Old 11th September 2006, 19:53   #181
Maverick5490's Avatar
Thanked: 671 Times
Hey guys.. got this in a mail.. thought i should share it with u..
Bajaj Pulsar DTS-Fi: More images and specs
  • First four stroke engine in the world employing DTS-Fi technology
    • Intelligently controlled ignition timing for each plug
    • High combustion efficiency
    • Low performance variability between engines
    • Precise metering of fuel for highest outputs and lower emissions]
    • Easy engine starts in all conditions of temperature and altitude
    • Best in class fuel economy [ as in beating the Karizma? Is that even a task?
    • First natural air-cooled 4-stroke engine in India employing a oil cooler
      • Maintains lube-oil viscosity even under extreme conditions of stress and ambient temperatures.
      • Also helps in cooling the engine internals
      • First high capacity engine in India to employ rollers at rocker arm pivits and camshaft interfaces for low friction
      • First engine in India to have electric start as the sole means of cranking
    • First two wheeler in India to employ tubeless tyres for superior performance and safety
    • First vehicle in the class to employ the widest tyres
    • First vehicle in India to employ a hydraulically actuated 230 mm rear disc brake
      • Enhances braking performance and control
        • First bike in India to employ a large 37 mm front fork for class leading vehicle dynamics
        • First... India to employ a non-contact digital speedo drive for accuracy, simplicity and long life
        • First... India to use clip-on handlebars
        • First... India to use a unique damping method for damping high frequency vibrations in clip-on handlebars (patent applied for)
        • First... India to employ a pure sports riding position
        • First... India to use a 3000 combination ignition cum steering lock with a twin-track pilfer proof key
        • First...world to employ backlit handlebar switches
        • First... India to employ non-contact handlebar switches for soft touch feel and zero maintenance
        • First...world to employ non-contact 'intelligent' self-cancelling turn signals
        • First... India to employ 'black mask' twin headlamps in a vertical stack configuration
        • First... India to employ a high wattage (H7, 55W) ellipsoidal projector lamp for white light low beam illumination
        • First... India to employ a high wattage (H7, 55W) compact clear lens parabolic lamp for white light high beam illumination
        • First... India to employ white light pilot lamp bulbs
        • First...India to employ a large free form orange backlit LCD speedo panel, displaying among other things the vehicle speed [ accurate to within 2 kph ], odometer, 2 tripmeters, graphic fuel level indicator and other information icons [ diagnostics: air filter choked, oil temperature, battery voltage and oil level ]
        • First... India to employ a stepper motor driven tachometer needle for quick undamped response
        • First... India to incorporate a flashing over-rev warning light in the speedo console
        • First... India to have an electronic speedo console which when keyed on goes through a self-diagnostic check
        • First... India which incorporates a flashing warning light for low fuel level
        • First... India to incorporate a day-night mode for the speedo console. In day mode, the indicating lights are brighter for clear visibility in ambient sunlight. In night mode, these lights reduce their brightness to prevent glare
        • First... India to employ a battery-saving function to automatically switch off headlamps while cranking
        • First... India to employ a battery-saving function to automaticallyregulates the number of continuous cranks
        • First... India equipped with a high-capacity O ring chain for final drive - smooth operation and long life in harsh operating conditions
        • First... India employing elliptical section swingarm on needle roller pivot bearings
        • First... India to incorporate sculpted, compact, fairing mounted rear view mirrors
        • First... India with sporty, sculpted two-piece grab rail for sleek big bike looks
        • First... India with a split seat design for easy access to tool kit and first-aid kit
        • First... India to sport 'twin slash' high intensity LED clear lens tail lamp, requiring zero maintenance
        • First... India to sport and aggressive and stylish anti-scratch tank pad to prevent damage to petrol tank paintwork due to zippers
Maverick5490 is online now   Reply With Quote
Old 11th September 2006, 19:57   #182
Thanked: 671 Times
not able to post the pics. wil try again later..
Well i have it on my mail.. dont know how to get it here.. any advice?
Old 11th September 2006, 23:42   #183
manson's Avatar
Thanked: 2,230 Times
right click on picture and save it on your hard drive.
after that just host them on imageshack etc
manson.
manson is offline   Reply With Quote
Old 12th September 2006, 09:18   #184
Default launch date
Any news on the launch date??????
Vicki_Rau is offline   Reply With Quote
Old 9th October 2006, 13:22   #185
Default 220 Pulsar Revised Launch Date Anyone?
The new 220 Pulsar DTS-Fi was scheduled for a Diwali Launch but seems to have been put off with just a revamped 180 Pulsar DTSi hitting the roads. Does anybody know when exactly the 220 launch is scheduled for?
amigoraj is offline   Reply With Quote
Old 9th October 2006, 13:26   #186
Rtech's Avatar
Thanked: 221 Times
Threads Merged. Please use the "search" option before starting a new thread.
Old 9th October 2006, 21:28   #187
turbo_v12's Avatar
Bajaj has postponed the launch of the DTSFi to Jan'07, probably during the Auto-Expo.
They've put quite some features which were to be a record first in the 220 in the new 180, though.
turbo_v12 is offline   Reply With Quote
Old 11th October 2006, 23:29   #188
Thanked: 21 Times
the new revamped 180 looks similar to the 220 .. launch is at Jan 07 as turbo v12 mentioned. but even ill rather wait till end of 07 for bigger one'1s ..... will try no to dream about it :d
nosfreak is offline   Reply With Quote
Old 12th October 2006, 11:12   #189
Joz
Default Pics: Part 1
Got this by mail some time back. Guess its the same as what Mav got.
Joz is offline   Reply With Quote
Old 12th October 2006, 11:20   #190
Joz
Default Pics: Part 2
Old 15th October 2006, 11:03   #191
Yamaha boy's Avatar
@Joz: nice pics buddy
hey but when bajaj gonna launch it.....hope 2 c it very soon on our roads
Yamaha boy is offline   Reply With Quote
Old 15th October 2006, 13:55   #192
blueraven316's Avatar
Good Job Bajaj. Please develop the Indian biking industry, it's progress totally sucks compared to cars.
Hero should stick to making bicycles, they are good at it.
blueraven316 is offline   Reply With Quote
Old 20th October 2006, 14:29   #193
Guys,
The dealers people here in Bangalore state launch probably in "Nov 06 IIIrd week" or "Jan 07 II week". That sure sounds strange, wonder why the 2 month gap.
The sales guy says that they are also waiting for Yamaha to lauch their 250 first.
Thats great, heres a company Bajaj (who according to rumours has already started production of the Fi) waiting for another OE to launch their product, about which nobody seems to have a clue, on the status.
.........and here I am, ready with my cash.............every two months.
Cmon Bajaj
PS went and checked out the self cancelling indicators on the new 180. They are magnetically actuated and are a real neat idea. The LED rear lights are awesome.
Old 20th October 2006, 17:42   #194
superboy44's Avatar
Thanked: 26 Times
i saw one on road today,,,
the cluster looked real classy and the best part looked the rear LED tail lamp
finally the heat is on for hot bikes,,
superboy44 is online now   Reply With Quote
Old 20th October 2006, 21:45   #195
ram_hyundai's Avatar
Thanked: 48 Times
hey guys ,
ive heard that it will be priced close to the 180 ,and there is a 180 comming out in the fi avatar too .so it will be 180,180fi,220fi.it wont go beyond 1 lak ,if it does then it will be bitting nail situation since the cbz is comming out with an fi version, the giny pig being the glamour fi.
ram
ram_hyundai is offline   Reply With Quote
Motormania’s Pulsar 220 DTS-i – Initial impressions and long term ownership review Motormania Motorbikes 10 11th May 2016 17:13
Pulsar 220 (new) or the Apache RTR 180 - EDIT - Bought Pulsar 220 M abhayshanu Motorbikes 203 1st March 2011 14:27
Bajaj Pulsar 220 DTS-Fi: Intial owner reviews... CrAzY dRiVeR Motorbikes 31 17th June 2010 15:26
Pulsar 220 DTS-FI Launched at killer price himanshugoswami Motorbikes 48 13th March 2007 14:51
