Old 6th January 2016, 14:35   #5266
Thanked: 430 Times
Default Re: Renault Duster : Official Review
Looks like the Fuel Gauge on my Duster AWD has gone for a toss. Tanked up full at Shell but its showing only two bars. Resetting the ODO didn't help. Anyone faced similar issue?
C300 is offline   Reply With Quote
Old 6th January 2016, 14:46   #5267
Thanked: 74 Times
Did you filled Diesel while Key was in Ignition. Then you need to remove the Key and wait for some time and then reinsert key.
micrographics is offline   (1) Thanks Reply With Quote
Old 6th January 2016, 19:13   #5268
swiftdiesel's Avatar
Thanked: 1,192 Times
Nothing to worry. Happened once in my Lodgy and I tried re-starting it but it still showed 2 bars. Later, reached my place and parked for the night. The next morning, viola, all the bars displayed. Never happened again.
swiftdiesel is offline   (1) Thanks Reply With Quote
Old 6th January 2016, 19:39   #5269
Thanked: 34 Times
I am having the same problem with my Duster AWD. Its fuel tank was running on empty when it was filled to full tank, but it showed only a couple of bars on the display. A week or so later, it has got better but it is still a couple of bars short. The tank fills up only to Rs. 1,500 or so. According to the Indian Oil pump we frequent, there may be an airlock but I haven't a clue whether they meant the tank or the fuel system. Based on whatever information I could comprehend online, an airlock in a diesel engine's fuel system is a major problem that affects the engine and requires extensive work to remove the air bubbles from the fuel system.
On our vacation recently mostly in 6th gear, I noticed that the fuel consumption indicator only went up from an already low 12.6 kmpl to a paltry 12.9 kmpl on the return trip, nothing like the 18 kmpl we got last time. I am fairly certain this is reasonably accurate as I spent around Rs. 2,000 more on this trip compared to similar ones we have done in the past.
I am worried what harm our 1,000 km trip may have done to the engine if indeed there is an airlock in the fuel system. I am going to call up Renault tomorrow to get to the bottom of this.
nowwhat? is offline   (1) Thanks Reply With Quote
Old 7th January 2016, 22:04   #5270
Thanked: 430 Times
Yes, the ignition was on. Will have to be careful next time I re-fill.
Unfortunately the issue still persists.
Thanks for the info.
Looks like I will have to take the Dusty to service centre and get this fixed.
Old 8th January 2016, 09:53   #5271
Thanked: 34 Times
I called up Renault yesterday and the CSR mentioned that off-hand they are not aware if this problem. They requested me to take the Duster to the service center.
I then called up Renault Silk Board, but could only get an appointment for next week. Their Service Manager, Guru, says that he hasn't come across this problem either.
Let me know what you find at your service center. BTW, How is your fuel consumption?
nowwhat? is offline   Reply With Quote
Old 8th January 2016, 11:04   #5272
Thanked: 430 Times
Havent noticed any changes to the fuel consumption.
Its usually in the range of 15-17 depending on the driving condition.
Old 8th January 2016, 11:22   #5273
antardaksh's Avatar
Thanked: 227 Times
Originally Posted by anilntny View Post
Blackened front grill ,instead of full black,I have kept a central strip of chrome.
Hi anilntny,
Does 3M store sell vinyl wrap or did you buy it from somewhere else. I was searching but was not able to find 3M vinyl wrap on any online store. I had gone to 3M car care to get chrome part(front grill) covered in matte black but they refused to do it, maybe due to less area and low cost.
Regards.
antardaksh is offline   Reply With Quote
Old 11th January 2016, 10:38   #5274
Thanked: 430 Times
Visited the service centre over the weekend. As per the SA, the issue was with internal wiring which was promptly fixed. I had few Gang of Duster vouchers so got the car thoroughly cleaned. Overall, happy with the job.
C300 is offline   (1) Thanks Reply With Quote
Old 12th January 2016, 16:56   #5275
engrohit's Avatar
Thanked: 91 Times
Hi Team
I am coming back to this forum after a long break. What brings me here is a query on the tyre replacement. I have done 47000 on stock tyres and am looking at options to replace this.
I definitely want to move away from MRF wanderers (this is what i had from OEM) and go for something which gives better life. While the MRF was super on ride comfort, it did have an issue of noise above 100 Km/h.
I am sure most of the original Duster buyers gang (i bought mine in Sept'2012) would have gone for tyre replacement already, so any inputs on what they chose and why would be very helpful.
Thanks in advance.
Rohit
engrohit is offline   Reply With Quote
Old 12th January 2016, 17:35   #5276
ampere's Avatar
Thanked: 9,108 Times
For the price, MRF is the best bet. You cannot get some thing which is better on noise (means softer rubber) and which has more life. Both seem inverse to each other.
For better ride and low noise, the best option is Micheline Latitude HT. Thats what I got for mine after 55K. I am nearing 63K now. Awesome performance. But dont expect life to hold like MRF. They should age faster, given they are softer.
ampere is offline   (1) Thanks Reply With Quote
Old 13th January 2016, 09:59   #5277
Thanked: 327 Times
^^ to add: they are super expensive too when compared to the MRFs..
@ampere: Have you faced more punctures in the soft Michelins?
BUXX is offline   Reply With Quote
Old 13th January 2016, 10:22   #5278
anilntny's Avatar
Thanked: 265 Times
Originally Posted by antardaksh View Post
Hi anilntny,
Regards.
I bought it from the 3M car care outlet, Kochi and did the wrapping myself.
anilntny is offline   (1) Thanks Reply With Quote
Old 14th January 2016, 21:18   #5279
Esu Junior's Avatar
Thanked: 82 Times
Originally Posted by PapaBravo View Post
Very tastefully modified Esu Junior. Looks clean & great.
Few questions :
1. What did you use for black chrome coating of grill ?
2. Does the 235/60 Marauder foul with the wheel well ? Any further modifications to accommodate it ?
Pawan
Hi pawan,
I'm not sure of what they have used for black chrome coating.It can only be done on chrome and not on fibre parts.Regarding Maxxis tyres(235/60/16) no modifications done and no fouling with wheel well.But noise is on the higher side.
Esu Junior is offline   Reply With Quote
Old 14th January 2016, 21:29   #5280
ampere's Avatar
Costlier yes. But Not that costly I guess. At most 1.5K or so over on top per tyre.
Nothing as of yet. Brilliant for regular highways. But yes, they are not all terrain tyres. So expect them to wear out faster as compared to MRF.
Renault Duster AWD : Official Review Rehaan Official New Car Reviews 863 9th July 2018 00:02
Itís an SUV, it's a Sedan...No it's a Crossover! The Renault DUSTER: Ownership Review h.s.r Test-Drives & Initial Ownership Reports 86 17th September 2016 11:38
Renault Duster : Official Launch Report parrys The Indian Car Scene 758 21st July 2012 20:36
