Old 26th February 2012, 22:43   #2041
Ketan's Avatar
Thanked: 163 Times
Default Re: Mahindra XUV500 : Test Drive & Review
Avinash/Hemant,
I would suggest wait for XUV availability, the newer version should surely make sense if they are not going to increase the price further.
If I cannot wait, I would go with either Scorpio or Aria in that order. Scorpio is still a good car to move around, but thats not the discussion here. If you can, wait for XUV availability.
Ketan is offline   Reply With Quote
Old 27th February 2012, 11:47   #2042
m_upreti's Avatar
Thanked: 305 Times
Originally Posted by gubbi555 View Post
Hello,I did finally get an oppurtunity to do some decent off roading with my AWD variant.The going gets really effortless once the AWD lock is activated.Hill hold/descent is an added pro for amatuers.But you do tend to turn off hill descent after a while since it restricts your downward speed a tad bit too much!I did quite some steep ascents to and it just moved forward effortlessly whereas a normal two wheel drive vehicle would have to bear the grunt.Ground clearance is decent.Did not scrape the bottom or the mudflaps even once.But yes ofcourse,it was never extreme off-roading.Highway cruising is really chill in this vehicle.Even to this date after nearly 6 months of vehicle launch,it still is a head-turner on the roads.I was a bit skeptical about the initial criticism it received,but once you own it you'd easily overlook minor niggles if any.I should'nt be publicising this,but I did touch 190km/hr top speed on an empty strech on the NH-4 towards chitradurga.A special mention of the ESP which definitely is a lifesaver.During a trip in the ghat section,there was a bit of understeer at one curve but then the vehicle just got back to track with a little wobble upon hard braking.Thats when I realised the effect of ESP.Also you can anticipate every curve via GPS in forest sections too.I definitely feel its worth the extra price for AWD since we initially thought of goin for the 2WD variant.Btw,variant/colour was both decided in under 5mins while booking since we were one of the firsts and were'nt really sure of whats what!!Overall,pleasurable ownership experience I must say after 2 and half months and 8.5k kilometers.Cheers.
Thanks for the first insight on the poweress of the 4WD, and 190 KMH that's a wow (I have managed 158 on my Scorpio).
Lets hope the remaining niggles get ironed out in this round of deliveries and the next round of deliveries opens up fast.
m_upreti is offline   Reply With Quote
Old 27th February 2012, 13:09   #2043
Thanked: 17 Times
This is for the mods - can we please have a formal review of the AWD, now that it has been available for a while?
timetraveller is offline   Reply With Quote
Old 27th February 2012, 13:18   #2044
raj_5004's Avatar
Thanked: 2,036 Times
Lohit Urs managed to place his Mahindra XUV 500 on the podium on the 2012 Desert Storm championship.
The award for the most distinctive car in the Desert Storm easily went to the XUV 500s of Gaurav Gill and Lohit Urs thanks to its signature headlight arrangement.
Gaurav Gill won the fifth special stage despite having just two wheel drive and suspect brakes on his XUV 500.
Source - Rana wins 2012 Desert Storm as Urs finishes third - Hindustan Times
raj_5004 is offline   (3) Thanks Reply With Quote
Old 27th February 2012, 14:01   #2045
Thanked: 7 Times
Originally Posted by hemanth.anand View Post
Mahindra's loss is Tata's gain...
After thinking over a lot, When XUV draw was unlucky, bhpain avinashsg took a test drive of 3 other cars...Scorpo, Safari and Aria.
Others were not tested for various other reasons.
Now its down to these two:
I myself in almost same situation & zeroed down on Safari & Scorpio. But still in delimma whether to wait for some upcoming launches (Storme & Duster) or go ahead with the current options. I am also inclined more towards Safari
Misguided is offline   (1) Thanks Reply With Quote
Old 27th February 2012, 14:15   #2046
naveenchhillar's Avatar
Thanked: 31 Times
Has anyone got the refund ??
naveenchhillar is offline   Reply With Quote
Old 27th February 2012, 18:23   #2047
Shai100's Avatar
Thanked: 106 Times
The rear view camera / Reverse Camera fitment and Review for the XUV 500 W8
Lot of people I have seen on this forum have asked about rear view camera for XUV and not much info was found regarding the same, Hence here is my review on Fitment and utility of the rear view camera.
I had been to SKS on bannerghatta road for fitment of the rear view camera. I had called up earlier and fixed up an appointment with the accessories guy for 5pm. The moment I reached there, SKS guys were waiting with the camera for fitment. Initially I examined the camera and it felt of a good build quality. The camera comes in a sealed packing From a Mahindra vendor which is ISO approved as it said on the Box. The Cost of the camera is 3500Rs plus taxes, the Box contains one camera, Connecting cable and a drill bit for drilling the hole in the bumper. pls see my PIC 1 for the box info.
Pic 1
Mahindra XUV500 : Test Drive & Review-camerabox.jpg
At first the operator opened the rear side of the bumper. Its a small plate held by push on clips. After the plate removal the hole was drilled in the bumper using the drill bit which is of the exact size as that of the camera Dia.
Pic 2
Name:  Hole drill.JPG
Then the Left hand side Rear light cluster and the plastic above it were removed. It was fairly easy to remove. This was done as the harness for the camera is routed via the back light and taken in from behind the plastic that's above the light. The power source for the camera is taken from the light cluster (Back up lights).
Pic 3
Name:  lights removed for harness.JPG
Now the camera was fitted and the video out cable from the camera was routed from behind the plastic, inside and bellow the back and front scuffplates. The doubt I had was that the HU had to be opened out and the video-In RCA cable has to be connected but that was not needed! Apparently a cable is already running from company itself and its found behind the Front left interior plastic cover right bellow the Dash! So the operator just connected the camera cable to that cable . Of course there was no connector there he had to cut and join the cable and then put the insulation tape on it! This though crude I felt is much better than removing the entire centre console and re fixing it because i fell while doing so we always risk braking some or the other press fit plastic pins.
PIC 4
Name:  video connection.JPG
Now it was time for Flashing the Car infotainment. Here the Camera needs to be enabled in the infotainment screen and also my car was due for a Firmware update which was also done.
Pic5
Mahindra XUV500 : Test Drive & Review-flashing2.jpg
After all this and finally fixing back all the components back in its place my Macho had eyes behind too!! The camera works fabulously and its very useful while parking in tight spots! The system shows backing distance as usual. The visibility at night is also adequate. The camera Can be invoked from 2 ways one by putting the car in reverse and other by going to Car Info. Bellow are the snap shots of the two
From Car Info
By putting the car in reverse
Points to take care of,
1) Make sure the operators put back all the components back in its place
2) Throughly check the alignment of the camera as if its slightly tilted too it looks odd on the screen
3) Another Issue am facing is the camera is not sitting Flush with the bumper because of which its lifted up by about 20 degrees. This though not a majour problem need to be looked at.
I hope this post is usefull for all future XUV owners thinking of fixing the reverse camera!
All in all its been a good upgrade!
Ok I guess for some reason the pics did not get uploaded properly here are some images. Kindly co-relate with the post!
If you have any questions feel free to reach me.
Thanks all!
Last edited by Rehaan : 28th February 2012 at 16:13. Reason: Merging images into original post. Please see the "How to Upload Pictures" thread in Announcements.
Shai100 is offline   (8) Thanks Reply With Quote
Old 27th February 2012, 19:25   #2048
Smile Re: Mahindra XUV500 : Test Drive & Review
Not yet. I am waiting for it. Meanwhile, wish M&M would do another draw for the rest of the "unlucky" folks for the next 7000-8000 set of vehicles and provide a delivery date of sometime around July-Aug-Sep, it would be good. The chances of winning for these folks would improve.
tupin22 is offline   Reply With Quote
Old 27th February 2012, 20:51   #2049
nikhileshgrover's Avatar
@Shai100: The pictures are not coming up. Can you please check.
And thanks for the details.
nikhileshgrover is offline   Reply With Quote
Old 27th February 2012, 21:06   #2050
dockap's Avatar
Thanked: 376 Times
Some more info on xuv500 performance in desert storm 2012
Both of the last two stages have favoured the XUV 500, which has a far superior top speed than Rana's Gypsy, which was only capable of a maximum speed of around 130 kmph. The XUV 500, by contrast, was regularly exceeding 160 kmph on the flat and long stretches of the last two stages.
While not as fast as Urs' XUV 500, Chiripal's Vitara managed to reach a top speed of 147 kmph on the 339.76 km long eighth special stage, which allowed him to close in on Rana who had held a lead of 36 minutes over Chiripal prior to the seventh special stage.
The rally's final stage on Saturday is a repeat of the seventh special stage that was run on Thursday night. The 75.91 km long stage will, however, be run in the opposite direction. With its superior top speed, Urs is expected to make up even more time on third placed Abhishek Mishra.
Mahindra admitted that they had been targeting a top three finish in the Desert Storm when they entered the two vehicles.
Suresh Rana held on to win the 10th Maruti Suzuki Desert Storm in his battered Gypsy by 20 minutes and 14 seconds over Gaurav Chiripal's Vitara. Lohit Urs managed to place his Mahindra XUV 500 on the podium as he finished 20min 43sec behind Chiripal.
The final results of the rally were thrown in doubt after a mini-controversy with Chiripal's Vitara, which had to be jump started from parc ferme after his car's starter motor failed to start. There were talks of a protest against Chiripal as there was talk that this constituted repair work on the car, which is forbidden in parc ferme.
dockap is offline   (4) Thanks Reply With Quote
Old 28th February 2012, 13:57   #2051
vrrraju's Avatar
Thanked: 28 Times
Congrats buddy on having the rear camera installed, I think it is very essential one on such a big beast. What I am interested in, the attached picture it has been observed that the installer was drilling the camera hole on the black portion of the rear bumper, unlike some other installations where it was done on the top portion of the bumper and slightly offset from the center as you can find a hump at exactly center of the bumper. Is it the normal way of installing then probably it can be done at the exact center of the rear.
Also waiting for some one who can post the images of Rear View cam on their W6, with an extra screen/on the infotainment system.
vrrraju is offline   Reply With Quote
Old 28th February 2012, 15:40   #2052
Shai100's Avatar
Thanked: 106 Times
Yes, the camera is placed On the black portion of the bumper and in the exact center. I guess there is no guideline from Mahindra about the location of the camera. I had asked the installer the same question and he said they have been doing the same in all XUV's. Personally I like this location as it does not look odd compared to the ones offset from the center.
Shai100 is offline   Reply With Quote
Old 28th February 2012, 19:39   #2053
rohitbagai's Avatar
Thanked: 226 Times
From Car Info
Does this mean we can keep camera on while moving forward (by activating through the car info)? I see only black image when I activate camera using the menu. It's only when I engage reverse I am able to see the image. Can you please confirm you can activate the camera in forward gears too using the menu
rohitbagai is offline   Reply With Quote
Old 28th February 2012, 20:51   #2054
swiftnfurious's Avatar
Thanked: 6,471 Times
Originally Posted by aditya79india View Post
I want to be able to travel long distance with family in comfort and participate in ndure category off-road events (not extreme) without getting stuck. What do you suggest?
That's a difficult question for me since I dont know the "endure category" limits! I suggest you take a call after a TD with your family. If you plan to go for Safari, please wait till Storme is launched. From the initial reviews, there is quite some improvement.
Please wait for Storme!
swiftnfurious is online now   Reply With Quote
Old 28th February 2012, 22:36   #2055
sudipta's Avatar
Thanked: 34 Times
Hi All,
Just want to check if any of the lucky winners of the second round has already got the delivery dates post completing the paperworks with the dealer. My friend has got a delivery date from the dealer as 11th April 2012. Any other dates provided to anyone?
sudipta is offline   Reply With Quote
Mahindra XUV500 vs Mahindra Scorpio vs Tata Safari Storme vs Renault Duster vs Tata Aria a4anurag SUVs, MUVs & 4x4s 116 10th May 2017 15:34
Received a copy of the Coffee Table book on the Mahindra XUV500 from Mahindra Corp. shankar.balan Shifting gears 3 2nd April 2012 16:26
