Old 5th October 2014, 19:36   #6571
rahul_kej's Avatar
Thanked: 263 Times
Originally Posted by gpriyesh View Post
How do I connect an iPod to the infotainment system. I connected mine to the USB. It is charging the iPod but not recognizing it as a music source
Use aux cable and connect it to 3.5mm port near the USB input
rahul_kej is offline   Reply With Quote
Old 5th October 2014, 20:24   #6572
Thanked: 47 Times
It works that way but then the music source is Aux and not iPod. How will the system recognize it as iPod so that you can use the steering controls to control it.
gpriyesh is offline   Reply With Quote
Old 5th October 2014, 20:53   #6573
Vasuki's Avatar
Thanked: 226 Times
Default Re: Mahindra XUV500 : Test Drive & Review
No need to connect Ipod to AUX. I used to connect my Ipod Classic to USB port and it used to recognize the device and was able to play/browse music.
Vasuki is offline   Reply With Quote
Old 5th October 2014, 21:42   #6574
rahul_kej's Avatar
Thanked: 263 Times
Copy music in your ipod as you do in normal pen drive or hard disk. Then it will recognise the songs via usb. I doubt if it will recognise songs which are transferred in ipod using itunes as that's a differen format.
rahul_kej is offline   (1) Thanks Reply With Quote
Old 6th October 2014, 12:02   #6575
reevester's Avatar
Thanked: 36 Times
Correct.
@rahul_kej - This won't work.
@gpriyesh - It seems your iPods filesystem is corrupted and thats why the XUV is not recognizing it when connected by USB. I use mine perfectly fine and it works amazingly well. I suggest you reset your iPod using iTunes and copy over your music again. If that doesn't work, try another cable.
reevester is offline   Reply With Quote
Old 6th October 2014, 21:17   #6576
fiery enzyme's Avatar
Thanked: 23 Times
Yup. Restore your iPod.
fiery enzyme is offline   Reply With Quote
Old 7th October 2014, 06:37   #6577
Thanked: 47 Times
Originally Posted by reevester View Post
Correct.
Thanks. I am using an iPod video. Will restore that and try again.
Old 7th October 2014, 15:18   #6578
Twiny's Avatar
Thanked: 47 Times
Could any XUV(AWD) owners can comment on their slush drive experience and snaps or video clips if any.. similar to one described on the Duster-AWD thread.
http://www.team-bhp.com/forum/indian...ml#post3550704 (Renault Duster AWD launched at Rs. 11.89 lakh (pg. 15))
Twiny is offline   Reply With Quote
Old 7th October 2014, 18:05   #6579
rahul_kej's Avatar
Thanked: 263 Times
Has any one used philips xtreme vision or osram nightbreaker plus for XUVs low beam. Is it better than the stock osram. Your views are highly welcome.
Old 7th October 2014, 18:21   #6580
undead's Avatar
Thanked: 168 Times
I wouldnt recommend changing the OE bulbs to these above models because, their life span is shorter than the normal bulbs. IT IS a real pain to change those headlight bulbs. So, often you would be required to visit the service centre for that. Also , they dont offer a drastic improvement in vision. If you feel that the low beams are not bright enough, shift to Philips HIDs . If you are having problems with high beams, buy a pair of Hella 3003 .
undead is offline   (1) Thanks Reply With Quote
Old 7th October 2014, 20:56   #6581
Ketan's Avatar
Thanked: 178 Times
Originally Posted by undead View Post
If you feel that the low beams are not bright enough, shift to Philips HIDs.
Hi, Do you know where can I get Philips HIDs from? I'm looking for 4200K (or 4300K) Philips HID bulbs. I already have Philips ballasts with me.
THanks.
Ketan is offline   Reply With Quote
Old 7th October 2014, 21:58   #6582
kARTIK IYER's Avatar
Thanked: 12 Times
Guys,
I am also keen to change my low beam lights. I have read earlier that HID makes considerable difference. Please guide me on which is good quality HID and what does entire kit consists of. Any further information on costs would really help.
kARTIK IYER is offline   Reply With Quote
Old 7th October 2014, 22:33   #6583
fusionbang's Avatar
Thanked: 1,092 Times
THanks.
Originally Posted by kARTIK IYER View Post
Guys,
I think this link should help you guys. And SDP would be the right guy for your queries on the lights.
fusionbang is offline   (1) Thanks Reply With Quote
Old 7th October 2014, 22:38   #6584
Ketan's Avatar
Thanked: 178 Times
Thank you,
If I remember it correct, SDP got it via the group purchase for Morimoto that happened earlier, I'm trying to see if I get just the HID bulbs for Philips from India, I can make use of my ballasts, else I will go with the complete HID kit, either Osram, which is available in India or Morimoto that may need to be ordered from US.
Old 7th October 2014, 22:43   #6585
fusionbang's Avatar
Thank you,
Did you get a chance to check in JC Road?? Probably I might go this weekend, will check there and let you know if the Philips HID bulbs are available.
fusionbang is offline   Reply With Quote
Mahindra XUV500 vs Mahindra Scorpio vs Tata Safari Storme vs Renault Duster vs Tata Aria a4anurag SUVs, MUVs & 4x4s 116 10th May 2017 15:34
Received a copy of the Coffee Table book on the Mahindra XUV500 from Mahindra Corp. shankar.balan Shifting gears 3 2nd April 2012 16:26
