Old 3rd April 2017, 16:18   #2851
vishy76's Avatar
Thanked: 1,445 Times
Default Re: Volkswagen Jetta : Test Drive & Review
Originally Posted by harryputtar View Post
BTW for the service, are there some frills I should avoid, like AC disinfectant, wheel balancing etc etc?
Avoid the A/C disinfectant. Many Jetta owners including me have ended up with broken A/C vents post this.
But do not skip changing the pollen filter for the A/C. There is a very good chance that it needs changing along with the other consumables such as oil and air filters.
Suspension lubrication should be applied. I have felt a marked difference in ride post this and suspension travel is much smoother.
Changing these consumables along with the oil itself and coolant will ensure that your FE is back to normal. Low FE is a sign of a blocked air filter. I usually trust the service centre with the wheel balancing and alignment but if you have a trusted workshop for the same, get it done there. Will be much cheaper.
vishy
vishy76 is offline   (3) Thanks Reply With Quote
Old 10th April 2017, 12:38   #2852
prash26's Avatar
Thanked: 16 Times
Finally bought the Jetta Silk Blue, HL AT.
The feeling of finally fulfilling a long awaited dream is unexplained.
She is an absolute beauty, from the outside as well as from the inside.
23.75 On Road,
extended warranty will be purchased later
Normal comprehensive insurance
An absolute beauty of a car, I was very apprehensive about the color, the more I saw the car in silk blue, the fonder I grew.
It has been a month now, a month of bliss
prash26 is offline   (3) Thanks Reply With Quote
Old 13th April 2017, 06:13   #2853
RajaTaurus's Avatar
Thanked: 351 Times
Congratulations. Welcome to Silk Blue Club. Sure head turner she is. Enjoy crunching Safe, luxurious and powerful miles.
RajaTaurus is offline   Reply With Quote
Old 13th April 2017, 11:10   #2854
Thanked: 130 Times
23.75 On Road,
Congratulations! You owned one that I am still dreaming about .
Are still new cars available in stockyard? Because they have already discontinued production.
sups is offline   (1) Thanks Reply With Quote
Old 13th April 2017, 12:25   #2855
prash26's Avatar
Thanked: 16 Times
Yes
when i last enquired,
VW Mysore has a Comfortline 2015 manufacture in silk blue in Mysore
VW Whitefield in Bangalore had a HL dsg silver 2015 manufacture
VW Palace Cross in Bangalore had HL manual 2015 manufacture
prash26 is offline   (1) Thanks Reply With Quote
Old 13th April 2017, 12:32   #2856
Thanked: 11,076 Times
Yes
Those are a bit old for stock. They must be demo cars
Old 13th April 2017, 12:52   #2857
prash26's Avatar
Thanked: 16 Times
No
They are not demo cars
atleast the one in whitefield bangalore and mysore is not
In Mysore they have a HL DSG silk blue demo car
generally , the top end dsg is used as demo cars, not the manual versions.
prash26 is offline   Reply With Quote
Old 14th April 2017, 15:23   #2858
Mission_PGPX's Avatar
Thanked: 300 Times
First of all congratulations for accomplishing your dream.
I suggest you change your insurance from comprehensive to zero dep ASAP.
you never know when you run out of luck...
Mission_PGPX is offline   (1) Thanks Reply With Quote
Old 14th April 2017, 16:31   #2859
ethanhunt123's Avatar
Thanked: 324 Times
Second that. Jetta parts are expensive and totally makes sense to buy Zero dep
ethanhunt123 is offline   (1) Thanks Reply With Quote
Old 15th April 2017, 10:20   #2860
Thanked: 293 Times
+1.
I suggest to include consumable & hydrostatic lock addon as well
Consumables are expensive for Jetta as well. Hydrostatic lock addon is a must for German cars in most parts of our country.
bhavik.1991 is offline   Reply With Quote
Old 15th April 2017, 13:44   #2861
Epic's Avatar
Thanked: 424 Times
Battery kaput or something else?
So my 2015 Jetta TDI AT has acted funny this morning. Here is he series of events:
- Unlocked the car and sat inside.
- Turned on the ignition. Everything normal.
- Tried to start the car and the power totally shut off. I though this would be a loose connection at the battery terminal but everything was ok there.
- With the key still turned to the 'ignition ON' position, I noticed the MID come on (all other lights on the dash were off) and the roof light slowly flicker a bit and come on.
- Tried to start the car again and all power shuts off.
Called up VW and they said it could be the battery that has failed.
Now, I have been using the car at least for 3 days a week(I alternate between my Polo & Jetta) and drove the Jetta just yesterday for a good 40 kms and so surprised that the battery is totally drained out today.
Is this just a freak battery cell failure issue or could there be more to it?
Epic is online now   Reply With Quote
Old 15th April 2017, 14:30   #2862
Thanked: 324 Times
Looks like battery fail. If it is not under warranty - just call your local Amaron dealer and get it replaced.
ethanhunt123 is offline   Reply With Quote
Old 15th April 2017, 16:09   #2863
graaja's Avatar
Thanked: 3,715 Times
This is a battery failure. I have experienced this twice. First the battery failed in about 15 months, and was replaced under warranty. Then the replaced one also failed again in just about 16 months, and I replaced it with Amaron. Details can be found in the below posts in my ownership thread.
First battery replacement (Platinum Grey VW Jetta 2.0 TDI Highline DSG comes home)
Second battery replacement (Platinum Grey VW Jetta 2.0 TDI Highline DSG comes home)
graaja is offline   Reply With Quote
Old 15th April 2017, 17:01   #2864
Epic's Avatar
Thanked: 424 Times
Thank you Ethan and Graaja for the inputs. Well one thing is for sure; the Varta OEM batteries have a ridiculously short life span - 02 years tops. My 2011 Polo 1.6 came with a Varta too which failed within 02 years of use. My 2015 Jetta has faced the same fate.
I had replaced the Varta in my Polo to Amaron and never had any issues till date. I guess I will have to do the same with the Jetta too.
@graaja - I noted that the Amaron battery is a little too big to fit in the battery case in the Jetta. Looks a bit shabby & out of place don't you think?
Old 15th April 2017, 17:04   #2865
graaja's Avatar
Yes. The battery is a little long to fit the OE cover, and the green color definitely makes it look out of place. But I think as it is inside the engine bay and not visible, it is a small price to pay for the reliability.
Can't have that "getting stranded" situations often due to those bad OE batteries.
Volkswagen Polo : Test Drive & Review GTO Official New Car Reviews 4018 10th July 2018 10:55
Volkswagen Jetta Comfortline 2.0 CrTDI : Test Drive And Initial Report sammycoolster Test-Drives & Initial Ownership Reports 15 13th November 2012 00:48
Volkswagen Jetta 1.6 Litre Petrol (Trendline) Test Drive, Review & Photos Karizma Fan Test-Drives & Initial Ownership Reports 40 18th February 2010 20:45
