Old 23rd July 2012, 11:55   #1471
samarjitdhar's Avatar
Thanked: 476 Times
Default re: Maruti Swift : Test Drive & Review
The Swift's braking issue is in the news now Forbes India Magazine - The New Maruti Swift's Brakes Don’t Work. What has been the experience of TBHP owners with the brakes of the new Swift? The article seems to give some lowdown on exactly what the problem is.
samarjitdhar is offline   Reply With Quote
Old 23rd July 2012, 14:12   #1472
funkyp's Avatar
Thanked: 92 Times
Originally Posted by samarjitdhar
The Swift's braking issue is in the news now Forbes India Magazine - The New Maruti Swifts Brakes Don’t Work. What has been the experience of TBHP owners with the brakes of the new Swift? The article seems to give some lowdown on exactly what the problem is.
I have a zdi and have found the braking to be adequate. Probably the brake boosters and wider foot print has to do with that.
The l and v variants have reported to have issues by many members earlier in the thread.
funkyp is offline   Reply With Quote
Old 23rd July 2012, 14:28   #1473
scofield's Avatar
Thanked: 131 Times
The ZDis dont have any braking issues as they are equipped with ABS however the problem is in the new LDi and VDi models, we have thread started by morabfibre about the issue he is facing with respect to the brakes in his new swift VDi.
scofield is offline   Reply With Quote
Old 23rd July 2012, 14:31   #1474
MutantX's Avatar
Thanked: 89 Times
guys, the issue quoted on forbes is more specific to petrol models (L, V & Z). The brakes becoming hard is a generic issue with all petrol models and it is attributed to insufficient vacuum produced at low speeds.
MutantX is offline   Reply With Quote
Old 23rd July 2012, 14:52   #1475
shivasuma's Avatar
Thanked: 272 Times
Don't the petrol and diesel models have the same brake system? It wouldn't be cost effective to have separate brakes for diesel and petrol (unless ofcourse either one of them is way more powerful than the other). I hope Maruti comes clean if there really is a problem with the brakes.
shivasuma is offline   Reply With Quote
Old 23rd July 2012, 15:02   #1476
MutantX's Avatar
Thanked: 89 Times
Petrol models use the vacuum generated by the engines for assisting the brake boosters. For Diesel cars, there is a separate vacuum chamber which produces vacuum to assist the brakes. Since the engine vacuum is not sufficient at lower rpms, the brakes become hard.
MutantX is offline   (2) Thanks Reply With Quote
Old 23rd July 2012, 16:11   #1477
MutantX's Avatar
Thanked: 89 Times
I have planned to change my new SWIFT's fog lamps. Can anyone confirm if the below can be directly swaped with my existing fogs?
2 Pcs H11 H8 68 SMD LED White Fog Headlight Light Lamp Bulb DC 12V NEW | eBay
Old 23rd July 2012, 17:23   #1478
Thanked: 3,944 Times
Confirm with seller whether it would fit in H8 type holder without any mods. Swift fog lamps are H8, H11 bulb has a slightly wider tab on the base.
Old 23rd July 2012, 17:25   #1479
HighOctane's Avatar
Thanked: 176 Times
Dear NEW Swift owners, the Braking issue reffered in above article is "weak brakes at ultra low speeds"/ "the brakes efficiency at half clutch while reversing or during bumper to bumper traffic drives" and not commenting about Brakes in normal speed.(This is about New 2011 car)
Swift is a gem of a car and IMO the swift owners are too happy with the car and its performance that they are not acknowledging the braking fault or they might have not experienced this half clutch drives with brakes pushing 2-3 times.
Note:Hope I am not offending swift owners.
HighOctane is offline   (1) Thanks Reply With Quote
Old 23rd July 2012, 19:58   #1480
MutantX's Avatar
Thanked: 89 Times
Sankar, Maruti's spare parts guy says, the new's fogs are H11 and hence I choose this particular size. Can you please confirm if the new swift's fogs are h8s or H11s?
Old 23rd July 2012, 20:16   #1481
Fog light bulb is H8. Its mentioned in the owners manual section 11 page 3 (11-3).
My old Astar had the same H8 bulbs in the fog lamps and to fit H11, which are 55W, in the fogs the steel tabs on the bulbs had to be ground off a little. Thats why asked you to confirm with the seller that the LED lights are indeed for H8 holder, otherwise it wouldn't fit.
Edit: H8 will fit H11 holder so the bulb in that link might be H8 so that it can cater to both H8 and H11 requirements.
Old 23rd July 2012, 20:24   #1482
MutantX's Avatar
Thanked: 89 Times
Thanks Shankar. I will check with the seller if he has H8 LED blubs. If yes, I shall buy them instead of these H11s.
Old 24th July 2012, 21:22   #1483
fuel_addict's Avatar
Thanked: 111 Times
It's baffling then why the problem should exist in the LDi and VDi variants too. In hindsight, I feel Maruti should have used the same brakes and brake booster from the older gen. Swift. Like they say "If it ain't broke, don't fix it". I had the old gen ZXi and can safely say that brakes were fantastic even after 5 years.
Let us know how it goes with the upgrade. Have you changed your headlamps too?
I plan to upgrade my headlamps and was quoted 1.15 K for Philips 100/90 bulbs with relay. This includes the installation charges.
fuel_addict is offline   Reply With Quote
Old 24th July 2012, 23:04   #1484
funkyp's Avatar
Thanked: 92 Times
hey where are you getting it done? MASS quoted me 2.5k and outside 1.2k. However, both warned that there might be issue with water getting in and damaging the system so am a little wary.
i was planning on getting xtreme visions if required.
Old 25th July 2012, 10:22   #1485
Thanked: 111 Times
This price was quoted by a shop in Milan subway at Santacruz West. Why would water get into the system? I haven't heard of this before. A blown fuse is more of a concern which is why a relay is a must.
My dealer (Sai Service) did not have the resources to do the headlamp upgrade. Asked me to get it down from outside. Assured me that warranty won't be void as long as a relay in installed and no wires are cut.
Maruti Ritz : Test Drive & Review GTO Test-Drives & Initial Ownership Reports 1605 8th February 2018 12:38
Maruti WagonR : Test Drive & Review Eddy Official New Car Reviews 687 15th January 2018 16:49
