Old 10th March 2011, 14:54   #1
Gordon's Avatar
Thanked: 197 Times
Default Ignition Coil - Machismo AVL 350
Seems like my ignition coil has failed. Any idea how much a spare would cost? Also can I fit any 12v ignition coil, since it is a CDI unit that controls it eventually?
Gordon is offline   Reply With Quote
Old 12th March 2011, 07:32   #2
Thanked: 175 Times
Default Re: Ignition Coil - Machismo AVL 350
i got one fitted on my bike for 100 RS + 50RS to fit it. but it was a desi one. i am not sure if the ignition coil is sold separate.
i hope you are talking about the one that is in the clutch case. not the HT?
desideep is offline   Reply With Quote
Old 12th March 2011, 11:24   #3
Randhawa's Avatar
Thanked: 270 Times
If it's the HT then its for Rs 470 and you can not fit the bigger coil from other bullets but the coil from Bajaj Boxer works on AVL. That's what RE mechanics say.
Randhawa is offline   Reply With Quote
Old 12th March 2011, 17:13   #4
Gordon's Avatar
Thanked: 197 Times
Went to Sharda Motors, who quoted me Rs 560. Got it instead from another Enfield Spares Dealer for Rs 280 - exactly the same one.
Anyways, the issue wasn't even the ignition coil, but messed-up wiring.
Old 13th March 2011, 14:50   #5
iron's Avatar
Thanked: 33 Times
IS there a shortage of spares for the AVL ?
@ gordon. from where did you get the ignition coil?
iron is offline   Reply With Quote
Old 16th March 2011, 12:10   #6
Gordon's Avatar
Thanked: 197 Times
From a shop on juhu-versova link road called Sahni Scooter Parts.
Old 4th November 2011, 02:36   #7
lazyrider's Avatar
Thanked: 20 Times
Question Carb for Machismo AVL 500
Bikers please advice.
I own a Machismo AVL 500 and of late have been experiencing this problem (at times not always) it feels like there is no fuel in the bike and it th engine almost goes dead.
There was a crack in the rubber intake pipe which was replaced, after the replacement the problem has somewhat reduced.
I think its a problem with the carb, my mechanic is of the same opinion.
The stock carb is a CV BS29, are there any other options?
Any help will be appreciated.
lazyrider is offline   Reply With Quote
Old 9th November 2011, 12:18   #8
Ali
Ali's Avatar
Default Re: Carb for Machismo AVL 500
Does this happen when you throttle at higher speeds? or at all kind of speeds? if at high speeds i read somewhere that it seems to be something with the petrol on/off knob. It seems the washer expands and it can be a cause.
Anywayz, where in hyd do you get your bullet serviced. I'm looking for a reliable mechanic, most of them are too busy to pay attention and i need attention to detail.
p.s- Remove the petrol on/off fitting from the tank and re attach it. Let me know how it goes.
Ali is offline   Reply With Quote
Old 9th November 2011, 14:14   #9
lazyrider's Avatar
Thanked: 20 Times
It happenes at higher speeds, let me check the petrol knob.
There's a mechanic beside Sanath Nagar Police station called Pavan, does a pretty good job, but he takes time.
Old 9th November 2011, 18:32   #10
madbullram's Avatar
Thanked: 76 Times
Lazyrider, I had a similar problem in my AVL. After checking carb, CDI etc we finally found out the problem was with the pick-up coil. Another friend had a similar problem and the issue was worn out wiring. So do check the electrical too.
madbullram is offline   (1) Thanks Reply With Quote
Old 10th November 2011, 19:20   #11
Rennjit's Avatar
Thanked: 84 Times
@ madbullram/ anyone familiar with RE's Cdi,
could you guys say how the trigger(reluctor) for pulse coil was arranged on Cdi machine? Afaik pulse coil sits way off the rotor unlike Tci unit.
Rennjit is offline   Reply With Quote
Modifying the Machismo 350 AVL (including a disc -> drum brake conversion) imbue Motorbikes 24 4th April 2014 21:04
Enfield Machismo 500 avl - front tyre change makanaka Motorbikes 38 5th October 2011 12:54
Me and My Bull 500cc Machismo AVL; The Journey has begun jimmyjagga Motorbikes 22 2nd May 2011 11:29
Machismo 350 AVL Technical Specs - Engine Oil, Clutch and Gearbox Amount and Specs imbue Motorbikes 1 26th April 2011 19:59
R.E Machismo 350 Ignition Timing Advance drsamuelk Motorbikes 1 2nd April 2010 21:01
