Old 13th May 2014, 22:02   #6001
Thanked: 15 Times
Default Re: Mahindra XUV500 : Test Drive & Review
Originally Posted by aajohn View Post
Had purchased mine a year back from snap deal for INR 6500. I think there are many options online.
I too have a purple one and have avoided chrome. Felt it to be a bit garish for the colour. I personally feel that chrome suits better for the black and white variants.
Will check online portals. Thanks for the update on the price.
Opinion differs. Even I am not a big fan of chrome, may remove if I dont like it.
Originally Posted by ebmrajesh View Post
when i took my car from Sireesh Bangalore, the showroom manager told me not to go with Chrome accessory. He mentioned that in many cars the sealant/gum which holds the chrome has lost its ability and few customers lost the chrome frame as it felt down while driving. He also quoted me how the gum leaks down and makes stains on car paint. Probably someone can confirm if they have experienced the same. After hearing this i did not go with chrome accessory. Moreover my car color is Silver so it really does not make difference.
I check for the same with the dealer and he confirmed no such issues. One neighbour(6 months old) and a colleague (1+ Yrs) has XUV W8s both of them have Chromes on it and reported no such issues.
Fellow bhpins can confirm.
Chuchan is offline   Reply With Quote
Old 13th May 2014, 22:51   #6002
TaureanBull's Avatar
Thanked: 309 Times
Smile Re: Mahindra XUV500 : Test Drive & Review
Originally Posted by Chuchan View Post
2. Thx for the price, any genuine online sources where I can order from?
I also bought it from snapdeal. However, the price has now gone up. I remember homeshop18 and an unknown site vicky.in also stocking it.
As someone who got projectors retrofitted last year, I have to say that there is still an issue.
Yes. The proper cut-off for RHD markets is expected to be like this:
http://www.veloster.org/forum/attach...m-lhdvsrhd.jpg
But, what I saw my sister's XUV is quite different. The left projector is way high up and the right projector is way down on the ground. There is almost zero illumination in front of the driver after say 10 meters.
So, the alignment is off.
@TaureanBull: Please check your vehicle and report back.
Yeah I agree that in low beam the visibility is about 10m but I guess thats the way it should be in low beam. The difference in the level of beam takes a little bit of time to get used to if someone has not experienced the same before. However, I would say that its not "way too high" for the left projector.
The illumination in high beam is level and gives a very good range. Its satisfactory for high speeds.
In a nut shell I would say that the low beam is unsuitable for higher speeds as the illuminated area is just about 10m thereby giving less reaction time at higher speeds. On the other hand the high beam is suitable for higher speeds.
TaureanBull is offline   (1) Thanks Reply With Quote
Old 14th May 2014, 00:32   #6003
gurudutt's Avatar
Thanked: 127 Times
Dear XUV'ians , i got my black beast 2 months back and was busy writing the tbhp test drives initial ownership report. Having driven her for close to 3000 kms, i have noticed a few issues. Calling them out here, please let me know if any of you have faced the same issue and any possible resolution.
1) While downshifting to 1st gear, specially when you are in some speed and anticipate that you will have to slow down and downshift to 1st, there is a sudden jolt in the gear box sometimes and perhaps the vehicle itself shudders a bit, this is worrying me a bit. I can't reproduce it when the speed is right to shift to the 1st gear.
2) On my W6 variant, the music system turns on every time i turn the ignition on even though i had switched it off after stopping the car the previous time.
3) Sometimes when i get a call while listening to radio and i press the call cut button on the steering wheel after speaking, the radio channel would have changed. Initially i thought i tried to cut the call after the caller had cut it, but that's not the case always.
4) Also, am noticing some squeaking and vibration from the speedometer console. Is this expected and something i have to live with or can i get it fixed by the service center guys?
Finally, any of you guys found leather/art leather seat covers matching the walnut color interiors? I tried g sport and couple of other brands, but found nothing close enough.
gurudutt is offline   (1) Thanks Reply With Quote
Old 14th May 2014, 07:50   #6004
Sheel's Avatar
Thanked: 4,505 Times
This happens with the Scorpio VLX as well which I drive. Seems, this feature is there in Mahindras.
Old 14th May 2014, 09:20   #6005
gurudutt's Avatar
Thanked: 127 Times
Not sure with all cars though, cause i checked with a W8 owner and he said it remains switched off until you switch it on.
gurudutt is offline   Reply With Quote
Old 14th May 2014, 10:21   #6006
Thanked: 309 Times
Dear XUV'ians , 1) While downshifting to 1st gear, specially when you are in some speed and anticipate that you will have to slow down and downshift to 1st, there is a sudden jolt in the gear box sometimes and perhaps the vehicle itself shudders a bit, this is worrying me a bit. I can't reproduce it when the speed is right to shift to the 1st gear.
I guess you are downshifting too early at a higher RPM. You should brake and reduce the speed before downshifting else continue in 2nd gear which has a good range.
Rest of the issues I have not faced so far, but then I have a W8 so I am not sure if W6 is meant to be different.
TaureanBull is offline   Reply With Quote
Old 14th May 2014, 11:36   #6007
Thanked: 83 Times
Haven't put any chrome but installed the side strips. The jokers who pasted it didn't do it properly - a thin line of glue can be seen just above the strip. I didn't notice it first. It was Sidhu (who runs the 3M store in HSR Bangalore) who pointed it out to me when I had gone for paint sealant treatment. You need to ensure the guys do it properly at the first attempt itself instead of doing trial and error and making a mess.
aajohn is offline   (1) Thanks Reply With Quote
Old 14th May 2014, 12:13   #6008
ebmrajesh's Avatar
Thanked: 18 Times
Dear XUV'ians
I guess you are mentioning the noise coming from the console hood, the curvy lid which covers the console. Many of them got it fixed and some mentioned that a thin layer of soft material has been fitted between the plastic. Even i got this rectified during my first service. Mention it during your first service and mostly service engineers are aware of this and they should take care.
ebmrajesh is offline   Reply With Quote
Old 14th May 2014, 15:28   #6009
gurudutt's Avatar
Thanked: 127 Times
Not as much as it sounds like, am talking about speeds after you have braked while approaching a turn or a speed breaker, ~15 kmph.
Thanks ebmrajesh, i will get it fixed when i got for 1st service.
Old 14th May 2014, 15:50   #6010
swiftnfurious's Avatar
Thanked: 6,359 Times
...1) While downshifting to 1st gear, specially when you are in some speed and anticipate that you will have to slow down and downshift to 1st, there is a sudden jolt in the gear box sometimes and perhaps the vehicle itself shudders a bit, this is worrying me a bit. I can't reproduce it when the speed is right to shift to the 1st gear...
Guess you are "forcefully" downshifting when there is NO need. You should downshift to 1st ONLY when you are close to 0 kmph, otherwise a second gear would do just fine.
swiftnfurious is offline   Reply With Quote
Old 14th May 2014, 18:22   #6011
Awaiting Email Confirmation
Thanked: 4,209 Times
MapMyIndia has released version 9.0 maps. My XUV500 has version 8.0 maps. Will Mahindra dealership automatically call up the owners for updating the map/licence files? They did not have version 8.1 maps, when I checked up with them. Anyway, I will contact India Garage tomorrow and enquire about it.
J.Ravi is offline   (1) Thanks Reply With Quote
Old 14th May 2014, 20:14   #6012
carvoyeur's Avatar
Dear XUV'ians
My car is 20 days old now and ~2500 Km mileage and I also have this issue. Appeared all of a sudden out of nowhere. Once you are irritated by this, place a hanky/paper napkins between the plastic cover and the instrument console and that should take care of it before you go for your service
Carvoyeur
carvoyeur is offline   Reply With Quote
Old 15th May 2014, 07:57   #6013
Thanked: 15 Times
Thanks Buddy! I have checked the same online and found everywhere the price is around 8k.
Would like to see it in flesh before buying, Bangalore Bhpins any idea where to get 3d Maxpieder Kagu's?
Old 15th May 2014, 08:00   #6014
Hot Tracks.
J.Ravi is offline   Reply With Quote
Old 15th May 2014, 08:27   #6015
DocRock's Avatar
Thanked: 40 Times
17000 Kms done without any major problems.The front right headlamps were malfunctioning and the alignment was falling down, so replaced the whole assembly for free. Its cost was around Rs 12000/-. The service is simply beautiful at Coimbatore Mahindra.
I am thinking about upgrading my headlamps and Speakers with a Screen. It is a good system, but I wouldn't call it great. I think an Amp, good speakers, slim and small bass unit and one or two LCD screens needs to go inside.
Any ideas guys. Its a w8.
DocRock is offline   Reply With Quote
Mahindra XUV500 vs Mahindra Scorpio vs Tata Safari Storme vs Renault Duster vs Tata Aria a4anurag SUVs, MUVs & 4x4s 116 10th May 2017 15:34
Received a copy of the Coffee Table book on the Mahindra XUV500 from Mahindra Corp. shankar.balan Shifting gears 3 2nd April 2012 16:26
