Old 15th June 2017, 13:51   #2926
shivasuma's Avatar
Thanked: 272 Times
Default Re: Volkswagen Jetta : Test Drive & Review
Hi all,
I have 2012 CL Jetta. I was thinking about changing the head unit to a touchscreen unit with navigation. Which is the best plug & play unit? Thanks in advance.
shivasuma is offline   Reply With Quote
Old 15th June 2017, 15:55   #2927
Thanked: 2,119 Times
Infractions: 0/1 (5)
Check this thread there are some good information about the options. RCD510, DS811 are couple of good options to start with.
DS811 is touch and go. If it works it works else its a PITA to get help and support and updated software. The Chinese company can give competition to customer service of all Indian Companies.
VW2010 is offline   (1) Thanks Reply With Quote
Old 15th June 2017, 16:53   #2928
shivasuma's Avatar
Thanked: 272 Times
I think you also have a CL, but I see in your thread that your car came with a RCD 510 unit. Mine came with a vary basic unit (probably RCD 310). I would like to order the DS 811 but really nervous if it doesn't work. Let me think about it. Thanks.
Old 15th June 2017, 17:02   #2929
Gannu_1's Avatar
Thanked: 10,222 Times
Check out the RCD 330G Plus. Cheap, has a better resolution display, capacitive touch works as good as a smartphone, has a built in Bluetooth module. The climatronic and OPS display works.
Downside - does not show the music info, contacts on the cluster's MFD.
Gannu_1 is offline   (3) Thanks Reply With Quote
Old 16th June 2017, 17:16   #2930
RajaTaurus's Avatar
Thanked: 339 Times
Folks, I need advise on after market pedal covers. It has been 10 months and I am not fully connected with stock pedal covers of my Jetta. Where can I get Aluminium or steel covers?
RajaTaurus is offline   Reply With Quote
Old 16th June 2017, 18:38   #2931
Gannu_1's Avatar
Aliexpress China, eBay Germany/UK, ECS Tuning US.
What's wrong with the stock pedal inserts?
Gannu_1 is offline   (1) Thanks Reply With Quote
Old 17th June 2017, 12:36   #2932
Chethan B G's Avatar
Thanked: 697 Times
Arrow Re: Volkswagen Jetta : Test Drive & Review
No. BCM is different from CAN Gateway (some BCMs come with integrated CAN gateway). It is located under the steering column and is a very difficult piece of controller to access.
Do a VCDS autoscan and export it to a text file. Attach the file. BCM information should be there in the report.
Dear Ganesh,
VCDS autoscan report does not show the BCM separately..
Sunday,19,February,2017,17:50:31:04550
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 15.7.0.2
Data version: 20150820
www.Ross-Tech.com
VIN: WVWE13164DA550521 License Plate: KA51ME5111
Mileage: 74320km-46180mi Repair Order: 19/02/2017
Chassis Type: 16 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 2E 42 44 46 52 56 62 72 77
VIN: WVWE13164DA550521 Mileage: 74320km-46180miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (J623-CLCB) Labels: 03L-906-018-CFF.clb
Part No SW: 03L 906 018 GH HW: 03L 907 309 R
Component: R4 2,0L EDC H25 7816
Revision: 42H25--- Serial number: 00000000000000
Coding: 00190012042500080000
Shop #: WSC 00047 000 00091
ASAM Dataset: EV_ECM20TDI01103L906018GH 003004
ROD: EV_ECM20TDI01103L906018GH.rod
VCID: 76FBF1C398C7C43235FCC0D-8022
No fault code found.
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
Component: ESP MK60EC1 H31 0152
Revision: 00H31001
Coding: A63B40F8092700FA651002E6901A0082251800
Shop #: WSC 00047 123 12345
VCID: 7DE9EEEFBDF197EA7486B79-8028
Address 08: Auto HVAC (J301) Labels: 3C8-907-336.clb
Part No SW: 7N0 907 426 BG HW: 7N0 907 426 BG
Component: AC Manuell H20 0505
Revision: 00001018
Coding: 0010002002
ASAM Dataset: EV_ACManueBHBVW36X A01010
ROD: EV_ACManueBHBVW36X_SE36.rod
VCID: 7AE3E5F3ACDFA05251A494D-802E
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 5K0 937 086 M HW: 5K0 937 086 M
Component: BCM PQ35 M 021 0068
Revision: BC021001
Coding: 26000A38882D00C040680080150081E40571008050A0816064 8060000040
Shop #: WSC 00066 123 12345
VCID: 3E6B29E3F0774CF22D0C78D-806A
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 300113 05 54 0403
Coding: 03300A
Address 10: Park/Steer Assist (J446) Labels: 1Q0-919-475.clb
Part No SW: 5C6 919 475 HW: 7E0 919 475 A
Component: PARKHILFE 8K H10 0005
Revision: -------- Serial number: 84091227000246
Coding: 108001
ASAM Dataset: EV_EPHVA18VW3610000 001003
ROD: EV_EPHVA18VW3610000.rod
VCID: 71F1C2DFF1A9E30AE00E0B9-8024
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 5C0 959 655 C HW: 5C0 959 655 C
Component: AirbagVW10 013 0613
Serial number: 003G6M087JRM
Coding: 00003241
Shop #: WSC 00047 000 00000
ASAM Dataset: EV_AirbaVW10SMEVW360 A01014
ROD: EV_AirbaVW10SMEVW360_SE36.rod
VCID: 32730DD3342F9812D994FCD-8066
Crash sensor for side airbag; driver side:
Subsystem 1 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Fahr.V H02 ----
Serial number: 3572MSME6F2F6475ZZZA
Crash sensor for side airbag; front passenger side:
Subsystem 2 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Beif.V H02 ----
Serial number: 3582MSME7D2C6475ZZZ7
Crash sensor for side airbag; rear; driver side:
Subsystem 3 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Component: S.Sens.Fahr.H H02 ----
Serial number: 3516KSME79143B20ZZZQ
Crash sensor for side airbag; rear; passenger side:
Subsystem 4 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Component: S.Sens.Beif.H H02 ----
Serial number: 3526KSME09093B20ZZZO
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 1K5 953 521 AK HW: 5K0 953 569 B
Component: LENKS.MODUL 016 0140
Revision: FF010041 Serial number: 20130312201188
Coding: 0082140000
ASAM Dataset: EV_SMLSNGVOLWSXS A01004
ROD: EV_SMLSNGVOLWS.rod
Multi Function Steering Wheel Control Module:
Subsystem 1 - Part No SW: 5K0 959 542 C HW: 5K0 959 542 C Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H31 0037
Coding: 820000
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 5C6 920 872 A HW: 5C6 920 872 A
Component: KOMBI H07 0705
Coding: 171B01
Shop #: WSC 00047 123 00091
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04716
ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
VCID: 2B4D10B71305C9DA9AD2091-807E
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 AN HW: 7N0 907 530 AN
Component: J533 Gateway H56 1642
Revision: H56 Serial number: 101013F1001644
Coding: 350003
Shop #: WSC 00079 790 45725
VCID: 7CEFE3EBA6EB9EE243B8825-8028
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H07 0705
Serial number:
Coding: 000000
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03709
ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
VCID: 6AC3D5B3DC7F10D2A14444D-803E
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 F HW: 5N0 035 342 F
Component: SG EXT.PLAYER H18 0546
Revision: A1001003 Serial number: 7663782629
Coding: 010100
VCID: 2A4315B31CFFD05261C404D-807E
Address 42: Door Elect, Driver (J386) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 561 959 701 A HW: 3C0 959 793 C
Component: TUER-SG FT 002 0515
Revision: 12110009 Serial number: 0006112446
Coding: 0012B7
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_TSGFPQ35BRFVW46X A04001
ROD: EV_TSGFPQ35BRFVW46X.rod
VCID: 1C2FC36B46AB3E62E378E25-8048
Slave Driver:
Subsystem 1 - Part No SW: 3C0 959 704 B HW: 3C0 959 794 C Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 008 1508
Serial number: 00000007546407
Coding: 000290
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 69 3305
Revision: 00H22000
Shop #: WSC 02069 000 90108
VCID: 37653CC7DF4D71BAEE4AB51-8062
Address 52: Door Elect, Pass. (J387) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 561 959 702 A HW: 3C0 959 792 C
Component: TUER-SG BT 002 0515
Revision: 14110009 Serial number: 0006241262
Coding: 0013B6
ASAM Dataset: EV_TSGBPQ35BRFVW46X A04001
ROD: EV_TSGBPQ35BRFVW46X.rod
VCID: 1D29CE6F5DB1376A1446979-8048
Slave Passenger:
Subsystem 1 - Part No SW: 3C0 959 703 B HW: 3C0 959 795 C Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 008 1508
Serial number: 00000007526057
Coding: 000290
Address 56: Radio (J0503) Labels: 5M0-035-1xx-56.clb
Part No SW: 5K0 035 190 B HW: 5K0 035 190 B
Component: Radio RCD510 005 0236
Revision: 00000001 Serial number: VWZ1Z3N1969320
Coding: 01000400040006
VCID: 245FFB8B7EDB06225B085A5-8070
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 7P6 035 730 J HW: 7P6 035 730 J
Component: TELEFON H15 3200
Revision: 1B001001 Serial number: 00007663656577
Coding: 0A10000000010101
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA.rod
VCID: 39613AFFE9596B4A185EA39-806C
End-------------------------(Elapsed Time: 03:02)--------------------------
Chethan B G is offline   Reply With Quote
Old 17th June 2017, 15:52   #2933
RajaTaurus's Avatar
Thanked: 339 Times
I would try Aliexpress. Actually I am used to slide my shoe over the pedals while moving from Brake to Accelerator (and clutch to dead pedal) in most of my previous rides and these rubber inserts are resisting that. Metal inserts are slippery if the footwear is wet or muddy, but I feel more comfortable with that rather than sticky pedals.
Old 18th June 2017, 10:15   #2934
Gannu_1's Avatar
Originally Posted by Chethan B G View Post
Dear Ganesh,
It does.
This is the BCM:
Revision: BC021001
Coding: 03300A
Do check Aliexpress. The pedals are not OEM and are made by third party manufacturers, the fit may not be perfect and you'll need to use some sort of glue to hold them in place, judging by the reviews of pedals sold for other cars. But customers are happy as they are a lot more cheaper compared to the original pedals which retail for close to 200 USD.
Do note that you'll need to check how to remove the accelerator pedal off the organ type pedal assembly. It may not be as easy as prying and removing the original one and inserting the replacement. Please check.
Old 19th June 2017, 09:35   #2935
Motoringlover's Avatar
Thanked: 179 Times
Team - Great thread - Just checking if any one has any experience in changing Fog lamp bulbs, i am looking for the type of bulb used which i can replace with an LED. I have 2012 Comfortline TDI.
Motoringlover is offline   Reply With Quote
Old 19th June 2017, 09:41   #2936
Mission_PGPX's Avatar
Thanked: 265 Times
One more thing to check is what BCM is installed.
Lastly, AFS is a totally independent module. You can actually install the BiXenons without AFS and just calibrate the leveling using the leveling screws. With this you will lose on the automatic leveling and dynamic cornering. But you can always install AFS later and add the feature.
oh god, now i see why there is so much difference between treandline and highline when buying new. All of a sudden that 3 lac difference seems very much justified for the features offered.
Mission_PGPX is offline   (2) Thanks Reply With Quote
Old 1st July 2017, 18:55   #2937
Thanked: 84 Times
It's been long time... all good with my Jetta... well until last week...
Both my wiper-blades came off the metal arm within 30mins when I was driving in Kerala last week, and it was raining cats and dogs... the left one flew off when I was at a speed of 20Kmh (now you know what's rain in Kerala)... I managed to drive with right one (driver side) another 30Kms until I reached my Dad's place... and I realsied the right one also had broken (the rubber). Not sure how the left one flew away - maybe someone tried to steal it and was loose fit, or the clips gave up.
I couldn't get either a OEM or Bosch in Palakkad. So I had to drive back with left wiper-hand wrapped in thick cotton. Tried couple of places in Whitefield, and none of them had the Jetta fit Bosch model. One guy offered Hella for Jetta which comes with adaptors for various cars/models, but that didn't fit Jetta (he agreed to take it back).
One of the worst things I have experienced on the Jetta is the quality of the wiper...
Finally, I could source wipers from Amazon and replace them. These wipers are exact fit for the Jetta and the problem is completely resolved.
Link: http://www.tricoproducts.com/Drivers...nce/TRICOForce
Link: http://www.amazon.com/Trico-25-190-F.../dp/B005WTPBZ8
Chethan, the Trico model doesn't seem to fit mine (2016 Jetta), at least by the looks of the clips. No photo of the adaptors. i don't want to be the in same state as with Hella today - had 6 adaptors but all of them were 2-3 mm wider than the OEM model.
What are my options ? OEM, was suposed to be sub-standard, so want to go for Hella or Bosch. Anyone have specific details what I can buy ?
sunsbhp is offline   Reply With Quote
Old 1st July 2017, 20:35   #2938
If you have the clip that will retain the rubber, you can simply swap the rubber from a hella or bosch into the OEM wiper frame itself. Thats what i have done and will continue to do.
Its a 15 min DIY with effort and 15 minute without much effort.
VW2010 is offline   Reply With Quote
Old 2nd July 2017, 10:20   #2939
Thanked: 697 Times
Trico model suits Jetta MK6. If you are still in doubt, please post a picture of your wipers and I will confirm. 😊
Old 4th July 2017, 15:29   #2940
Thanked: 254 Times
Hello folks,
I have seen many Jettas MK6 (pre-facelifted) with the tail light part which is integrated into boot not working (usually either side). I always thought the owner might be unaware of it hence didn't get it fixed however couple of days back, I became the victim myself.
Couple of days back, MID showed error "Please check driver side tail light" & a yellow warning symbol popped up in the console as well. (I will upload images soon). It appeared after I drove her through the water puddle of approx 5"-6" deep & 3-4 feet in the length in reverse. (Coincidence?)
Has anyone faced the similar issue? My SA told me over telephone that most probably it won't be covered under extended warranty :( If not, what repair cost I am looking at?
bhavik.1991 is offline   Reply With Quote
Volkswagen Polo : Test Drive & Review GTO Official New Car Reviews 3998 15th December 2017 13:37
Volkswagen Jetta Comfortline 2.0 CrTDI : Test Drive And Initial Report sammycoolster Test-Drives & Initial Ownership Reports 15 13th November 2012 00:48
Volkswagen Jetta 1.6 Litre Petrol (Trendline) Test Drive, Review & Photos Karizma Fan Test-Drives & Initial Ownership Reports 40 18th February 2010 20:45
