Old 5th June 2016, 21:21   #1561
sgiitk's Avatar
Thanked: 3,792 Times
Infractions: 0/1 (5)
Default Re: Honda Brio : Test Drive & Review
Mine was the first AT in Kanpur, I think 2012. That also did not have any underhood insulation. So they do not install it. I think my d-i-l's Amaze (two years old, is also not having any of this insulation. Remember both the cars are the V versions.
Old 5th June 2016, 22:02   #1562
aerohit's Avatar
Thanked: 600 Times
Originally Posted by sunnyman_46 View Post
Hi All,
I am heading for my 30,000km/3 years service next week. Please advice what all needs to be checked or taken care. I have sqeaking sound from my brakes and clutch too is little hard.
SUNNY
Go for clutch master cylinder oil bleeding / brake oil bleeding
Your brake pads may also need replacement
Oil Filter/Engine oil / Air filter chance
Optional: gear oil change
Optional: Throttle body cleaning
Check the condition of spark plugs.
Nothing else. You can check more details in owners manual
aerohit is offline   Reply With Quote
Old 5th June 2016, 22:27   #1563
reignofchaos's Avatar
Thanked: 1,185 Times
After 35000 odd km, I bid goodbye to my 2011 VMT brio last week. Nothing really to complain about other than a few rattles here and there due to iffy build quality. Brakes lasted 18000 km and after 35k, the clutch started feeling a bit weak. Parts in the brio do not have the same longevity of the larger Hondas.
Old 5th June 2016, 22:59   #1564
Thanked: 26 Times
My Brio's IRVM has sort of gotten free and changes it's position whenever i go over any broken roads. Consulted the SA and he mentioned that it needs to be replaced and is not covered under Extended warranty. Any idea if SA is lying or not?
SpoiledBratt is offline   Reply With Quote
Old 6th June 2016, 07:41   #1565
sgiitk's Avatar
He is probably right. Are you sure you cannot tighten it a bit in the socket.
sgiitk is offline   (1) Thanks Reply With Quote
Old 6th June 2016, 08:24   #1566
aerohit's Avatar
Thanked: 600 Times
Mine daily city drive for office commute is a Brio, almost 1 year old.
So far - ZERO rattles (may be because I did invisible rattle proofing the day I bought it, which I do in every car - few minutes of inconspicuous one time effort here and there)
Since it has hydraulic clutch, one must replace hydraulic fluid every few years.
aerohit is offline   (1) Thanks Reply With Quote
Old 6th June 2016, 13:52   #1567
Viju's Avatar
Thanked: 1,634 Times
Genuinely curious to know your rattle-proofing method!
Viju is offline   Reply With Quote
Old 6th June 2016, 15:03   #1568
sgiitk's Avatar
Our experience with Honda cars has been the same - four in the family Civic & brio for myself and City and Amaze for my son and his wife.
Old 6th June 2016, 15:48   #1569
Thanked: 26 Times
No it cannot be further tightened. SA told that further tightening may break it.
Old 6th June 2016, 20:16   #1570
Thanked: 251 Times
Hello
Can someone comment about the Aircon of the Brio, I recently bought a Brio purely for within city runs last month and when I compare the air conditioner performance with my 2010 Honda city it feels weak. In fact my first service will be due now and I am thinking if this is normal or I should bring it to my dealers attention.
Other than that its a wonderful little car, the buying experience with the Honda dealer however was terrible at best. Had it not been for knowledge and information available on T-BHP they would have shoved a 14 month old vehicle down my throat.
And we say VAG group sales is bad.
manishkapadia is offline   Reply With Quote
Old 7th June 2016, 11:09   #1571
arindambasu13's Avatar
Thanked: 129 Times
Originally Posted by manishkapadia View Post
Hello
Hi Manish, the aircon of Brio is indeed quite weak in my experience. I own a Brio and a Swift. On a typical hot summer day, the Brio takes ages to cool down the cabin sufficiently, while in the Swift, its a chiller of an AC, and within hardly a couple of minutes, the cabin is chilled. This is a known drawback of the Brio. The large glass area also allows lot of sunlight to come in and on a sweltering summer day, this is not very helpful either.
arindambasu13 is offline   (1) Thanks Reply With Quote
Old 7th June 2016, 12:11   #1572
gpa
gpa's Avatar
Thanked: 274 Times
The Honda City has a larger engine and a slightly larger air-con compressor as well which enables better cooling. The Brio's compressor is smaller and has to cool a relatively larger glass area and hence you feel the perceptible difference.
Top Tip: Switch on the a/c soon as the engine is warmed up and don't wait for the car to become warm before switching on the a/c. This will keep the cabin temperature at a very comfortable level with the fan speed set on 2/3.
Having used the Brio over the past four summers, I will agree that if you leave the car baking in the sun, it will take a while to cool the cabin owing to the large glass area. However, once the cabin cools, the temp is very comfortable. I have a digital probe thermometer that I've used to measure the in-cabin temp at the back seat after having baked the car in the sun. With an ambient temperature of over 35 C in Bangalore last month, the in-cabin temperature was around 22 C after running the a/c for about 30 mins.
Top Tip: I've noticed that keeping the a/c condenser clean does wonders to the cooling efficiency of the system. There are proprietary foam cleaners that you can spray-on and rinse off that will enable you to keep the a/c system in top shape.
Old 7th June 2016, 17:03   #1573
Thanked: 251 Times
I will probably use some film to keep heat out. However for rear glass I am not sure if film can be attached on the glass that has glass heating system installed to remove condensation. Ideas anyone ?
Since our cars are parked in open so yes they do get heated quite a lot. The summer this time is not mild either. Need to keep the blower on 3 to be comfortable. This is unlike my City where its impossible to sit with AC on full even on blower at 2 as it chills to the bone. So I was just surprised how different the brio ac is from the city. I guess I didn't pay attention to the air conditioning at time of taking trial on friends car.
Old 19th July 2016, 21:24   #1574
sunnyman_46's Avatar
Hi All,
I just fitted my Brio with Bosch Symphony Wind tone horn which I feel is a very good mod to my ride.
I also upgraded my stock headlights with Osram 130/100 off road, Now it is really bright and visible @ night.
sunnyman_46 is offline   Reply With Quote
Old 22nd July 2016, 11:53   #1575
Scaryskodamenon's Avatar
Thanked: 35 Times
Hi everyone, can someone suggest a good head unit for my Brio AT. I would like to keep my expenses at the lower side of 12 to 15 thousand. I intend to keep the stock speakers as well as this car belongs to my wife and is mainly used for short city runs. The idea behind is to integrate the existing reverse camera visual to the dashboard fitted unit and to add Bluetooth telephone. In the process, I hope this would give something to cheer about, otherwise to a lackluster interior of Brio.
Scaryskodamenon is offline   Reply With Quote
Got Brio'RED': Honda Brio VX Automatic getsurya Test-Drives & Initial Ownership Reports 42 6th June 2017 20:43
*SCOOP* Honda Brio DIESEL caught. EDIT: Only for next-gen Brio in 2017 kpzen The Indian Car Scene 377 6th September 2015 02:55
Stig gets Brio'ed! Red Honda Brio SMT (O) adityasiera Test-Drives & Initial Ownership Reports 61 16th March 2015 19:23
