
i have ordered a upswept goldstar from Sans. i hope to receive it in a week or so. this time sans have changed the design to look like ones awaiable in south i mean in Pune the famous shakeel sorts. lets see how that thing performs.
i already have a goldie from Royalmotors. it is a direct pipe bloody loud. i dont like it that loud it is so dumb to use that kinda pipe on a british single.
thanks will update the thread soon.
Below attached are the pics with the goldstar on the bike, this is a old pic from 2007 october i think
desideep is offline   Reply With Quote
Old 26th February 2010, 13:10   #146
naveenroy's Avatar
Thanked: 782 Times
Would appreciate you attaching a pic as soon as you fit it. Looking forward to the performance report too since I am looking to get the same.
Old 23rd March 2010, 14:24   #147
throttleking's Avatar
Thanked: 340 Times
@desideep,
you got the silencer? how is the performance?
throttleking is offline   Reply With Quote
Old 24th March 2010, 02:00   #148
Thanked: 175 Times
Hey Man,
i am sorry but i have not received the Exaust yet. i have been keeping very busy
if you check the thread bellow in my signature thats what i have recently done to me bike. and i hope to fit the exaust if i receive it in next some days as soon as i hit the 1500 KM mark.
Desi D
http://www.team-bhp.com/forum/motorb...o-avl-std.html (What to do ? AVL and STD.)
Old 12th April 2010, 00:00   #149
Thanked: 175 Times
i received a call on 6th April the tuesday that the Exaust was ready and if i can come and collect it. thanks to Mr. Katar himself that he took pains to get it fitted to my bike.
The exaust sounds real nice. the best part it that the Thump is not too loud. but it is a very soothing thump.
Old 12th April 2010, 12:12   #150
DesertKing's Avatar
Thanked: 20 Times
Hello friends,
I am riding my friend's Thunderbird 2003 and am going to buy the same soon. I wanted to know what silencer does it have (pls see the below photos) and how do you rate it. It is yes a bit too noisy but I do not mind.
I was thinking to go for one goldie from Sans Inc, Delhi, pls advice the what do you think the effect in performance would be.
DesertKing is offline   Reply With Quote
Bullet silencer for sale. 2 numbers Gordon Shifting gears 1 22nd April 2007 15:58
Decarbonizing your diesel car silencer at home tsk1979 Technical Stuff 16 30th July 2006 10:53
Baleno silencer touches filcord Technical Stuff 12 8th December 2005 22:20
MATIZ - Silencer noise SCH Technical Stuff 7 23rd March 2005 00:32
