Old 17th June 2014, 12:42   #4066
harpreetsubhi's Avatar
Thanked: 101 Times
Default Re: Renault Duster : Official Review
Originally Posted by jsing3 View Post
Hi Harpreet...Thanks for info. I did not speak to Murli, but the DGM Service was good enough to address the issue immediately. Got the Duster back in the evening today and the service advisor told that there was a fault in the timing. This is a weird answer as the duster was running fine before without any problems and there was no indication in the ODO. They have told me to monitor the performance for a week and then give them the feedback about it. Let's see how it goes guys. Harpreet you can call me @9871696969.
Really Happy to hear that the car is perfectly back to normal now. I will call you in the evening and take your feedback on Duster as I'm also contemplating Duster 85PS RXL+ version, which Renault is selling for 9.99L ex. showroom these days.
harpreetsubhi is offline   (1) Thanks Reply With Quote
Old 17th June 2014, 15:08   #4067
ampere's Avatar
Thanked: 8,825 Times
Originally Posted by HillMan View Post
Looks like an issue with Turbo which kicks in at 1800rpm in 85ps. Do keep us posted on the progress.
Turbo kicks in much earlier I thought. Almost 1200-1300 rpm itself? (I mean for the 85)
Old 17th June 2014, 15:28   #4068
HillMan's Avatar
Thanked: 401 Times
Turbo kicks in around these RPMs
1800 for 85ps
2200 for 110ps
The turbo punch is felt from there on.
HillMan is offline   Reply With Quote
Old 17th June 2014, 20:48   #4069
Thanked: 101 Times
1800 for 85ps
2200 for 110ps
What is the idle RPM of the 85ps Duster ?
harpreetsubhi is offline   Reply With Quote
Old 17th June 2014, 20:52   #4070
HillMan's Avatar
Thanked: 401 Times
Idles around 700 RPM both with A/C On and Off. The sound goes up when you turn On the A/C, but there is no noticeable change with the position of RPM needle.
Old 17th June 2014, 21:30   #4071
ampere's Avatar
1800 for 85ps
2200 for 110ps
No I think it kicks in much much earlier for the 85. Thats how we are able to drive it like a petrol engine.
Here is a ref post from the review:
http://www.team-bhp.com/forum/offici...ml#post2847117 (Renault Duster : Official Review)
As expected, the Duster 85’s USP is the outstanding in-city driveability on tap. Turbo lag is too negligible to mention, with the engine feeling immensely tractable. While the Duster 110 only really wakes up after 2,000 – 2,200 rpm, the Duster 85 pulls clean from as low as 1,200 rpm. The engine behaves like a naturally-aspirated diesel! Translated, you’ll seldom need to downshift within the city. The Duster 85 passes the 2nd gear speed-breaker test with flying colours; it is even possible to drive away from 0 kph in 2nd gear, with just a little clutch slip. BHPian Parrys didn’t face any problem in climbing city flyovers in 5th gear itself. In traffic conditions that the Duster 110 would require frequent downshifts, the 85 happily rolls along in the same gear. You can use the versatile 2nd or 3rd gear (choice dependent on traffic speed) just like an automatic. With liberal usage of the accelerator pedal, the Duster 85 is reasonably peppy in the city. That said, it somehow doesn’t sprint as fast as the Sunny Diesel.
Old 18th June 2014, 06:37   #4072
HillMan's Avatar
Thanked: 401 Times
Agreed, the 85p does pull clean from 1200 but that I believe is to do with the design with FE in mind. Duster 85 struggles below 1000RPM. It is only comfortable idling there. Slight touch of pedal will take the RPM above 1k mark. I can guarantee there is no additional sound from the engine until you go above 1500RPM. There is no digital meter for me to confirm the exact number. I believe it has to be 1800RPM, here the acceleration behavior changes. The SA also mentioned this figure to me in one of my interactions.
Old 18th June 2014, 07:53   #4073
condor's Avatar
Thanked: 4,559 Times
HillMan (Renault Duster : Official Review) : Duster 85 struggles below 1000RPM. It is only comfortable idling there.
Unless you are driving a large engine like the Volvo Bx's, an engine will struggle below the 1k rpm mark. The cars/LMV's will. 1000 rpm for cars is between idling & operating rpm's, and unless you want to keep going at low speeds, that rpm is not where you will be anyway.
HillMan (Renault Duster : Official Review) : Slight touch of pedal will take the RPM above 1k mark. I can guarantee there is no additional sound from the engine until you go above 1500RPM.
Of course there is no additional sound from the engine. In fact, there is only one sound from the engine - of the engine in operation
Old 18th June 2014, 09:17   #4074
HillMan's Avatar
Thanked: 401 Times
The sound and feel of the engine is noticeably different from 1800rpm. If turbo kicked in below this figure, the dynamics would be different.
Old 19th June 2014, 17:29   #4075
anilntny's Avatar
Thanked: 225 Times
Infractions: 0/1 (5)
I purchased a Renault Duster 85 ps RXL plus 3 weeks back.
I have JL audio amplifier J320.4 , JL audio subwoofer ,Focal component speakers and Morel coaxial speakers, all about 2 years old removed from recently sold swift.
The audio installation and uninstallation was done by Emperor Kochi.
My original plan was to swap the whole kit with duster's audio components. But Renault Kochi accessory shop sales adviser is warning me about warranty issues if I do so. Please help out here to make a decision.
anilntny is offline   Reply With Quote
Old 22nd June 2014, 04:57   #4076
HillMan's Avatar
Thanked: 401 Times
Warranty issues will arise if the wiring are tampered. But then they are acceptable to a point if it causes no issues with the vehicles electricals and worked on professionally. After all many people go for aftermarket ICEs.
I've also heard of issues where rain water was flowing into the carpet because seals/damping were tampered during an audio install to run the wires.
It is best to reuse the existing cables where ever possible.
HillMan is offline   (1) Thanks Reply With Quote
Old 22nd June 2014, 19:41   #4077
anilntny's Avatar
Thanked: 225 Times
Thank You HillMan. I have dropped the idea of installing Amplifier and Subwoofer. I will swap speakers only.I also plan to damp and pad all four doors.Let me know anything to be careful with while tampering with door pads.
In between ,any idea about how to fully seal the cabin ,as outside air tend to seep in even in recirculation mode?
Old 22nd June 2014, 22:44   #4078
HillMan's Avatar
Thanked: 401 Times
There is a stop before the circulation knob is fully open or closed. Turn it all the way to left. Raise a complaint with the service center if the issue continues.
Old 23rd June 2014, 00:17   #4079
xjosephjacob's Avatar
Thanked: 239 Times
I figure you're not talking about the air that seeps in through the a/c vents.
This has been discussed before, however no one came up with a definitive solution. If you drive your Duster through a foul smelling area at moderate/high speeds, the bad odor does seep in sometimes. May be the rather poor door/window seal design (or the inadequate cabin insulation in itself) is the culprit.
How I wish Duster had better acoustic insulation.
Nissan Terrano has additional weatherstrips on all four doors. Do check them out; what if a eureka moment strikes you
xjosephjacob is offline   (1) Thanks Reply With Quote
Old 23rd June 2014, 09:16   #4080
Thanked: 216 Times
During my recent trip to Sikkim in the start of the year I also faced a similar issue, where even though the AC was not running when there was someone driving in front of me in the muddy roads, there was enough amount of dust getting inside the car.
After coming back I went to the ASC, and they told me that there are two ducts which are purposefully left open, one in the front and one in the back, and if I want they will seal both of them so that no outside aur comes in, unless you switch to the outside air with the AC knob.
They charged me 3000 Rs. for that, 2000 for front and 1000 for back. And after that I couldn't feel any dust/smell getting inside the car, though I haven't been to muddy roads like the one I have been before, but I couldn't feel anything with my trip to Kanyakumari in May. May be you can try that.
gurha is offline   (1) Thanks Reply With Quote
Renault Duster AWD : Official Review Rehaan Official New Car Reviews 811 9th February 2018 14:42
Itís an SUV, it's a Sedan...No it's a Crossover! The Renault DUSTER: Ownership Review h.s.r Test-Drives & Initial Ownership Reports 86 17th September 2016 11:38
Renault Duster : Official Launch Report parrys The Indian Car Scene 758 21st July 2012 20:36
