| LinkBack | Thread Tools | Search this Thread |
| | #151 |
| BHPian | Its a free flow indore silencer.A bit loud silencer but doesn't effect the engines performance noticeably. |
| | #152 | |
| BHPian Join Date: Aug 2008 Location: Bangalore
| Quote:
It looks like good old short bottle (may be after market) silencer. Thanks, Pradip. | |
| | #153 | |
| BHPian | Quote:
Its not a short bottle as a short bottle has a small neck. Nonetheless,diff. states may call it by different names. | |
| | #154 | |
| BHPian | Quote:
PS :: does this misfiring indicate something?? To everybodies wonder, I like the misfiring sound, just eager to know (will not opt for sure) if it can be increased without any harm to the engine and power/performance. | |
| | #155 | |
| BHPian | Quote:
Though many do not like it at all,I am not aware of its long term effects on the engine. | |
| | #156 | |
| BHPian | Quote:
| | #157 |
| BHPian | Sorry for going OT on this thread. Pls help me on the below thread by sharing your knowledge there, I am dying to own the Thunderbird and need all of yours help... http://www.team-bhp.com/forum/motorb...ng-doubts.html |
| | #158 |
| Senior - BHPian Join Date: Feb 2006 Location: Bangalore
Thanked: 158 Times
| Hi all, Where can I get the goldster Silencer in Bangalore. I want to put it on my CI 500 |
| | #159 | |
| BHPian Join Date: Feb 2010 Location: Bangalore
| Quote:
Delhi is another option as well. If you browse through the pages you'l get the numbers of the fabricators. | |
| | #160 |
| BHPian Join Date: Aug 2009 Location: Dehradun
Thanked: 19 Times
| @SANS : leaving out the thump what would be the difference between the two grilled silencer and the single one ? you use glass wool as well ? |
| | #161 |
| BHPian | |
| | #162 |
| BHPian Join Date: Dec 2009 Location: Bangalore
Thanked: 38 Times
| OK. Not sure if this thread is still alive, as the last post was made some 4 months back. A lot has changed in the recent past with RE products. @ Jay and others: I have a machismo 350, 2008. I got a Goldie from Shakeel ( 1.5 yrs back) and put it on my Machismo. The plan was to upjet and use a free flow filter with the Goldie. Did not materialize, blame it on my laziness. I liked the note of the Shakeels Goldie at low revs, but at higher revs, the thump was lost, taken over by this loud shrilling noise. Too loud for me taste. (i was using the Goldie with the cat-con removed from the OEM bent pipe). with the Goldie, i could feel reduction in back-pressure, and also reduction in initial pickup. I removed the Goldie, put a short bottle, did some acoustic experiments with the CEAT mudflaps (meant for mini trucks) clubbed with silencer end rubber ring, and was satisfied. Thats how my machismo 350 is running today. About 6 months back, i got the delivery of my classic 500. From the very beginning, i bought the up-swept silencer (made and marketed by RE as off roading silencer). the Up-swept for the C5 (classic 500), has to be bought with the bent pipe. This bent pipe DOES NOT have a cat-con. (hence marketed as off road, as the latest emissions norms are not met). Anyhow, i was not satisfied with exhaust note of this up-swept silencer either on my C5. All this while, i still had the Shakeel's Goldie with me ( the one bought for my machismo 350) Now i am planning to make some mounting modifications, and use that Goldie on my C5. I tried putting the Goldie (holding with hand) with the bent pipe of up-swept (without the cat-con), and started the bike to get a feel of the sound. The bike sounded much better at idle, but with little throttle, the sound became very loud and shrill. ( the bike was stationary, as the Goldie was not mounted to the bike, but held with had to get a feel of the sound) have decided to modify the mounting points on the Goldie anyways, and get test it out. A few issues which comes to my mind: the C5 has a fuel injection instead of carb, so up-jetting etc is out of question. What i can do max is use a free flow air-filter. The C5 is got an AIR FLOW SENSOR, which senses the amount of air intake, and compensates petrol accordingly (based on the mapping). I am hoping that with a free flow air-filter (K&N), the Airflow-sensor would sense increase in the amount of air and accordingly adjust the petrol mixture. However, i am not too sure about all this. Was wondering, if i use the Goldie on the C5, will it have any other adverse affects? will it fry/melt the exhaust valves? Would there be any difference in performance? Also, the dia of the Goldie is slightly larger than the bent pipe. How can i adjust that? (what type of packing can be used? Guys, throw in your suggestions / inputs for these new breed of enfields, so that they can sound at-least 80% of what a well tuned standard would. ![]() Last edited by nasirkaka : 24th September 2010 at 13:15. |
| | #163 | |
| BHPian Join Date: Aug 2009 Location: Bangalore, Cochin
Thanked: 17 Times
| Quote:
Regarding the upjet for an FFE, i've no idea about the newer breeds. Is it possible to somehow re-map the C5? Do you have the open-able Shakeel Goldie? The later ones (including the one I have) comes with an open-able back where you can stuff in glass wool. I'm running a shakeel Goldie with glass wool half filled, and i can bear the sound even at 100+. Another suggestion, there is another breed of goldies, sold by Sans from Delhi. Those are not free flow, but comes with baffles in them. If sound is the only reason why you want to upgrade to a Goldie, you can give the Delhi Goldie a try. I have a spare one which I tried on my bike for sometime, PM me if you want to try it on and check the sound. | |
| | #164 |
Thanked: 38 Times
| @ jingaboysr The goldie which i got from shakeel is NOT open-able type. Its a single piece goldie, with a perforated sheet metal bent like a flower petal in side. There is not glass wool. Yesterday, i managed to fit that old Goldie on to the C5. ( abit of cutting and welding of mounting points.) the C5 with goldie sounds very different compared to either stock or up-swept. Its much loud. The beats are clear, loud and bassy at low revs, and the bike sounds very good at speed of 50kmph in 4th gear / 60 kmph in 5th gear. BUT, as soon as the engine is revved, the thump changes in to a loud snarl/roar. (the typical character of the goldie replicas). The engine feels like its breathing easily, the back-pressure seems to have reduced. Also, i think, there is slight reduction in initial pickup. (i may also feel so, as i was a little reluctant to rev hard, cos of the sound and scared of heating the exhaust valves. Talking more about the goldie, the beat its making it a little louder than what i would prefer. So i am planning to cut the goldie, remove the petal shaped perforated sheet, fit another perforated sheet tube, and fill the gap between the perforated sheet tube and the outer wall with glass wool. Have already spoken to a sheet metal tinkering and he would do it for me. I am hoping that would reduce the loudness, slightly and made the beat even more heavy on base. Got to chrome plate the goldie again so might aswell explore the glass wool as well before plating. Sound is the main reason for me switching to goldie. Performance boost would be an added advantage. (contrary to popular belief, i feel C5 is way underpowered), for all the newness / price. Here is pic of yesterdays fitment of the old goldie. |
| | #165 |
Thanked: 17 Times
| Here is my Glodie ![]() May be you can try to make the silencer openable, so that you can insert/remove glass wool as you wish. The guy whom I gave for chroming told that the glass wool would melt inside when they chrome it, so I removed it and got it chromed. Insertion of glass wool did not make the low end more bassy in my case, it reduced the sound. That's the reason why I run my bike with glass wool loosely filled in. |
Similar Threads | ||||
| Water in Silencer | revhappy | Technical Stuff | 21 | 15th October 2009 20:13 |
| Silencer Noise!! need urgent help | amit_mechengg | Technical Stuff | 9 | 26th May 2008 16:49 |
| silencer issue! | ariendj | Technical Stuff | 10 | 4th May 2008 00:00 |
| silencer fallen off. help!! | kutlee | Technical Stuff | 6 | 11th October 2007 20:34 |
| silencer got a crack | sankeerthreddy | Modifications & Accessories | 9 | 25th April 2007 18:59 |
