Old 15th June 2015, 21:40   #1996
Santoshbhat's Avatar
Thanked: 3,492 Times
Default Re: Volkswagen Jetta : Test Drive & Review
Thanks. In that case, my first upgrade will only be the tyres. Regarding Bilsteins, I would like to get them, but I guess it will affect the warranty. So I will wait for atleast 3 years, to use 50% of the extended warranty.
Yep, been there done that! Coming from a Corolla I too was very happy with the taut suspension of my Laura. Fear of losing warranty kept me away from getting some very tempting upgrades. I enjoyed the stock car for nearly two years, but then could not resist any more. Bhpian Robimahanta offered me a drive in his car and I was sold.
Dealerships typically like to discourage you from modifying anything. But logically speaking, if you upgrade shock absorbers you will only lose warranty on suspension related stuff. And given that shock absorbers are the most likely component that could demand a warranty replacement, I don't think you have much to worry. Besides Bilstiens come with their own warranty and last much longer than stock shock absorbers. If you still think they will object, just paint them black and they won't even notice .
Originally Posted by Chethan B G View Post
That way, I think even a tyre upgrade also will effect warranty?
Jetta with its OEM setup, grips / handles and corners very well. Is something more required in real world conditions? I really could not understand..
Stock Jetta is a very good handler and the suspension has very good balance no doubt. But still the suspension is tuned towards comfort which will satisfy a majority of owners. The Bilstein B6 is not an all out sport suspension. It just gives you higher damping force which pushes the car to the ground a little more firmly. It eliminates that bouncy movement that you get when you go over road undulations and gives you that feeling of control at the wheel. The ride is never uncomfortable and the car just feels planted at all times. If you drive a lot on highways its a highly recommended upgrade for these D1 segment cars if you ask me. I regret I didn't do it earlier.
Santoshbhat is online now   (4) Thanks Reply With Quote
Old 15th June 2015, 22:22   #1997
Chethan B G's Avatar
Thanked: 697 Times
Arrow Re: Volkswagen Jetta : Test Drive & Review
Thanks. I am sold!
I will plan this as an alternative when I need to replace my stock shocks. Generally, what will be the life of the stock shocks? That is, when will they start to become bouncy? Around 50K Kms on the ODO?
Did you replace the springs also or only the struts? Can you share the cost please..
By the way, could get hold of 3MCR90 for the side windows and the front wind-shield for 20K.
Chethan B G is offline   Reply With Quote
Old 16th June 2015, 19:25   #1998
Thanks. I am sold!
Shock absorbers generally last about 60 to 70,000 kms. This largely depends on the kind of roads they are subjected to. Worse the roads, lesser the life.
No I have retained the stock springs. You will need to replace springs only if you want to lower the car. Bilstein B6 should cost you about 65 to 70K for a set.
Santoshbhat is online now   (1) Thanks Reply With Quote
Old 16th June 2015, 21:35   #1999
Thanked: 697 Times
Thanks.
Is 70K for a set of four? I think we need to replace all 4 struts together, else the car may have a rocking effect?
Old 16th June 2015, 22:43   #2000
paras211's Avatar
Thanked: 56 Times
How much do the stock struts cost ? I am past 90k but the ride is still firm. The car is used on highways 95%.
paras211 is offline   Reply With Quote
Old 17th June 2015, 17:56   #2001
Default Re: Volkswagen Jetta : iphone cable
Hi all owners,
My iphone cable in the glove compartment has died ( will not attach to the iphone - keeps slipping out), does any one have a 30 pin / lightning cable that they are not using? Will be happy to take it off you. VW thane says they don't have it in stock.
Thanks and regards
Shiv
clix22 is offline   Reply With Quote
Old 17th June 2015, 21:22   #2002
Thanked: 16 Times
My 2 year 4 month Jetta DSG Highline, would not start today. Some lights flashing, and clicking sound and different messages on the MID. Sometimes ESC is not functioning, sometimes Left DRL is not working (it is indeed working fine!) and asking me to put the lever in Parking (while it was in Parking). Also when I unlock the car with the remote, I get couple of warning bells.
Called up Roadside Assistance and realized getting 2 years extended warranty does not include Roadside Assistance and that needs to be purchased separately (some 3.3K for 2 years). No idea why VW Sundaram never bothered to sell that ...
Will wait for tomorrow morning to call the dealer and check. But anyone has any thoughts?
TIA!
Ram
Rammee is offline   Reply With Quote
Old 17th June 2015, 21:33   #2003
ajaypjayaraj's Avatar
Thanked: 1,078 Times
Sounds like a battery drain issue. This is the typical behavior of the car when the battery is drained below the tolerable limit.
ajaypjayaraj is offline   (1) Thanks Reply With Quote
Old 17th June 2015, 21:44   #2004
Thanked: 16 Times
Thanks! I am suspecting the same - only in my other cars in past, the typical duration was 4 year plus. Is 2 year+ a standard in Jetta?
Also, wish the cars would have some kind of advance warning (like low fuel indicator) to let us know that the battery is about to die. Suddenly failing to start is always unwelcome situation.
Old 17th June 2015, 21:52   #2005
It depends. My Octavia and Yeti batteries lasted roughly 3.5 years. Dealer said that's more than expected. They told me that the expected life is about 3 years for diesel cars. But there are people whose batteries lasted more than mine as well as less than that too. You can get your battery checked up. If cells are fine, get it charged completely once before putting it back in the car. Otherwise get it replaced. The dealer or a good battery shop will be able to guide you after checking the battery condition.
Old 18th June 2015, 10:37   #2006
Thanks.
Yes Chethan, 70K is for a set of four.
No idea. But if were to take guess, it should be between ₹ 30K to 40K for a full set. 100K should be a good time to replace your struts.
Old 18th June 2015, 11:19   #2007
Thanked: 282 Times
Did you try to jump start the car? If it starts, then you know it's battery issue and drive it straight to the workshop for the check-up/ replacement.
reverse_gear is offline   Reply With Quote
Old 18th June 2015, 19:48   #2008
Thanked: 16 Times
Did call the local battery guy and he came and confirmed that the battery is fully dead. Got it changed to an Amaron Flo battery with 2+2 years warranty. Car back to normal
Checked with VW Service center folks as well - it appears Jetta batteries seem to fail anytime after 2 years Not sure if other members have faced similar issues.
Old 19th June 2015, 09:08   #2009
Thanked: 10,033 Times
After 3 years and 3 months. My bettery failed today. It felt slow when i started up early morning, went to the gym. Car refused to start after that,
Need to pick up a new battery and get it fitted
Old 19th June 2015, 20:25   #2010
Thanked: 78 Times
Had a problem with ac not cooling immediately after starting my car in the morning. Took it to the service centre , on investigation turned out to be a faulty expansion valve , this along with dryer was replaced under warranty, so far its working ok
hubolt is offline   (1) Thanks Reply With Quote
Volkswagen Polo : Test Drive & Review GTO Official New Car Reviews 3998 15th December 2017 13:37
Volkswagen Jetta Comfortline 2.0 CrTDI : Test Drive And Initial Report sammycoolster Test-Drives & Initial Ownership Reports 15 13th November 2012 00:48
Volkswagen Jetta 1.6 Litre Petrol (Trendline) Test Drive, Review & Photos Karizma Fan Test-Drives & Initial Ownership Reports 40 18th February 2010 20:45
