Old 27th January 2014, 15:44   #3571
::CMS::'s Avatar
Thanked: 464 Times
Default Re: Renault Duster : Official Review
Last saturday I was at the Renault Whitefield service station for fixing some weird noise coming from the driver seat back rest. I happened to see a Duster came for 30K service and I observed the new Air Filter doesnt have the 1" thick black foam at the bottom that helps in preventing the bigger particles that enter the airfilter. I was told that the new filter is coming without the foam and he replaced the old one w/o the foam.
Anybody knows the reason for that? Is it for a better pick up or a cost cutting measure? Also does K&N Filter has any filter for Duster?
BTW, they couldnt find the reason for the screeching sound from the seat, so they are replacing it under warranty.
::CMS:: is offline   Reply With Quote
Old 27th January 2014, 16:31   #3572
::CMS::'s Avatar
Thanked: 464 Times
Note: Couldnt merge this post to the prev one as the editing time was over.
Following is the extract from 30K paid service of Neil Roy's Duster, I am posting it here for getting more response.
Invoice : http://www.team-bhp.com/forum/attach...terbill30k.jpg
- In the parts list they have mentioned "PAD-FR BRAKE LI : 2500/-", I think its for the brake pads. Is the kit includes the front 2 and the back drum pads too or is it only for front brake pads (both L & R)?
- Are these the labor charges just for cleaning and changing the brake pads? if not, please mention what are those charges?
> "3043 GO REPLACE FRONT BRAKE PADS : 210/-"
> "BRAKE FR & RR BRAKE CLEANING & ADJUST : 1000/-"
> "DISC DISC FACING BRK : 2500/-"
If the above is true, then its day light robbery, 3710/- labor for just the brake servicing even w/o brake fluid changing.
- "PMS Periodic maintenance : 1050/-", Since they charge everything separately, are they charging 1050 for just washing, air filter and oil change?
Any idea, Is there any implication with the warranty if we do the rest of the servicing outside except the oil change and wheel balancing and alignment from the service center?
Old 27th January 2014, 17:01   #3573
HillMan's Avatar
Thanked: 401 Times
This looks like brake lining replacement for front brakes alone.
This seems to be regular cleaning of brakes both front and back plus the replacement charge.
This piece is confusing. Not sure, what they are charging for when brake parts and labour already accounted.
Curious, if they replaced the disk itself?
Yes. this will void your warranty as only authorized service center needs to service your car at regular interval as per their schedule.
For small stuffs like air filter cleaning and replacement with branded product or wheel balancing and replacement they usually dont bother.
HillMan is offline   (1) Thanks Reply With Quote
Old 27th January 2014, 21:37   #3574
::CMS::'s Avatar
Thanked: 464 Times
Where can we find the mandatory checks or replacements for each service schedule recommended by the company (not by the dealer)?
Old 27th January 2014, 22:37   #3575
SunnyBoi's Avatar
Thanked: 2,803 Times
Disc Facing is a local term used for turning the brake rotors on a lathe to flatten out any grooves on the rotor surface.
2500Rs still for it is sheer robbery.
SunnyBoi is offline   (2) Thanks Reply With Quote
Old 28th January 2014, 00:01   #3576
HillMan's Avatar
Thanked: 401 Times
Here you go:
http://www.renault.com.eg/services/serviceprices.html
Select Duster from drop down and select service interval based on Kms. It has a fair maintenance schedule listed out there.
While hunting for the above, I found this useful PDF. Which is nothing but soft copy of the owners manual.
http://www.renaultusa.com/News/Drive...a%20duster.pdf
Old 28th January 2014, 09:11   #3577
AshwinThekkan's Avatar
Thanked: 219 Times
Post Re: Renault Duster : Official Review
K&N filters are available for 110ps variant, i am using it in my Duster.
Not sure about K&N for 85ps variant but green cotton filters are available for the same.
AshwinThekkan is offline   (1) Thanks Reply With Quote
Old 28th January 2014, 09:16   #3578
::CMS::'s Avatar
Thanked: 464 Times
From where did you buy and for how much? The filters should be same for both. The filter upgrade is pending since the remap.
@All, Can somebody please send me a scanned copy of the warranty terms and conditions page for Duster?
Old 28th January 2014, 09:22   #3579
Thanked: 219 Times
For Which variant ? It costed aroud Rs 4000/- for me if i recall correctly. The filters are entirely different for 85ps and 110ps variant.
Old 28th January 2014, 11:23   #3580
sumeshmani's Avatar
Thanked: 104 Times
1/3 rd the cost of a 30K service is just for brakes. The labor costs are on the higher side.
Are there any other reliable places where we can get disk skimming done?
sumeshmani is offline   Reply With Quote
Old 29th January 2014, 14:11   #3581
pahwa's Avatar
Thanked: 125 Times
I was infront of you (White Duster) while waiting at the railway gate
Hey CMS. Was nice meeting you yesterday on Whitefield road.
Please do keep us posted about your Andrio device and how the whole testing experience goes. How about a dedicated thread about Andrio?
pahwa is offline   Reply With Quote
Old 29th January 2014, 16:05   #3582
Thanked: 326 Times
guys.. we all know how the Diesel engined powered Duster can trot about without any throttle input in 1st Gear...
Now, these days I have gotten into a habit of using this as a default option while starting off from a complete stop. And even on inclines ! My own Hill Ascent Control..
Just wanted to check if this practice could have any detrimental effect on the clutch/transmission etc?
BUXX is offline   Reply With Quote
Old 29th January 2014, 17:51   #3583
HillMan's Avatar
Thanked: 401 Times
Increases clutch wear and tear. Start is OK but stopping vehicle on inclines with light clutch is bad.
Old 29th January 2014, 18:30   #3584
ahmad.007's Avatar
Thanked: 66 Times
Avoid it at inclines. Other than that I can't seem to think why this practice will not be beneficial for the clutch and other parts,etc. The speed differential between the gear and driveshaft is minimum at idle rpm, hence theoretically minimum wear and tear. I mostly use only clutch to get my vehicles moving (yup, even petrols).
ahmad.007 is offline   (1) Thanks Reply With Quote
Old 29th January 2014, 18:43   #3585
human_wheels's Avatar
Thanked: 56 Times
Works like a charm. Been doing that since ages. My dzire clutch still feels like new at 60k. Except that you should not hold your vehicle at an incline with half clutch for a longer duration(I guess 4-5 seconds is fine).
human_wheels is offline   (2) Thanks Reply With Quote
Renault Duster AWD : Official Review Rehaan Official New Car Reviews 815 23rd February 2018 12:33
Itís an SUV, it's a Sedan...No it's a Crossover! The Renault DUSTER: Ownership Review h.s.r Test-Drives & Initial Ownership Reports 86 17th September 2016 11:38
Renault Duster : Official Launch Report parrys The Indian Car Scene 758 21st July 2012 20:36
