Old 25th March 2017, 09:45   #4411
Thanked: 28 Times
Default Re: Tata Safari Storme : Official Review
From what I understand, the bellow is used to pump fuel to the fuel-pump in a situation where fuel from the tank is not reaching the pump. ( like when fuel in tank is less).
In a situation where the bellow is punctured, the fuel supply would have been affected.
So is there any possibility to by-pass this bellow ( by using a make-shift arrangement like a pipe in place of the bellow ?
Secondly, some sort of protection may help. May be 2-3 layers of metal wire mesh wound around the bellow ?
Well as per the mechanic it cannot be by-passed and the inlet and outlet from this bellow is moulded and airtight.
The issue now is that the bellow available in open market has in/outlet pipes not of same length as original unit and i think some mods have to be done by mechanic...
never realized that this can cause so much headache.:
cheers
PRADEEP KUMAR is offline   Reply With Quote
Old 27th March 2017, 08:43   #4412
n.devdath's Avatar
Thanked: 1,679 Times
cheers
Another option is to scout around the scrap market and find the exact piece. You can take measurements with you and then look for it. I m sure you will find it in Chennai.
Old 27th March 2017, 14:27   #4413
sourabhzen's Avatar
Thanked: 1,276 Times
[quote=PRADEEP KUMAR;4169865]...
/QUOTE]
I hate headaches and would try to avoid doing things that causes headaches. I would have paid Concorde if I was in your place. All manufacturers have overpriced spares and that's how they make money.
sourabhzen is offline   Reply With Quote
Old 31st March 2017, 18:38   #4414
iabhishekkumar's Avatar
Thanked: 94 Times
Originally Posted by garyag79 View Post
I had the same issue last summer, no need to replace the unit. The touchscreen is the culprit. Go to any car stereo repair shop and they will replace the touch screen for anything between 1500-2000 Rs. I replaced mine for INR 1800 and its been working fine for last 8 months.
Thanks for the suggestion, it really worked. I went to the car market @ sector 16, noida and met a person who said he can change the touch screen panel for INR 2000. Took the decision to go ahead and voila! the system is back to working normally.
Let's see how long it lasts? Anyways, thanks a bunch for the suggestion on this. This certainly saved me some bucks that I would otherwise had put on a new HU.
Cheers!
iabhishekkumar is online now   Reply With Quote
Old 31st March 2017, 22:28   #4415
Thanked: 111 Times
No worries should work fine...mine is doing all right
garyag79 is offline   Reply With Quote
Old 1st April 2017, 08:06   #4416
Thanked: 28 Times
Update.
Managed to get the bellow alone(without cables) in Bangalore, was not available in Chennai.Costed Rs 530/.
Local mechanic fixed it (juggad involved) for Rs 300/-
Few thousands saved!!
Storme back in form.
Thanks for all the inputs.
cheers.
Old 1st April 2017, 08:28   #4417
condor's Avatar
Thanked: 4,203 Times
.Managed to get the bellow alone(without cables) in Bangalore...
Local mechanic fixed it (juggad involved) ..
Please share pics ! What was the jugaad that he did ?
Also pls keep checking it for any leaks, since this is path that fuel flows from tank to pump / engine.
Old 26th June 2017, 16:11   #4418
condor's Avatar
Question to owners of the Storme - 2012/2013 -the 320 Nm version.
What is the rpm @ 100 kmph in 5th gear ? 2200 ?
Old 27th June 2017, 17:43   #4419
BulZire's Avatar
Thanked: 132 Times
Friends, need some help.
I am a 2.2 DICOR owner before. Now contemplating on buying a good pre-owned storme. I am planning to check a 2013 LX now. Can you please help me with usual suspects specific to Storme which i should not miss while checking.
BulZire is offline   Reply With Quote
Old 27th June 2017, 17:54   #4420
sourabhzen's Avatar
The usual suspects are either same or less than the Dicor. So, you will be just fine if you know the issues to check in a Dicor.
sourabhzen is offline   (1) Thanks Reply With Quote
Old 8th July 2017, 10:41   #4421
Thanked: 124 Times
Looks like The Storme is the only Safari available now, Dicor is removed very recently from site : http://safari.tatamotors.com/
Current:
Tata Safari Storme : Official Review-safarisitenew.jpg
Recently archived version from Internet Archive,
Tata Safari Storme : Official Review-safarisitearchivejune2017.jpg
Request to Mods: Not able to find any generic Dicor related thread, kindly move the post to other thread if required.
Vishal.R is offline   Reply With Quote
Old 9th July 2017, 14:05   #4422
Thanked: 96 Times
~2000 in very smooth drives - 2200 in slightly uneven ones where you have to keep a heavy foot on the throttle
chinkara is offline   Reply With Quote
Old 9th July 2017, 16:36   #4423
condor's Avatar
How is that ? 100 kmph is 100 kmph. Why do you need to have a heavy foot on the throttle on slightly uneven roads ?
Any one else seeing / experiencing this ?
condor is online now   (2) Thanks Reply With Quote
Old 9th July 2017, 17:17   #4424
vibbs's Avatar
Thanked: 843 Times
I agree. Every engine rpm at a gear should correspond to a particular speed on the road irrespective of the type of road.
I don't think it is possible that engine rpm for a particular speed can vary depending on road conditions unless something in the transmission is slipping (likely case - the Clutch).
vibbs is offline   Reply With Quote
Old 9th July 2017, 19:24   #4425
Thanked: 2,201 Times
A practical observation. I think it can vary. You won't be able to get it to 5 or 10 kmph on a 40% incline at 4000+ m ASL at the same RPM as you would on 0 m ASL. The thin air sucks quite a bit of power out of the engine and to get the same type of response, a higher RPM is needed.
Dry Ice is offline   Reply With Quote
Tata Safari Storme 4x4 : Official Review tsk1979 Official New Car Reviews 198 26th November 2015 19:02
