Old 16th October 2014, 16:10   #6616
kARTIK IYER's Avatar
Thanked: 12 Times
Default Re: Mahindra XUV500 : Test Drive & Review
I personally never do the wheel alignment/balancing at the ASS, they are expensive and do not do a complete job. I have been doing it at MRF centre or Bridgestone outlets and feel its better as they only do that business,are better equipped to manage it well.
You can find plenty of them at all metro cities.
kARTIK IYER is offline   Reply With Quote
Old 17th October 2014, 02:17   #6617
neil.jericho's Avatar
Thanked: 1,197 Times
Originally Posted by Twiny View Post
Madhus Enterprise@Langford is highly praised on this forum, about their workmanship in Alignment/Balancing. I have earlier taken all my cars to TyrePlus in HSR/Whitefield, and am satisfied with them too.
BTW after reading your bad experience, I won't ask Sireesh Marathahally (which is the nearest for me) to not even check the Wheel Balancing/Alignment, for my 5k service which will be due shortly.
I wouldnt suggest TyrePlus in HSR. It is amateur hour over there, all the time. Madhus is a much better experience.
neil.jericho is offline   (1) Thanks Reply With Quote
Old 17th October 2014, 13:59   #6618
PMK-MoJo's Avatar
Thanked: 53 Times
Originally Posted by balan View Post
I urgently need to change the service center. I am fed up with their service.
But first need to check the alignment again thoroughly. Which would be a good place to check the alignment? I usually do at the Sardar's shop near Indranagar RTO. Please suggest a good alignment shop before the tyres get damaged. BTW, I have done 25K km now.
Bala
Unequal force/ pressure distribution inside the tyre also one of the reason for this steering vibration/ side pulling. I had similar issue earlier, when i approached Madhu's they identified that one of the tyre is having this issue using their Road force test equipment. They suggested to use this as spare wheel and if required use this wheel in rear position.
That is the manufacturing defect.
FYI.. mine are JK tires. This defective tyre is actually given to me as a spare wheel. Once i changed tyre from that time i had this issue. Anyway now it is back to its actual spare wheel position.
PMK-MoJo is offline   Reply With Quote
Old 17th October 2014, 15:05   #6619
Thanked: 59 Times
Thanks. This may be the issue as I had changed the rear left tyre with spare tyre and the right pulling started. I assumed it was due to hit on the kerb. Now sireesh have rotated the tyres and have to go to madhu ro check the issue
balan is offline   Reply With Quote
Old 17th October 2014, 15:23   #6620
undead's Avatar
Thanked: 164 Times
I dont know why the service centres dont want to balance the rear wheels. I had severe vibration when touching triple digits. Took the SKS service in salem. They Did the balancing for front wheel only and vibrations reduced (but not fully gone) I asked to do the rear wheel also, but they declined .
This time during the second service visited CAI in erode and insisted to do rear wheel balancing. The vibrations totally gone and now its completely smooth. I agree that VIBRATIONS are due to front wheel balancing only. But when you have rear wheel that has big difference in weight balance , some vibrations can be felt right ?
undead is offline   Reply With Quote
Old 18th October 2014, 09:34   #6621
sreedhar's Avatar
Hello there. Is there any way to play videos using the USB? Seems only DVDs can be used. Any ideas??
sreedhar is offline   Reply With Quote
Old 18th October 2014, 11:55   #6622
Thanked: 47 Times
Yes ideally you can. It will play avi files. But I am unsuccessful till date. It is recognizing avi files but I can see only blank screen..could be a file codec issue
gpriyesh is offline   (1) Thanks Reply With Quote
Old 18th October 2014, 14:08   #6623
AutoIndian's Avatar
Thanked: 3,675 Times
Can someone please clarify the company standard warranty and the extended warranty on the XUV5OO. As per the "XUV500_service&warranty_booklet", the standard warranty is for a period 2 YEARS or 65,000 KM whichever occurs earlier from the date of retail sale to the customer, whereas the homepage mentions that the standard warranty is now, 3years/1,00,000 kms. Which version is true? And if the standard warranty now is indeed 3years/1,00,000 kms, then what about the extended warranty in terms of additional years/kms?
I am inclining towards the W6, hence the query.
AutoIndian is offline   Reply With Quote
Old 18th October 2014, 14:42   #6624
Thanked: 47 Times
Standard warranty is 3 years/100000kms.. You can buy extended warranty for 2 more years and 150000kms
gpriyesh is offline   (2) Thanks Reply With Quote
Old 18th October 2014, 14:56   #6625
AutoIndian's Avatar
Thank you gpriyesh for pitching in. That is a substantial warranty for peace of mind. Anyone aware of any offers currently going on XUV in Pune. Also how much discounts one can expect during the year end.
Old 19th October 2014, 05:40   #6626
sreedhar's Avatar
Thanks Priyesh. I'll try this and see if it works. Also, do enlighten me how to rest my trip recorder. Any amount of pressing the triangular button on the right hood of the Speedometer console does not reset or switch between odo and trip meters as informed in the booklet. Thanks
Old 19th October 2014, 14:23   #6627
rahul_kej's Avatar
Thanked: 229 Times
Try pressing the switch little hard than the usual force you apply, ofcourse not too hard to break it off. Still if it's not working, approach your ASS, there can be minor issue with the switch as carbon forming between the contacts can cause this issues. If accessible little bit of cleaning of the contacts in ASS will resolve the issues else ask them for replacement of the switch.
rahul_kej is offline   Reply With Quote
Old 19th October 2014, 16:00   #6628
Thanked: 47 Times
Soft press on the button toggle between odo and trip meters and the hard press resets them. This is the normal behavior. If not working this way take it to the ASS
gpriyesh is offline   Reply With Quote
Old 19th October 2014, 16:02   #6629
PMK-MoJo's Avatar
Thanked: 53 Times
Hi Guys
I am unable to find the bulb specification for high beam.
In user Manual it is showing as H15-15 55W. Not able to find this anywhere.
Is there any alternate bulbs available or what is the correct bulb spec for high beam?
Old 19th October 2014, 16:22   #6630
rahul_kej's Avatar
Thanked: 229 Times
Hi Guys
It's H7 bulb 55watt.
rahul_kej is offline   (1) Thanks Reply With Quote
Mahindra XUV500 vs Mahindra Scorpio vs Tata Safari Storme vs Renault Duster vs Tata Aria a4anurag SUVs, MUVs & 4x4s 116 10th May 2017 15:34
Received a copy of the Coffee Table book on the Mahindra XUV500 from Mahindra Corp. shankar.balan Shifting gears 3 2nd April 2012 16:26
