Old 6th November 2013, 14:02   #1771
narayan's Avatar
Thanked: 1,276 Times
Default Re: Tata Safari Storme : Official Review
Originally Posted by ebonho View Post
Same problem in my truck. Managed to figure out why. The clasp on the seat back which smaps and locks on to the small cylindrical post coming out of the central pillar, is not able to close and lock properly because it aligns with the circular knob like end of that post, instead of further inside on the thinner part of the stalk.
What the TASS guys did was remove that post and refit it on to the central pillar with a washer (as a spacer) at the base. This made the post jut out a bit more and the clasp of the seat back now aligns with the thin part of the post and manages to close and lock perfectly instead of aligning with the circular knob at the end.
In my case, I just had to push back the back rest firmly and at an angle and the u shaped clamp at the seat back went and rested proporly in the bolt thats counted from the C pillar ( if one may call it so )
Have just updated my 2nd service feedback in the ownership thread.
http://www.team-bhp.com/forum/test-d...ml#post3285698
narayan is offline   Reply With Quote
Old 6th November 2013, 14:10   #1772
ebonho's Avatar
Thanked: 3,180 Times
Even in my case with some banging a few (many) times and some wrestling with the seat back, the backrest would finally lock and not unlock by pulling the backrest forward. But that was really an inelegant and hit or miss type solution. Now I just have to push the backrest back normally (no Samson style thudding) and things click (and stay) in place.
ebonho is offline   Reply With Quote
Old 6th November 2013, 16:33   #1773
tsk1979's Avatar
Thanked: 15,770 Times
If you read the review, you will see I have mentioned this issue. Hard braking will cause the rear seat to fall down. This problem is due to the locking mechanism not aligning with the body support bolt on some safari's. If it matches, it perfect, but if it does not then you have a go at it with a hammer and try to find the good position.
Since your stormes are new, I suggest you give a hard time to your A.S.S bodyshop and get it aligned, refusing to give positive feedback till they fix it.
I now have found a solution in my safari. I tie a nylon rope to the backrest, and then tie it with the grab handles on the boot. Not the most elegant, but it works.
tsk1979 is offline   (2) Thanks Reply With Quote
Old 6th November 2013, 16:42   #1774
ebonho's Avatar
Another bit of experience to share. I use to get this clanking metallic sound inside the cabin every time my truck would hit a level difference in the road (like when bottoming out after a flyover where the transition of the concrete is not leveled off smoothly). We went mad trying to find the source of this sound.
Turned out that the bracket which holds the jack, the jack has to be screwed out and opened so that it tightly fits within that. If not, then it moves and makes that metallic thunk.
ebonho is offline   (1) Thanks Reply With Quote
Old 7th November 2013, 22:01   #1775
NST440's Avatar
Thanked: 175 Times
Hey guys can anyone pls. post about the things to be taken care of at the 3rd service
(1year,10000 Kms.), i guess it includes oil change. I would be going for the same soon & would like to know what things should be kept in mind & at the same time how much would it cost?
NST440 is offline   Reply With Quote
Old 7th November 2013, 22:10   #1776
condor's Avatar
Thanked: 4,741 Times
@NST440, Have you completed 1 year ?
Reason I ask is the service is due only @ 15000 km, and not 10k.
For items to be covered, pls refer owner's manual. Ensure that all those points are done.
condor is offline   (1) Thanks Reply With Quote
Old 8th November 2013, 11:32   #1777
narayan's Avatar
Guys
Has anyone tried a roof mounted luggage carrier with the Storme ? Any suggestions on what will look good ? I don't plan to invest in Thules etc. If practically posssible I might even remove it after the trip.
Guys
posting my query again since I did not get any response. Pls help. Will need to do something in the next 2-3 weeks. Also should I consider the rear mounted metallic tray type thing one sees in the explorer edition ?
Old 8th November 2013, 11:35   #1778
comfortablynumb's Avatar
Thanked: 944 Times
Pls help.
I had seen these at an accessory shop in Pune and they seemed quite robust & decently put together. Please check if they are available anywhere in Chennai.
http://ajantain.com/roof_racks__luggage_carrier
Cheers,
Vikram
comfortablynumb is offline   (1) Thanks Reply With Quote
Old 8th November 2013, 13:42   #1779
stormerider's Avatar
Thanked: 489 Times
Originally Posted by stormerider View Post
Guys I need some suggestions on the problem which I faced for the second time last week leaving me stranded and forced to call on road assistance.
My gear lever went free while the car was in 3 gear!?! It's because of a small pin which links gear lever to transmission, which is only Rs.16 fix at the Tass. But the fact that the pin came out and left me stranded in less than 16k kms is troubling me.
Both the times, the on road assistance (provided by tvs) fixed it with a small nut and bolt and asked me to take the vehicle to Tass for fixing the issue.
Can someone please throw some light as how can I get rid of this dampener, as otherwise I am completely in love with the truck. Has anyone else faced the same issue?
Some help would be appreciated,
Service interval is 1yr/15k kms. check your owner's manual, everything is mentioned.
That's a crude "Jugaad". I remember you mentioning this, but its only if the seat doesn't lock properly, once locked, have never seen this happening.
stormerider is offline   (1) Thanks Reply With Quote
Old 8th November 2013, 14:04   #1780
ebonho's Avatar
Guys
Cheers,
Vikram
I am looking at one of these below. Its imported, and better quality and finish than the cheaper Indian ones.
Will probably go with the C300A as it looks more curvy and aerodynamic than the more boxy X100.
CTrack X100 (this comes in matte black powder coating also, on order)
Tata Safari Storme : Official Review-fordecosportsfrontguardsx100.jpg
CTrack X300A
Tata Safari Storme : Official Review-fordecosportsfrontguardsx300a.jpg
Hope this helps.
Old 8th November 2013, 15:45   #1781
ebonho's Avatar
Audio gurus, I need your help in figuring out my speaker/amp upgrade for my Storme please.
http://www.team-bhp.com/forum/ask-gu...ml#post3287825
Old 8th November 2013, 18:50   #1782
YGarg's Avatar
Thanked: 69 Times
Guys
Haven't seen the "Explorer edition Cargo basket" in person yet, but I think it will hamper the accessibility of rear door to some extent. Also the luggage in it will be more prone to bouncing as well as theft as compared to roof rack. The roof racks suggested by ebonho will suit the Storme better in my opinion.
However (if the requirement of carrying additional luggage is once-in-a-blue moon only), isn't it possible to put luggage directly on the roof and tie it with existing grab-handle type things above third window? Roof sheet metal looks designed for bearing the weight of some luggage!
YGarg is offline   Reply With Quote
Old 8th November 2013, 19:11   #1783
condor's Avatar
Originally Posted by YGarg View Post
.. I think it will hamper the accessibility of rear door to some extent. Also the luggage in it will be more prone to bouncing as well as theft as compared to roof rack. The roof racks suggested by ebonho will suit the Storme better in my opinion.
Rear door movement can get hampered only if luggage is loaded up. But your post leads to a good point:
If there is so much luggage that the rear of the Storme is filled, and hence the remainig luggage is put into this rack, then the luggage in the rear of the Storme (inside) will not be accessible till the luggage in the rack is cleared to allow opening of the door.
So, Narayan, logical that a roof carrier is a much better option than that rack.
.. isn't it possible to put luggage directly on the roof and tie it with existing grab-handle type things above third window?
@YGarg, have you ever seen anyone placing luggage directly on the roof ? They dont do it even on buses !
Old 8th November 2013, 19:28   #1784
YGarg's Avatar
Thanked: 69 Times
Was expecting something like this only from the experts !
However, the slightly recessed and ribbed area on roof gives the impression that it can be used that way too! For frequent requirement, I completely agree with the idea of detachable roof-rack or lockable roof career.
Old 8th November 2013, 19:45   #1785
Thanked: 411 Times
Have you considered possibility of paint damage due to scratches from feet/wheels of luggage ?
Few years back Concord used to have a nice aluminium luggage rack for safari's similar to one in picture posted below in their showroom.
The difference was that the clamps and bolts used to be fitted exclusively on roof rails without touching painted portion.
Check out from Tata dealer just in case they still sell them.
amitk26 is offline   Reply With Quote
Tata Safari Storme 4x4 : Official Review tsk1979 Official New Car Reviews 199 6th March 2018 14:10
