Old 20th February 2014, 12:25   #1471
Pferdestarke's Avatar
Thanked: 546 Times
Default Re: Skoda Rapid : Test Drive & Review
Originally Posted by achopraa View Post
Both High and Low beams are generated from the same bulb filament with only one of it glowing at a time.I would expect the same behaviour in Projector lamps as well, so IMHO all is well.
AFAIK the only dual-beam halogen bulbs available are H4 and HB12, which houses seperate filaments for low and high beams. So they light up only one beam at a time. For the rest, the headlight assembly accomodates seperate bulbs for both beams. Coming to Rapid's headlamps, the projector is for low beam and the high beam is taken care by a halogen with reflector. The projector gets dimmed out when switched to high-beam but wouldn't go off.
Low beam.
Skoda Rapid : Test Drive & Review-prolow.jpg
High beam.
Skoda Rapid : Test Drive & Review-prohigh.jpg
Originally Posted by torque18 View Post
The low beam(projector) would go off every time high beam was flashed or the switch pushed back (constant high beam) when ideally on high beam the low beam should also stay on.
The older headlamps house H4 bulbs. So the same bulb gets input for both beams, whereas in new headlight assembly there are two seperate bulbs. I think this is something to do with the wiring. Please put up your query in this thread (Auto Lighting thread : Post all queries about automobile lighting here). They can surely help you out on this.
Pferdestarke is offline   (1) Thanks Reply With Quote
Old 20th February 2014, 13:39   #1472
Thanked: 11 Times
The air from the AC ducts of my Rapid fails to shutdown completely even 30 minutes after turning it off. I feel that car efficiency has also gone down due to this; hardly getting 11-12kpl in city.
Has anyone experienced this and got it fixed?
ashw_r is offline   Reply With Quote
Old 20th February 2014, 14:28   #1473
Santoshbhat's Avatar
Thanked: 3,832 Times
Have you set the AC to recirculation mode or fresh air mode? When you set it to fresh air mode, outside air comes in through the AC duct even if the fan and AC are switched off. The faster you go, higher is the flow of air. This has no impact on mileage.
Check for other things like tyre air pressure, fuel quality etc... if you are experiencing drop in mileage. If you ask me 12 kmpl in the city is pretty decent mileage within the city for a midsizer.
Santoshbhat is offline   Reply With Quote
Old 20th February 2014, 14:56   #1474
Thanked: 11 Times
Thanks for your reply. I have it set to recirculation mode almost all the time.
About the mileage, it has settled around 12 kmpl after the 6th month service. It used to give 14 prior to that. I take the e-city toll road to office and another colleague mentioned he gets 14 on a comparable route. Hence, the thought.
The mileage could well be down to my driving style but it does not concern me more than the 'escaping' air.
Old 20th February 2014, 15:04   #1475
In that case your recirculation valve may be broken. The ASC should be able to fix it.
Santoshbhat is offline   (1) Thanks Reply With Quote
Old 21st February 2014, 00:53   #1476
Thanked: 92 Times
In a normal Headlight, only one beam works at time i.e. either you are at High Beam or at low beam.
What glows along with both the beams are the parking lights (small bulbs inside the Headlight Assembly).
On the other hand, what was the cost of the Projector lamps and any pics to share after your setup.
Finally - Congratulations!!!
I haven't got it installed in my car yet as for that i would need to travel 200 kms.
But I had place order for the lights against advance payment and on their arrival the workshop guys tested it in some other Rapid and have reported the issue to me. They have asked me to get in touch with them after 2-3 days by which time they will hopefully have some solution.
The cost of the lights is approx Rs. 9500 each.
Thanks. I am hoping to hear from them in a day or two. Lets see what they have to say first
torque18 is offline   Reply With Quote
Old 22nd February 2014, 15:03   #1477
manas27587's Avatar
Thanked: 58 Times
Originally Posted by narsi_6989 View Post
Hi motoworks, as Pferdestarke it is possible to procure the cover alone. Since you have already replaced the complete assembly now, the below information can be used for future reference.
I just enquired at Dashmesh auto.
He too claimed that only the cover cannot be procured and the whole assembly has to be bought and will cost 2200 for the left tail light.
manas27587 is offline   Reply With Quote
Old 23rd February 2014, 13:56   #1478
Dealer prices for accesories is always on a higher side by atleast 20-30%.
Try finding an accessory shop outside to get best VFM leatherette seat covers.
You can also try converting seat into bucket style seat by removing orginal cloth and getting the seats stitched in leatherette(and they do feel good).
The downside with Leatherette is their ability to be too hot or too cold in extreme weathers but on the other hand its too easy to clean them (specially since we have beige) as compared to the Cloth based covers.
PS:- for around 42k more, i got Skoda Antares alloys, reverse camera, garmin Nuvi GPS navigator with Reverse display, parking sensors and Art Leather Covers under the Leisure Model.
Keeping above in mind, 10K seems to be on a bit higher side.
I have dropped the plan to install leather seats for now due to cost. Enquired with Karlsson Bangalore and they quoted me 46k. It's ridiculously high.
But I feel reverse parking camera (RC) is an essential requirement due to limited visibility from the RVM. Again ruled out integrated GPS & Camera in the HU due to high cost. I'm considering 2 options and need advise from this forum. Both are on-dash systems
Opt# 1 Mapmyindia (MMI) GPS with concealed wiring at left end corner on dash with integrated reverse camera. Cost 19k
Opt# 2 Garmin Nuvi GPS with integrate RC powered externally from the cigarette lighter charger :-) (pls excuse my ignorance. I have no idea what's the technical term for this element) Cost 25-27k. I guess the high cost is maybe for the brand.
I personally prefer Option 1 mainly due to concealed wiring. However I'm seeking feedback based on user experience with Mapmyindia.
Secondly I'm personally disappointed to know he reverse parking sensor output is not displayed in the OEM HU and would require an additional device to be planted over the dash. So that makes it 2 devices over the dash. Has anyone installed both over the dash? Can this be integrated into MMI device?
dspeter is offline   Reply With Quote
Old 23rd February 2014, 19:47   #1479
achopraa's Avatar
Thanked: 104 Times
[/quote]
Again
Having the Unit at extreme left corner will hinder your ability to perform navigation while you are at Driver's seat. I had my Garmin Navigation + Rear Camera provided with this setup by Dealer and I was very annoyed whenever I had to lean to extreme left.
Have a look below at how it was earlier in my TDI.
Navigation Unit with Camera and Parking Sensors with Display
This is what I have and personally I am very happy with
  1. Navigation Unit
  2. Reverse Camera
  3. Integrated Bluetooth Handsfree in the Navigation Unit
"powered externally from the cigarette lighter charger" means that the navigation Unit will have be powered by the Chigarette light Charger and thus
a) Your Car Charger unit will be occupied
b) The wire to the Navigation Unit will be dangling outside.
The Garmin Navigation Unit is available for around 16-17K and the Camera should not be more than 6K(worst case) and thus 25-27 seems to be a bit on higher side.
First, check below how both of them look at Dash with different Pics
My Rapid TDI ("Leisure"ly enjoying the Skoda Rapid TDI)
This is my current setup -
And this is how concealed the Unit.
Concealing the Navigation Unit wiring ("Leisure"ly enjoying the Skoda Rapid TDI)
I hope I have not let you more confused than you were before.
achopraa is offline   Reply With Quote
Old 26th February 2014, 11:04   #1480
Thanked: 546 Times
Guys, need a little help here. I feel the gear shifts in my Rapid are notchy especially from 1st to 2nd. No matter how slow I release the clutch it ends up giving a jerky transition. Is it common for a new car or should I suspect any issue? Also, up to what rpms do you revv before up-shifting?
Pferdestarke is offline   Reply With Quote
Old 26th February 2014, 15:56   #1481
achopraa's Avatar
Thanked: 104 Times
I would call it notchy if we are not able to slot the gear properly.
If you are getting Jerks while releasing clutch, either the clutch is having issues or may be the clutch is not being released as expected.
The problem usually occurs when we move from Petrol to Diesel since Diesel has a long play and is a bit hard as compared to the Petrol vehicles.
achopraa is offline   (2) Thanks Reply With Quote
Old 26th February 2014, 16:13   #1482
swiftnfurious's Avatar
Thanked: 6,570 Times
...No matter how slow I release the clutch it ends up giving a jerky transition. Is it common for a new car or should I suspect any issue?...
I would attribute it more to the personal driving technique. While I can release the clutch smoothly in my Swift (been driving it for 4 years & ~80,000 kms), I could never do it on my friends' Linea / Punto due to the long clutch travel.
At the same time, my friends never had issues with their cars. So that's my way of releasing the clutch causing the jerk.
At the same time, I had a very similar issue in my Swift too, which was eradicated by bleeding the clutch. The reason I was told was that there could be air bubbles in the clutch fluid due to driving style. After clutch bleeding, the issue never happened again.
swiftnfurious is offline   Reply With Quote
Old 26th February 2014, 16:35   #1483
Thanked: 546 Times
Yes, the clutch in my Rapid has a long range and almost no freeplay as compared to swift. Have been driving swift for 5 years. I think this needs a little getting used to.Thanks for pointing this
Old 26th February 2014, 16:38   #1484
hrman's Avatar
Thanked: 395 Times
I face this sometimes. Its more to do with the way of driving. You can try releasing the clutch and then pressing the accelerator. You can minimise the jerk then.
hrman is offline   (1) Thanks Reply With Quote
Old 1st March 2014, 19:42   #1485
ad3952n's Avatar
Thanked: 1,845 Times
Hi all, As per the details on Cardekho.com after having revised their prices just yesterday, Skoda India have gone ahead and released a limited edition of the Rapid called "Ultima". According to the Skoda India officials the limited edition is going to be the way forward as the company sees a potential in sales for their product portfolios.
AD
Source: http://www.cardekho.com/india-car-ne...ched-12525.htm
ad3952n is offline   Reply With Quote
Skoda Laura vRS : Test Drive & Review Rehaan Test-Drives & Initial Ownership Reports 184 6th June 2017 21:35
Skoda Rapid (MPI Elegance MT): Test-drives & Initial Ownership Report smydtt Test-Drives & Initial Ownership Reports 32 29th September 2016 19:09
A red hot rapid install in a red hot (Skoda) Rapid Samridh In-Car Entertainment 28 18th August 2013 00:49
