Old 25th March 2014, 15:22   #1261
graaja's Avatar
Thanked: 3,741 Times
Default Re: Volkswagen Jetta : Test Drive & Review
Originally Posted by akshay1234 View Post
Yes he certainly misinformed you. The light he was pointing to possibly took care of the cornering at low speed, so maybe the fogs do not do the low speed cornering in the Jetta.
You got it perfectly right. Found a video in youtube where the owner demonstrates the cornering lights. The light that the SA pointed to me is actually for low speed cornering, not the fog lamps.
BTW, pardon my persistence. Being an engineer, I don't get sleep till I get the complete answer to a question
graaja is offline   Reply With Quote
Old 25th March 2014, 16:38   #1262
me_navin's Avatar
Thanked: 27 Times
The pattern does change, but its really not very noticeable. My vRS has AFS and I've thoroughly driven Superbs, etc with AFS2 and believe me noticing the beam change is difficult, its just so subtle.
Slightly OT, but is there any difference in the AFS setup of the new superb and the octavia ? Did not get a reply for this on the Superb thread . So incase you know , it would be helpful. The reason I ask is because when you turn on the high beam in the new superb a pair of halogens light up along with the xenons. So is it actually a bixenon setup?
me_navin is offline   Reply With Quote
Old 25th March 2014, 18:28   #1263
graaja's Avatar
What is the trim of your Superb? IIRC, only the elegance trim has AFS.
Edit: checked the Skoda site. Only the elegance trim has bi xenons with AFS. The ambition only has halogen projectors with manual levelling.
Old 25th March 2014, 18:54   #1264
dkaile's Avatar
Thanked: 4,476 Times
Let me try to explain this to you. The term Bi-Xenon is confusing. Bi-Xenon is basically marketing jargon for a projector headlight that activates a solenoid when the High beams are activated. The solenoid in the projector moves downwards, allowing for more light in the projector bowl to actually escape through the magnified glass. This basically provides a "high" beam even though it is still the same beam. This is how it is in the Superb and the new Octavia. AFAIK in the Laura & Jetta the Xenon works only for low beam.
A lot of cars have Halogen high beams to supplement the Xenon/HID or to act as the sole high beam (Laura/Jetta). Xenon/HIDs are not very suitable as separate high beams since they have a longer warm up time and flashing them drastically reduces their lifespan. A lot of cars also have a halogen beam to complement the HID/Xenon with a solenoid (aka bi-xenon as in the Superb).
Hope that clarifies.
dkaile is online now   (1) Thanks Reply With Quote
Old 25th March 2014, 18:54   #1265
me_navin's Avatar
Thanked: 27 Times
I am talking about the elegance model. The website does say its a bixenon setup . The car I checked out was the test drive car . What confused me is that a pair of halogen lights next to the xenons turned on along with the xenons when in high beam . Any ideas?
Old 25th March 2014, 19:04   #1266
graaja's Avatar
The Elegance is indeed BiXenon with AFS. The halogen you saw should be the low speed cornering lamp which gets activated when the steering wheel is turned. Check out the video I posted a few posts earlier.
http://www.team-bhp.com/forum/offici...ml#post3398535 (Volkswagen Jetta : Test Drive & Review)
Did you observe something like this?
Old 25th March 2014, 21:39   #1267
me_navin's Avatar
Thanked: 27 Times
I saw the video. Mayb they do work as cornering lights. But I saw them come on ( both the left and the right) when the car was stationary and the steering kept at centre and only when it was on high beam.
Old 25th March 2014, 21:53   #1268
Thanked: 372 Times
Maybe the car was in the reverse gear.
H_Dogg72 is offline   Reply With Quote
Old 26th March 2014, 03:39   #1269
Akshay1234's Avatar
Thanked: 7,286 Times
The AFS is the same in both. Except like you mentioned the Superb has a pair of halogens too. So when the headlights are off, if you flash the lights only the halogens will come on. But when the headlights are on, the xenons go to high beam too and the halogens act as a filler (In Skoda terms).
Akshay1234 is offline   (1) Thanks Reply With Quote
Old 26th March 2014, 08:07   #1270
graaja's Avatar
Friends,
I plan to change the stock tires of the Jetta 2.0TDI immediately after taking delivery. Requirements are good grip, low road noise and durability. What are my options?
Please provide your inputs.
Old 26th March 2014, 09:08   #1271
iliketurtles's Avatar
Thanked: 1,055 Times
The Yokohama V550 AVS DB is what you're looking for since you'll want minimum road noise. I'm not sure how noisy the Michelin's are, but I wouldn't recommend my Pirelli P7's too since they can be slightly noisy at speed (in my opinion) and that would be a deal breaker for you.
Go for the Yokohama or Michelin, can't go wrong.
iliketurtles is offline   (1) Thanks Reply With Quote
Old 26th March 2014, 09:27   #1272
VW2010's Avatar
Thanked: 2,124 Times
Actually the stock tyres fit all that requirement. Mine has run around 32K and is sill going strong. The day when i hear it screeches while i take my office ramp i know its time to change them.
Very high speed noise will be there but at that speed noise is your last worry
Having said that check out the Michelin series 3ST. I was looking at this as my replacement tyres as well.
http://www.team-bhp.com/forum/tyre-a...hed-india.html (Michelin Primacy 3 ST Tyres launched in India)
http://www.michelin.in/Home/Products...imacy%203%20ST
Use this for tyre size options while changing
http://www.wheel-size.com/size/volkswagen/jetta/
I wanted to get a 225,50,R16 profile but not really researching at this point.
VW2010 is online now   (1) Thanks Reply With Quote
Old 26th March 2014, 10:23   #1273
graaja's Avatar
Thanks iliketurtles and VW2010. I will check the availability and pricing of Yokohama and Michelin 3ST with the local dealers and choose one of them. Hope they give me a life of at least 40K km.
I am not planning to upsize the tires as that would require some research time. For now, I am planning to stick to the stock size.
Old 26th March 2014, 18:33   #1274
Thanked: 164 Times
Are you keeping the same tire size and profile?
In any case, I'd recommend the Michelin primacy LC and Pirelli P7's. You should get between 5600-6000 per tire if you trade them in straight away. The Pirelli's should cost about 8300 per tire and the Michelin's about 9300.
I went for the Pirelli's. They're a good choice, although road noise at high speeds is slightly loud for my taste, although it is well within acceptable limits. I'm told the longevity of these tires is good and I can vouch for the performance. I'd recommend them as much as I would the Michelin's.
Do trade them in straight away, you'll get the best valuation for your tires.
Got the tyres upgraded to Continental & kept the same size 205/55 R16 and they are no nonsense tyres, having nice road grip and less noise which was a screamer in the Goodyear Eagle NCT5.
Got a very good offer from our regular tyre dealers and he did a buyback of old tyres at Rs.5000/-
Would suggest anyone that do not take the Goodyear Eagle NCT5 as it is a Hard tyre and makes a hell a lot of noise on road.
Go for the Continentals 205/55R16 91V CONTI PREMIUM 2 and they are a very good tyres which will run atleast for 35K - 40,000kms as per your usage.
gowda79 is offline   Reply With Quote
Old 26th March 2014, 19:04   #1275
graaja's Avatar
Thanks for the suggestion. I checked the "change my tyre" website, but could not find Conti Premium 2 in the size 205/55 R16. Will check with the local tire guy.
Any other users using Continental tires please provide your inputs.
Volkswagen Polo : Test Drive & Review GTO Official New Car Reviews 4028 13th August 2018 17:02
Volkswagen Jetta Comfortline 2.0 CrTDI : Test Drive And Initial Report sammycoolster Test-Drives & Initial Ownership Reports 15 13th November 2012 00:48
Volkswagen Jetta 1.6 Litre Petrol (Trendline) Test Drive, Review & Photos Karizma Fan Test-Drives & Initial Ownership Reports 40 18th February 2010 20:45
