Old 23rd April 2016, 15:32   #7696
Thanked: 53 Times
Originally Posted by tirthankard77 View Post
Last Sunday was returning from Hyderabad to Bangalore, after 30 KM the check engine lamp came on and the max speed was 100/110 at 3000 RPM
The Turbo had stopped working. After another 300 KM after a 30 min stop where I had switched off the car, the warning lamp was off and pick up was normal. I had sent the car to ASC on Monday. They replaced the turbo under warranty. My car is of Nov 2013 and done 34560km.
XUV 500 is no doubt a value for money car with all the bells and whistles but stories like yours makes me wonder whether xuv 500 will be a suitable upgrade for our 2009 Chevy Tavera which is totally bare bones and is in touchwood condition.
Vikvkv is offline   Reply With Quote
Old 26th April 2016, 17:09   #7697
Default Re: Mahindra XUV500 : Test Drive & Review
Hello folks. Due to a minor accident, I had to give my XUV500 (done 16.5K kms in 18months) to the service station and the SA advised me to get the 3rd (20k kms) free servicing also done, which is overdue as per the no. of months. The estimate they (Infinity Autolinks, Mumbai) have provided is 19K + tax. This seems to be really high. I am attaching a copy of the same here.
Can one of the experts tell me whether they are right to charge for "cleaning" of the parts in the free service? Aren't they supposed to only charge for consumables?
Does this look ok or am I being taken for a ride?
Mahindra XUV500 : Test Drive & Review-img_4774.jpg
vivekiyer20 is offline   Reply With Quote
Old 26th April 2016, 17:52   #7698
rahul_kej's Avatar
Thanked: 241 Times
Don't get the 20K servicing done now. There is no time frame limit for Xuv servicing. He can't force you to get your car serviced.
Just get your minor repair work done.
rahul_kej is offline   Reply With Quote
Old 26th April 2016, 17:58   #7699
raj_5004's Avatar
Thanked: 2,031 Times
Most of it is not needed and they are just trying to make some quick bucks.
Just tell him to give you a proper estimate/quote and you will send it to Mahindra to check if all these are really needed in a 20k run XUV.
Or tell them to do everything but you will not pay a single penny for the work not mentioned in the service manual.
Your bill should not be more than 6k, if the mentioned prices are correct.
raj_5004 is offline   (1) Thanks Reply With Quote
Old 26th April 2016, 19:55   #7700
rishie's Avatar
Thanked: 30 Times
Likely parts/consumables to be used
FUEL FILTER CARTRIDGE -NEF CRDe.,MAXIMILE FEO 5 LTRS,MAXIMILE FEO 1 LTR,COPPER WASHER,AC FILTER,KIT OIL FILTER ELEMENT
Labour:2400/-
Parts:4346.73
Service (Total): 6746.73
This is an extract from Mahindra service calculator for 20K Service, apart from this, everything else should be optional. And I don't see any requirement for engine carbon cleaning and EGR cleaning on a car that has run only 20K kms.
rishie is offline   Reply With Quote
Old 26th April 2016, 20:41   #7701
Thanked: 13,345 Times
Now this is what I call a Royal Ride.
Of the list I can see, exclude the following:
WA/WB - 1800
Interior cleaning - 1500
EGR cleaning - 1000
AC Disinfection - 1000
Engine decarbonization - 1500
Silencer coating - 1500
Total: 8300 can struck off the 17000 + Tax
What you can do is:
Engine oil
Engine oil filter
AC Filter
Air filter
Wheel alignment and balancing can be done if they do a good job else get it done outside.
What is that SUB = Rs 650 and
Service Plus = Rs 400 in the estimate?
a4anurag is offline   (1) Thanks Reply With Quote
Old 27th April 2016, 10:05   #7702
Thanks Anurag, Rishi and Raj. Very helpful inputs for me to confront them with.
Rahul - Another reason I was thinking of getting the 20k servicing done now is that I have been getting a warning on my infotainment system that "Brake fluid is a low, drive with caution". The SA was telling me that mostly the brake pads would have worn off.
Old 27th April 2016, 16:32   #7703
DieselFan's Avatar
Thanked: 233 Times
I do not see a correlation between brake fluid and brake pads being worn out. Ask him to explain how he thinks when brake pads wear out the brake fluid warning comes up. I think all you need to do is top up brake fluid and see if there is any leakage in the brake system and fix the leakage. brake pads may be just fine. 16K kms is too less for the brake pads wear unless you have run the XUV recklessly.
DieselFan is offline   Reply With Quote
Old 27th April 2016, 16:46   #7704
Thanked: 2,060 Times
Wile the fluid levels needs to be topped up, replacing brake-pads is not what is required. You should get a separate warning as "Replace Brake Pads". It is usual to wear out brake-pads around 20K on XUV, so no issues there. Refer to numerous ownership threads - many have to replace the brake-pads at around 20-22K Kms. Reasons explained there in details.
abirnale is offline   Reply With Quote
Old 23rd May 2016, 11:44   #7705
Hi All XUV owners,
Your opinions required for 5th year shield warranty for XUV 5oo
I have W6 June 2012 model done 52000 km, warranty expires on 10 June 2016.
Is it worth to get 5th year shield warranty with RSA? (Approx. total Rs 24000/-(22000/- + 1961/-) for 1 yr)
bp74 is offline   Reply With Quote Received Infraction
Old 23rd May 2016, 12:53   #7706
Thanked: 142 Times
The XUV500 app from the Play Store has a service interval calculator which also lists parts to be replaced and/or cleaned at each service.
pillainp is offline   Reply With Quote
Old 23rd May 2016, 13:38   #7707
Sheel's Avatar
Thanked: 4,843 Times
Infinity Autolinks, Mumbai guys are pretty desperate, at least this is what appears from the estimate given, but they are also smart, since they have provided a hand written estimate on a plain paper.
Save for lube change and filter/s change, nothing is required. Fuel filter too shouldn't be required at 20K service, correct me if I am wrong.
I got my 4WD S10's 20K service and with change of lubes & filter's, the bill was around 4K [all documented]
Old 23rd May 2016, 14:03   #7708
Tanveer_2558's Avatar
Thanked: 1,997 Times
If your planning to keep the vehicle for the full 5th year, Go for it, The money is worth it for the peace of mind it will provide, Even though you have just done 52000 kms, Years went down he pipeline might bring something up, So i would suggest you should get it.
Last edited by GTO : 24th May 2016 at 09:46. Reason: Removing quoted post which has been edited
Tanveer_2558 is online now   Reply With Quote
Old 1st June 2016, 12:52   #7709
Thanked: 25 Times
Got the Warranty on my 2013 XUV extended for 4th & 5th year. Yes it's worth it as mentioned by Tanveer mainly for the peace of mind. My reasoning for the expense was that it will also fetch me a better resale value if selling withing the warranty period (& even otherwise) as the buyer would be assured that there has been no compromise in my ownership of the car.
Numb_Locked is offline   Reply With Quote
Old 10th June 2016, 09:41   #7710
Bageera's Avatar
Thanked: 19 Times
My XUV500 bought in Nov'14 is due for 40,000 kms service. I will be giving to for service to Mahindra Service Center only. Can any of you let me know how much the cost would come around to?
Bageera is offline   Reply With Quote
Mahindra XUV500 vs Mahindra Scorpio vs Tata Safari Storme vs Renault Duster vs Tata Aria a4anurag SUVs, MUVs & 4x4s 116 10th May 2017 15:34
Received a copy of the Coffee Table book on the Mahindra XUV500 from Mahindra Corp. shankar.balan Shifting gears 3 2nd April 2012 16:26
