Old 19th June 2015, 21:04   #2011
Tanveer_2558's Avatar
Thanked: 2,461 Times
Originally Posted by hubolt View Post
Had a problem with ac not cooling immediately after starting my car in the morning. Took it to the service centre , on investigation turned out to be a faulty expansion valve , this along with dryer was replaced under warranty, so far its working ok
Hello, i am facing the same issue just to confirm is it during the cold start? And the ac starts throwing cool air only after a minute or so and when the car starts moving, Is it the same with you? And it takes longer for the ac to start throwing cool air if the car is stationary.
Tanveer_2558 is offline   Reply With Quote
Old 20th June 2015, 01:13   #2012
VW2010's Avatar
Thanked: 2,124 Times
Default Re: Volkswagen Jetta : Test Drive & Review
Tanveer,
Take it to the service center. if you are under warranty, get the complete compressor and drier replaced if possible.
They are one of the weak areas of jetta.
VW2010 is online now   (1) Thanks Reply With Quote
Old 20th June 2015, 01:47   #2013
Originally Posted by VW2010 View Post
Tanveer,
Yes my car is just around 9 months old, ill probably do that, i just hope the service center guys try to understand the problem atleast, since my last visit to them was because of the glovebox light not working and it took them 2 days to find the issue for it which eventually was a kaput fuse.
Old 20th June 2015, 08:19   #2014
Chethan B G's Avatar
Thanked: 1,093 Times
Arrow Re: Volkswagen Jetta : Test Drive & Review
Hi Tanveer,
I had a similar problem with my Jetta and it is rectified after AC solenoid replacement under warranty. This seems to be a common problem with Jetta. I heard that the Solenoid now has been modified and the new one after replacement works fine. Please get your's replaced. All the best!
For details: http://www.team-bhp.com/forum/test-d...ml#post3586354
Chethan B G is offline   (1) Thanks Reply With Quote
Old 20th June 2015, 21:13   #2015
Thanked: 79 Times
Hi tanveer, yes my problem was the same
hubolt is offline   (1) Thanks Reply With Quote
Old 21st June 2015, 01:49   #2016
Originally Posted by Chethan B G View Post
Hi Tanveer,
Thank you very much for the info, i have a checkup for the car comingup so ill get it done that time, i just hope the service center is aware of this issue.
Thank you, seems to be a common problem then.
Old 21st June 2015, 09:47   #2017
Thanked: 41 Times
Do we not get an alert, some sorry of flashing light of the battery is low?!
RoadTrippin is offline   Reply With Quote
Old 21st June 2015, 13:42   #2018
Thanked: 79 Times
Normally, esp and abs sensors failure starts showing every few days intermittently , those are the battery charge low signs normally could also be sensor issue , but intermittent fault explained above usually indicates battery issues , funny how such a sophisticated car has to use such unrelated Telltale's to warn of pre eminent battery failure that too to be learnt from user experience
Old 21st June 2015, 17:52   #2019
VW2010's Avatar
Its a little more sophisticated and cost inefficient to build a true battery indicator. The reason why you are seeing glow all over the dash board is because of the indifferent voltage received by these sensors which in a way is the easiest way to identify battery failure.
These batteries actually get charged to full while driving, its only the discharging pattern determines if they are kaput. They simply discharge super fast.
I think it has simply got to do with the cost involved in investing on getting the battery indicator which is used once every 3-4 years and it doesnt make any practical sense to have one.
VW2010 is online now   Reply With Quote
Old 22nd June 2015, 08:17   #2020
Thanked: 79 Times
The problem is this fault does not oÁcur as infrequently as every 3 to 4 years though ideally I agree it should , also if the sa can find the fault thought their diagnostics , that means the fault code of that nature is being recorded all that has to be done is report it on the screen or keep the battery light on or flash it with a bell , I don't think to do such such an investment is prohibitive , also battery failure advance warning is quite useful and important
Old 22nd June 2015, 08:55   #2021
Thanked: 11,303 Times
To be fair, i was warned that the battery will die soon. The voltage was a little lower than normal.
when it did happen, i did not panic, merely got a new battery and put it in
ajmat is offline   (1) Thanks Reply With Quote
Old 22nd June 2015, 16:06   #2022
Thanked: 152 Times
Not sure of Jetta but in Octavia it shows the status of the battery, below is the pic, in Octavia press and hold the trip set button to get this info.
SOC = state of charge
Volkswagen Jetta : Test Drive & Review-20150622_140655.jpg
B747 is offline   (2) Thanks Reply With Quote
Old 22nd June 2015, 21:31   #2023
adi_petrolhead's Avatar
Thanked: 1,091 Times
Again it's very important to check the battery under load as I have experienced this just very recently. VAG service centers have a special device to check out the battery. They simply connect it to the terminals and press a button, out comes a receipt that reads the fault in the battery. That's it. That small bit of paper decided that my Octavia's battery had failed and they replaced it within no time.
adi_petrolhead is offline   Reply With Quote
Old 7th July 2015, 09:25   #2024
tilt's Avatar
Thanked: 569 Times
Default Jetta owners - is your odo accurate?
I first noticed that my new Jetta showed an increase of ten+ kms in the distance driven door-to-door Bangalore to Madras when compared to my old i20.
Then, two days ago, I decided to verify it. I used VW's own app to trace my route over a few rides and compare it with what the odo showed.
The app's GPS tracker showed 12.15 km and the odo showed 13.5; the app showed 10.91 and the odo showed 11.7; and the third trip the app showed 26.43 kms and the odo showed 28.3.
And as I mentioned in the beginning of this post, my BLR-MAA distance showed around 360 kms instead of the 343 shown by my i20.
I want to know if other Jetta owners have noticed something similar.
Some of the other T-BHPers I spoke with thought it might have to do with any tyre size changes, but I am running the original wheels and tyres the car came with.
Yes, I agree that the difference does not seem to be significant, but I am unable to find a steady pattern to the difference, and was wondering how I may have this corrected.
As to WHY I would like it corrected, it would show a higher usage of the car over time, and also the fuel-consumption figures would not be accurate; not to mention the speedo also being optimistic.
Thanks and cheers
tilt is offline   (1) Thanks Reply With Quote
Old 8th July 2015, 01:25   #2025
VW2010's Avatar
Could be a sensor issue or sensor calibration issue?
Did you check with VW.
Also any mods to the rims or tyres
Volkswagen Polo : Test Drive & Review GTO Official New Car Reviews 4028 13th August 2018 17:02
Volkswagen Jetta Comfortline 2.0 CrTDI : Test Drive And Initial Report sammycoolster Test-Drives & Initial Ownership Reports 15 13th November 2012 00:48
Volkswagen Jetta 1.6 Litre Petrol (Trendline) Test Drive, Review & Photos Karizma Fan Test-Drives & Initial Ownership Reports 40 18th February 2010 20:45
