Old 19th October 2012, 23:29   #661
human_wheels's Avatar
Thanked: 56 Times
Thats exactly what I was wondering about for the last three years. My dzire rear left wheel has the same camper offset which makes it look like the pics above. When I had brought this to the notice of the SA he said it is normal.
human_wheels is offline   Reply With Quote
Old 20th October 2012, 12:00   #662
latentpotential's Avatar
Thanked: 377 Times
Default Re: 1500 km update
Originally Posted by mohandas View Post
2. Suspension - This is becoming a big issue on Ertiga. The rear passengers are complaining that the entire shocks from bad roads are getting moved to cabin. I suspect that they have reused the swift's suspension in its bigger and heavier cousin - ertiga.
I faced the same issue for the first 2000 kms. Got the rear air pressure set to 28/29 and the difference was very noticeable. Front pressure at 32. Both values 'cold'. Can you share the pressure you are maintaining for now?
latentpotential is offline   Reply With Quote
Old 22nd October 2012, 21:57   #663
virgovencat's Avatar
Thanked: 68 Times
Does other Ertigas in the yard have similar chambers? And is this camber angle only on the left rear wheel or do both rear wheels look the same?
It's not necessary that camber angle be 0, some vehicles can have + or - camber as designed to aid vehicle dynamics. That's why I asked if other Ertigas look the same and if both rear wheels are cambered same.
Yes all the Ertiga's had the same negative Camber values on the left rear wheel. Understood it could be a design from the manufacturer, if that is the case it has be symmetrical and both the rear wheels should have similar values which is not the case.
I have also verified several other Ertiga's alignment and all of them have the same values.
Yes, both the Ertiga's from the yard had the same values, I also checked with quite a few other vehicles and all of them have this deviation.
Also I understand that the Camber by design can be negative or positive but the catch is it has to be uniform (Symmetrical) which is not the case with Ertiga, the left and right does not have symmetrical values.
Originally Posted by nistala View Post
Could you please clarify what you mean here? Are you referring to the Caster angle? If yes, is it -ve or +ve and what it should be? If possible, please explain with a small diagram. Thanks for your time.
Sorry for the delayed response, I have posted details on the page 44. Also you are correct these negative camber will cause adverse effect on the suspension and the tyres also on the handling of the vehicle.
Note from Team-bhp support: Please use the EDIT or MULTI-QUOTE buttons instead of typing one post after another on the same thread. Please ensure the text does not contain any [FONT] and other tags when posting content created using external word processors. For more details : (Removing [FONT] [SIZE] and [COLOR] tags from your post)http://www.team-bhp.com/forum/announ...your-post.html (Removing [FONT] [SIZE] and [COLOR] tags from your post)
Last edited by moralfibre : 23rd October 2012 at 09:35. Reason: Back to back posts.
virgovencat is offline   Reply With Quote
Old 23rd October 2012, 21:16   #664
Thanked: 68 Times
Default Re: Maruti Ertiga : Official Review
Camber is the tilting of the wheels from the vertical when viewed from the front of the vehicle. When the wheels tilt outward at the top, the camber is positive (+). When the wheel tilts inward at the top, the camber is negative (-). The amount of tilt is measured in degrees from the vertical. Camber settings influence the directional control and the tire wear.
Too much positive camber will result in premature wear on the outside of the tire and cause excessive wear on the suspension parts. Too much negative camber will result in premature wear on the inside of the tire and cause excessive wear on the suspension parts.
Unequal side-to-side camber of 1 or more will cause the vehicle to pull or lead to the side with the most positive camber.
Negative camber generates what is referred to as camber thrust. When both tires are angled negatively they push against each other, which is fine as long as both tires are in contact with the road surface. When one tire loses grip, the other tire no longer has an opposing force being applied to it and as a result the vehicle is thrust towards the wheel with no traction.
I understand that the Camber by design can be negative or positive but the catch is it has to be uniform (Symmetrical) which is not the case with Ertiga, the left and right does not have symmetrical values. This issue is across all Ertiga's in the market now, I have been able to verify the Wheel Alignment Report of many Ertiga's.
Maruti Ertiga : Official Review-ertiga-rear-left-wheel-ve-camber-2.jpg
Maruti Ertiga : Official Review-ertiga-rear-left-wheel-ve-camber-1.jpg
virgovencat is offline   (4) Thanks Reply With Quote
Old 23rd October 2012, 22:13   #665
nurni76's Avatar
Thanked: 334 Times
Hi Virgo. Ever since you mentioned of asymmetrical camber values, I have observed carefully, and couldn't see any perceptible tilt either ways in my vehicle. I will be sending my ertiga for 2nd service soon and will definitely check the alignment and report. Also there seems to be no uneven tyre wear as well.
nurni76 is offline   Reply With Quote
Old 24th October 2012, 00:26   #666
ultimatechamp's Avatar
Thanked: 93 Times
Originally Posted by nurni76 View Post
Pictures of my Tyre ugrade (Teaser to my ownership review).
The alloy you see on the front was used just to test how 205/60/15 looks on the car. Initially thought of 205 but then finalised the 195.
Primacy LC does NOT come in 205/60 R15. It is either 205/65 R15 or it is 205/60 R 16 . So why did you first tried with 205,and then changed ? What made you change your mind? What according to you could have gone wrong with 205s?
Source : http://www.michelin.in/Home/Products...rCar/PrimacyLC
ultimatechamp is offline   Reply With Quote
Old 24th October 2012, 10:47   #667
nurni76's Avatar
Thanked: 334 Times
I know that the primacy does not come in 205. I tested 205 with yoko. 2 reasons for not going with 205. The tyre seemed to be jutting out of the body and also there could be possibility of touching the inside of the wheel arch when loaded and secondly he did not have Yoko A drive while the other Yoko version costed Rs 700 per tyre more than primacy.
Old 24th October 2012, 12:42   #668
gkrishn's Avatar
Thanked: 36 Times
after some googling around, feel that this negative camber might help to keep the body roll to minimum.
http://forums.rennlist.com/rennforum...-handling.html
gkrishn is offline   Reply With Quote
Old 25th October 2012, 01:16   #669
Thanked: 68 Times
I have also attached the Wheel alignment report of my vehicle which is similar to other vehicles report as verified. It is better if you can get this checked from a third party other than any authorised Maruti Service Center, Wheel alignement should cost you Rs. 350.
Also Tyre wear will be visible to Visual eye only after 15K Kms and that to if the wheels are not rotated.
I understand that the Camber by design can be negative or positive but the catch is it has to be uniform (Symmetrical on both wheels) which is not the case with Ertiga, the left and right does not have symmetrical values. This issue is across all Ertiga's in the market now, I have been able to verify the Wheel Alignment Report of many Ertiga's.
Usually the Camber is set negative for high performance cars in order to increase tyre contact with road while cornering there by reducing body roll.
virgovencat is offline   (1) Thanks Reply With Quote
Old 26th October 2012, 21:38   #670
Thanked: 93 Times
Have you written to Maruti or asked your After Sales Service outlet about this peculiar thing about camber angle Virgovencat ?
Old 29th October 2012, 23:16   #671
Thanked: 68 Times
Yes I have written to Maruti, They are yet to come back with a result upon thier investigation...
Old 1st November 2012, 12:06   #672
Thanked: 19 Times
Hi virgovencat, after reading this discussion about chamber angle, I have looked at my Ertiga rear wheels closely and found out that both wheels have slightly negative chamber. However, it is difficult to judge whether the chamber angle on both sides is the same or not with naked eye.
nistala is offline   Reply With Quote
Old 2nd November 2012, 20:50   #673
Thanked: 1,018 Times
I have been invited as part of an Ertiga owner's meet by Maruti Suzuki at Le Royal Meridien, Chennai. They said it's a satisfaction survey to receive feedback on the car. The meeting is at 5 PM on the 5th and 6th of November. Did anybody else from Chennai or other places receive an invite?
swiftdiesel is offline   Reply With Quote
Old 5th November 2012, 17:31   #674
Thanked: 55 Times
Could you please ask them about the camber issue being discussed in this thread and also another issue posted here: http://www.team-bhp.com/forum/techni...g-chain-2.html (Fiat Linea 1.3L MJD - Timing Chain)
The latter is about a timing chain issue in 90HP MJD engines, and Fiat is providing a new timing chain for 90HP Punto and Linea. It should be applicable to Ertiga/SX4 D too.
mohan41 is offline   Reply With Quote
Old 6th November 2012, 00:25   #675
Viswam's Avatar
Thanked: 16 Times
Apparently not many others (incl me) have received the invite to the meet. Could you pl share if any point of interest discussed/revealed on the Ertiga Owner's Meet.
BTW, i like the signature line, Inter-city Express.
Viswam is offline   (1) Thanks Reply With Quote
Review: My Maruti Suzuki Ertiga ZDi a4anurag Test-Drives & Initial Ownership Reports 38 29th November 2015 18:13
For Taxi: 2012 Chevy Tavera vs Maruti Ertiga vs Chevy Enjoy? EDIT: Bought Ertiga ZDi M35 SUVs, MUVs & 4x4s 21 9th January 2015 06:48
FAB makes way for LUV - Maruti Ertiga VDi Review rohin4110 Test-Drives & Initial Ownership Reports 14 2nd June 2014 20:32
