Old 15th March 2011, 09:24   #1
Default Valve problem in P150?
I have P150 DTSi version, 2006 model. have installed K&N performance filter and bike has done 38k kms till now.
Offlate I am experiencing problems with engine revving. If I ride the bike at 80-100 speeds for some time and then stop the bike, the RPM will be toggling between 1.5k and 2.5k. When I enquired my mechanic about this he said its problem with valves. And the main reason the valves got damaged was because of the air filter. Has the filter done any major damage to the engine?
Also at speeds of 70-80 the RPM will be post the green mark. I feel that engine is revving too much than what is required. Or is this the normal behavior?
_abhishek is offline   Reply With Quote
Old 15th March 2011, 11:04   #2
rdna's Avatar
Default Re: Valve problem in P150?
What is your idle RPM when idle? I'm not sure for Pulsars, but RTRs should hover slightly less than 1.5k. Running a bit more rich can have the effect which you see your bike when you are riding in a hot condition for too long.
rdna is offline   Reply With Quote
Old 15th March 2011, 14:53   #3
@rdna, the RPM when idle is set to 1k.
8 Valve SOHC vs 16 Valve SOHC shineshine Technical Stuff 6 12th February 2016 22:23
Upgrading from a P150. What bike for <1L INR? ashis89 Motorbikes 18 24th July 2012 12:30
P150 Engine Decarb at 22K kms _abhishek Motorbikes 6 14th June 2010 17:34
P150 Airfilter Mod abhijeet080808 Motorbikes 16 12th May 2009 23:31
My lovely P150 thrashed! :-( hyper123 Motorbikes 43 22nd June 2008 20:06
