Old 29th March 2011, 20:25   #16
rajivanoj's Avatar
Thanked: 45 Times
Default Re: CT 100 bulb gets blown often
@ sajjt
I have done it, DIY as you suggested, but the regulator was under the seat. not near battery. Now the thing is working fine.
cost:
volt regulator Bajaj OE - Rs.192
OSRAM halogen 35w - Rs.80
brake bulb - Rs.8
No labour, since its an DIY. Thanks for all Bhpians for their suggestions and encouragement.
To MOD: Can edit title to SOLVED
rajivanoj is offline   Reply With Quote
Old 29th March 2011, 21:12   #17
kaushikr's Avatar
Thanked: 34 Times
Originally Posted by sajjt View Post
Dude, putting a new battery wont settle this as the battery will also get fried just because of faulty RR. Basically a RR will stabilize the over voltage by shorting internally with the help of SCRs. RR have to functionalities first is regulating the supply to a max of 14V and the second part is rectification for the the battery charging. Battery cant suppress any excess voltage and it doesnt have any connection to the lighting circuit. Lighting coils will produce a moderate voltage at normal rpms hence no issues but once you are trying to overtake or increasing the speed, rpm increases and obviously voltage too. Normal bulb will withstand a max of 16-17v beyond that it will blow.
@rajivanoj What about your tail lamp/console lights? That should also be in the same condition by now. Replace your RR there's no much options left for you.
Hey Sajit, missed the bit that not all the lighting circuit are connected to the battery. My bad. But frying the battery, are you sure about that?
@rajivanoj, great work and good to hear that the issue is sorted!
kaushikr is offline   Reply With Quote
Old 30th March 2011, 11:10   #18
sajjt's Avatar
Thanked: 97 Times
Originally Posted by rajivanoj View Post
@ sajjt
cost:
brake bulb - Rs.8
Glad to hear that you've fixed it.
If the RR is good there's no worry about frying the battery. Only horn, selfstarter, blinker, console or brake lamps are usually connected to battery on a AC+DC bike. Hope this clarifies
sajjt is offline   Reply With Quote
With rising fuel prices, are small capacity blown petrol engines the way forward? MaserQ Technical Stuff 17 10th August 2011 11:13
pics of a blown toyota paras211 Modifications & Accessories 2 11th January 2008 14:40
hissing noise from speakers when horn is blown gopz In-Car Entertainment 7 14th June 2007 13:40
MS BLOWN into retirement .... khaadu75 Int'l Motorsport 2 23rd October 2006 01:01
RaceR Tech tacho blown! steroidauto Modifications & Accessories 7 5th January 2005 13:23
