Old 18th April 2011, 16:47   #16
Thanked: 172 Times
Default Re: *Installed* : Hydraulic Clutch For RTR and FZ
Ajay you may have seen pics of Delhi RD's running the Hyraulic clutch. i know the man who does the JOB
desideep is offline   Reply With Quote
Old 18th April 2011, 19:35   #17
Ajaybiz's Avatar
Thanked: 140 Times
This is done way back in 2001 in Bangalore first as Bangalore is known for setting up any kind of benchmark first whether performance or cosmetics and Delhi follows the same trend.
Ajaybiz is offline   Reply With Quote
Old 25th April 2011, 16:39   #18
Where in Bangalore we can get this mod done? Need it for an Yamaha RD
TurboGuru is offline   Reply With Quote
Old 27th April 2011, 17:03   #19
rajatsingh78's Avatar
Thanked: 27 Times
never seen any Bangalore bike with hydraulic clutch done, whoever does them there, is he not interested in advertising his creation so that he gets customers from all over India? Or is he the one who does for only a specific group ?
rajatsingh78 is offline   Reply With Quote
Old 27th April 2011, 18:04   #20
chiragh_bir's Avatar
Thanked: 69 Times
hydraulic clutches i have seen are lot different from what you have done ..
you are still using the same clutch system which operates via wire , the hydraulic clutch system works on fluid forces inside the clutch box !!
none the less something new to see
chiragh_bir is offline   Reply With Quote
Old 12th November 2011, 08:13   #21
racerdabba's Avatar
Thanked: 121 Times
Sir, this was done as my Final year project, B.tech Mechanical. Due to shortage of time, resources and more importantly Vit M, didn't want to mod the clutch mechanism. Also we wanted a system which can be easily reversed if the need be, and a setup that can be used on almost all Indian bikes with a little mod.
Im on the way to make some more minor changes, and make it even better. BTW this setup is still in use in both the bikes, and not a single problem yet. Still the ultra smooth operation.
racerdabba is offline   Reply With Quote
Pros & cons of hydraulic clutch sbasak Technical Stuff 38 24th November 2017 20:12
What's the point of a Hydraulic clutch, why not go the "EPS" way tsk1979 Technical Stuff 10 20th January 2015 14:14
Diesel clutch release bearing installed in a petrol car. Possible effects? Crazy_Eddy Technical Stuff 2 16th July 2013 03:16
RTR 160 vs RTR 180 rangakishen Motorbikes 42 7th January 2012 20:59
Help needed- Hydraulic Clutch conversion on RD350 aruncheloor Motorbikes 2 14th April 2009 10:53
