Old 10th November 2016, 10:42   #1771
Thanked: 187 Times
Default Re: Ford Fiesta : Test Drive & Review
Originally Posted by Arsi View Post
2 - I notice a grunting sound from the left wheel as I turn towards right at considerable speeds. No such sound is heard in the otherwise direction. (Bearing issue?)
Check the drive shaft. These are typical wear & tear parts that need replacement after ##k kms. My Fiesta just crossed 80k and both front drive shafts are due for replacement. Its making the grunting sound while turning
Originally Posted by hypermiler View Post
The temperature reading (just above where our ODO is) tends to gradually increase a lot particularly at crawl speeds (1st or 2nd gear) while driving during peak hours.
I would think a good radiator clean up is due. I had a recent incident on a Chevy Tavera, that had a blown engine due to rad corrosion/clog. Many places have hard water and this can add to the issue. If your car has high miles, then show it to an experienced mechanic for a radiator check up/clean up.
Czarcarsm is offline   Reply With Quote
Old 10th November 2016, 11:35   #1772
swiftnfurious's Avatar
Thanked: 6,017 Times
Originally Posted by rock18 View Post
What is the ideal air pressure that needs to be maintained? I recently changed to Continental tyres and kept the pressure at 33psi for all 4 tyres. Car feels floaty. Please suggest the ideal pressure to be maintained...
It's better that you try reducing 2 psis and keep experimenting till you find the sweet spot. As far as I understand, the nitrogen top ups are usually free, any reason why you feel it's not practical to change the pressure?
How often do you check your tyre pressure?
swiftnfurious is offline   (1) Thanks Reply With Quote
Old 10th November 2016, 14:44   #1773
rock18's Avatar
Thanked: 54 Times
Thanks for replying. I travel alone one day and with family the next day..so i thought its not practical to change the pressure on a daily basis.
Nitrogen is not free here, even for top ups.. Maybe few places in Chennai might offer free topups.
As you said, Need to find a sweet spot for both.
I guess only Fiesta has this extreme variations for single and full load and hence the confusion.
rock18 is offline   (1) Thanks Reply With Quote
Old 19th November 2016, 20:00   #1774
Arsi's Avatar
There has been one more dormant yet consistent issue since my last service. A few days after I brought my car home after cleaning the EGR valve and resetting the error at FASS, my car refused to start. The engine would crank but not fire. I had to tow it back to FASS. What they did there was simply unplug, blow air and plug the ECM plugs and the car started. Although everything seemed fine there, the fault still persists. What happens is that my car randomly refuses to start. After 20-30 cranks, the car starts as if there is no fault at all. And this happens very randomly. I am very sure that the error is electronic but not aware of what it could be.
Is it possible that they might have upset a thing or two in the circuitry while cleaning?
Arsi is offline   Reply With Quote
Old 14th December 2016, 08:12   #1775
Can anyone recommend a good HU for Fiesta 1.4 TDCI SXI . Wanted to change the stock HU . Not a full ICE upgrade but only HU which gives Bluetooth , USB and rear cam functionality . Rest all are plus.
Budget max 12/13k . Can get from US also .
kuduku is offline   (1) Thanks Reply With Quote
Old 14th December 2016, 15:23   #1776
mayankk's Avatar
Thanked: 3,113 Times
Any double din unit you pick up from Amazon will do. You should be able to get one in that budget. Camera would at most be another 1k.
mayankk is offline   (1) Thanks Reply With Quote
Old 15th December 2016, 07:58   #1777
Will this do https://www.amazon.com/Pioneer-DVD-p...3HJJRTFX7Q81JJ
or can you recommend something on these lines if possible less than 10k .
vehicle runs less than 40 kms in a week these days . No time to enjoy the music these days
kuduku is offline   Reply With Quote
Old 15th December 2016, 10:18   #1778
mayankk's Avatar
Look for something on Indian sites. The problem with US units is that the tuning for FM is 0.2Mhz stepped. That means you will only be able to listen to odd number frequency stations in India. For under 10k, you can pick up a Mega-audio all singing dancing unit. It will sufficient only, though. Not from a audiophile inclination.
mayankk is offline   Reply With Quote
Old 15th December 2016, 10:56   #1779
Something better in Indian then?
Not highest quality audiophile but better than average. Why waste money on new HU only for BT then - if have to go for average only
Will increase budget accordingly to minimum requirement.
Old 16th December 2016, 09:39   #1780
mayankk's Avatar
Something like this?
http://www.amazon.in/Blaupunkt-San-M...3Z2HB8JWMTZ69P
Ford Fiesta (Automatic) : Test Drive & Review GTO Official New Car Reviews 160 12th December 2014 16:41
Bought a Ford Fiesta Sxi Premium without a Test Drive Rastapopoulos Test-Drives & Initial Ownership Reports 171 1st December 2010 13:24
Ford Fiesta Sxi test drive below expectations Path_Finder Test-Drives & Initial Ownership Reports 5 16th July 2008 23:15
