Old 18th November 2012, 14:00   #1786
swiftnfurious's Avatar
Thanked: 5,379 Times
Originally Posted by champ27
...[*]In the 2nd gear, the car has a tendency to jump ahead if you don't keep the clutch pressed. I prefer to drive in the 2nd gear in a slow moving traffic instead of 1st gear and end up driving mostly using the clutch as the car is always willing to lunge forward. Is it the same with everyone? How do you go about driving in an extremely slow moving traffic?
The 'jumping' happens because of the idle rpm & ecu helping not to stall the vehicle. In slow moving traffic, I use first gear on my Swift D.
[*]When I started off, I used to get FE of around 17-18 in city but now it has come down to 15 with AC in a stop start traffic. I have never gone beyond 2500rpm till date. What could be the reason?
Are all the parameters exactly the same like time of travel, traffic density, people in the car, gear shift patterns, AC usage, external temperatures etc?
1. Do you fill fuel from the very same pump?
2. Check the tyre pressures.
3. Additional heavy equipment in the car?
4. Get the air filter cleaned up.
Recently I did a Bangalore - Goa trip and the FE while going with 4 guys in the cabin was 20.3 and while returning was 18.3 with 5 guys in the cabin. Does the lower FE attribute to an extra person ? What has been your experience in a similar situation.
Yes. FE is inversely proportional to the weight inside the car.
swiftnfurious is online now   (1) Thanks Reply With Quote
Old 18th November 2012, 19:25   #1787
Thanked: 62 Times
Default Re: Hyundai Verna : Test Drive & Review
1. Do you fill fuel from the very same pump? Yes
2. Check the tyre pressures.I mostly drive as per the recommended pressure, i.e, 33 in all 4 tires
3. Additional heavy equipment in the car? No
4. Get the air filter cleaned up.Is it really required for a new car that has just done 5000 km?
Thanks!
No, the parameters are not exactly the same. Now the traffic is more towards the heavier side. As indicated in my earlier post , since I prefer to drive in 2nd gear even in start stop traffic, it results in more usage of clutch to prevent the car to lunge forward. Maybe I should try using the 1st gear in such situations but I don't like the engine over revving in 1st gear. Other answers are inline. Earlier, since the traffic was on the lesser side, clutch usage was on the lower side. All the other parameters apart from these two are mostly same.
champ27 is offline   Reply With Quote
Old 18th November 2012, 19:52   #1788
..No, the parameters are not exactly the same. Now the traffic is more towards the heavier side. As indicated in my earlier post , since I prefer to drive in 2nd gear even in start stop traffic, it results in more usage of clutch to prevent the car to lunge forward. Maybe I should try using the 1st gear in such situations but I don't like the engine over revving in 1st gear. Other answers are inline. Earlier, since the traffic was on the lesser side, clutch usage was on the lower side. All the other parameters apart from these two are mostly same.
Diesel filters can pick up a lot of dust, so it's better that you clean up & re-use the same filter every 5K kms. Hyundai might have some general check ups which costs some 200/- or so & includes checking all fluids, filters etc. A road side mechanic could do the job as well. If you are a DIY person, it should not be complicated at all.
I do NOT recommend usage of 2nd gear from a start stop. And why should there be an over revving in first gear? In start stop traffic, you could move the vehicle easily using the clutch alone in first gear. Try that please.
Old 18th November 2012, 20:48   #1789
Thanked: 62 Times
Thanks for the suggestions, I will try them out. Over revving happens when I have to quickly speed up in 1st gear to avoid sidewinders cutting into my lane especially the bikers.
Old 26th November 2012, 13:52   #1790
KPS
KPS's Avatar
Thanked: 3,363 Times
Just an update.
My June'11 car has now done 18K kms. The front coil springs have been replaced under warranty. The front is a stiffer and improves road handling big time. All the road humps do not scrape the bottom now.
Overall great improvement
KPS
KPS is offline   Reply With Quote
Old 26th November 2012, 17:15   #1791
FlyingSpur's Avatar
Thanked: 1,310 Times
The tiptronic box on the automatic seems more like a suggestion box than something that takes a shift command. Is this normal? I have never seen this in any other automatic I've driven. And no, please, I'm NOT comparing this to the 320d.
FlyingSpur is offline   Reply With Quote
Old 30th November 2012, 17:11   #1792
revved_up's Avatar
Thanked: 162 Times
Originally Posted by revved_up View Post
Hi All,
Has anyone of you changed the gear lever to the one which comes standard with SX(O) variant? I am desparately trying to get onem but service centre keeps asking me to get them the part code and then they can order it.
I saw on some other forums that people have ordered this from local hyundai service centre.
Can anyone help me out here?
I want the below lever:
Finally, I managed to order this gear knob.
The part code is 437113x200hz and the price is Rs.735
DIY procedure for changing the gearknob can be seen here:
http://www.hyundai-forums.com/233-rb...ai-accent.html
revved_up is offline   Reply With Quote
Old 30th November 2012, 21:07   #1793
Thanked: 32 Times
Originally Posted by KPS
Just an update.
KPS
Do you advice I get front coil springs replaced to improve handling and avoid scraping. Where did you get this job done?. I have done 32k kms.
shenoytech is offline   Reply With Quote
Old 30th November 2012, 22:45   #1794
Vid6639's Avatar
Thanked: 17,189 Times
Yeah dude that is normal. Have seen the same on a Sonata CRDi AT as well. Even if you want a shift it will only shift when it deems fit. Most of the time the tip-tronic rejected the shifts I wanted since they were too aggressive.
Old 2nd December 2012, 14:17   #1795
revved_up's Avatar
Thanked: 162 Times
Picked up the gear knob from Hans Hyundai Moti Nagar yesterday.
The SA told me that changing it is a tedious exercise as the whole panel will need to be opened.
I told him, never mind. Changed it myself today morning using the instructions in the link in my previous post. Total time taken, 5 mins.
Here is how it looks now.
Hyundai Verna : Test Drive & Review-imag0393.jpg
revved_up is offline   (1) Thanks Reply With Quote
Old 2nd December 2012, 14:39   #1796
Tassem's Avatar
Thanked: 413 Times
Default Part Number for Rheostat?
Can someone help with a part number for the Console Illumination Control Rheostat? It's that roller next to the headlamp alignment roller.
This is what I'm talking about (Image is for representation only, as I have the fluidic model) -
Originally Posted by wildon View Post
Tassem is offline   Reply With Quote
Old 2nd December 2012, 14:44   #1797
revved_up's Avatar
Thanked: 162 Times
Default Re: Part Number for Rheostat?
I shall try to find out. BTW, what happened to the orignal one?
Edit: Oh, is it because yours is not the SX model and does not have the "supervision cluster"?
Old 2nd December 2012, 14:48   #1798
Tassem's Avatar
Thanked: 413 Times
Thanks! I really appreciate it.
My car did not come with it. I have the base 1.6 CRDi The console automatically dims when I turn on the park lights. However I'd like to have this option.
Old 2nd December 2012, 14:50   #1799
revved_up's Avatar
Thanked: 162 Times
Ok, understood. I shall try to bug the store guy again(earlier i bugged him for the gear knob..lol).
Edit: If you want, you can take the VIN number of any SX variant standing in the service centre, walk up to the store and ask him to find out the part number. Thats how i found out for the gear knob.
If you want the vin of my car, PM me, I will give it.
Else, I shall do it on my second service which is coming up shortly.
Old 9th December 2012, 16:12   #1800
Thanked: 9 Times
Did 30K paid service over the weekend. Total cost came to Rs.7754. Following were done/changed -
Parts -
1. Brake Fluid - Rs.110
2. Coolant - Rs.486
3. Engine Oil - Rs. 1123
4. Fuel filter catridge - Rs. 1751
5. Air filter - Rs.304
6. Oil filter - Rs.366
7. Gasket - Oil Plug -Rs. 33
8. Brake Caliper - Rs.90
Labour -
1. Radiator flushing - Rs. 380
2. AC blower cleaning - Rs. 600
3. Periodic Service Charge - Rs. 850
4. Rear and Front Brake Calibration - Rs. 860
Items 1,2 and 8 in the parts list and items 1,2 and 4 in the labour list were done as part of 30K service. Therefore, hoping the routine 10k service charges to hover around 6K.
In addition to the above, one of the reverse sensors had failed and was replaced. Third one to be replaced. Checked with the SA on the suspension coil spring replacement. He has promised to check my VIN and get back. Mine is April 2011 batch.
manumike is offline   (1) Thanks Reply With Quote
Hyundai i10 Kappa2 : Test Drive & Review Stratos Official New Car Reviews 391 3rd January 2017 14:14
Hyundai Verna 1.5 CRDi Diesel Automatic Test Drive - My Views VSG12777 Test-Drives & Initial Ownership Reports 13 12th January 2011 10:43
Hyundai Verna(VGT) test drive(torture drive) tsk1979 Test-Drives & Initial Ownership Reports 67 3rd October 2008 20:20
