Old 16th February 2015, 10:09   #2416
tiger_stripes's Avatar
Thanked: 42 Times
Originally Posted by TourBug1974 View Post
2. AC on/off switch heating up: The AC On/Off switch is getting very hot to the touch. So much so, it is almost like I am suspecting an electric loose-connection resulting in a spark-heating inside the switchgear. After about 10 minutes of running, if I need to roll down the window and wanna switch off the AC, the shockingly hot switch gives me a jolt - its probably almost 65-70 deg C. When the AC is switched off, the switch is not heating up. Anybody else having the same observation?
The AC switch does heat up a bit, and has been reported not just by Amaze owners but other Honda vehicle owners as well. But definitely not to the extent you mentioned. I would say it gets warm to touch. So your observation about loose connection may be correct.
tiger_stripes is offline   Reply With Quote
Old 27th February 2015, 21:36   #2417
sixthsense2k6's Avatar
Thanked: 7 Times
Had bad noises from rear since long... Only on rough roads.Got it checked, dealer sent some voice r cording to Honda, thank god its diagnosed as relating to H beam. Going to get it replaced once the spare arrives
Can anybody tell me how much is the price and the actual role of H beam
Want to know whether changing it makes any difference even though it's under warranty
Also guys, any one faced sounds or shake of driver seat
My seat gives me a double jump when car falls into pits on roads
Even for that dealer wants to record the sound and send to Honda
For that I have to keep my vehicle again after H beam replacement
Last edited by suhaas307 : 27th February 2015 at 22:58. Reason: Merging consecutive posts. Please use the EDIT / QUOTE(+) functions within 30 minutes of posting.
sixthsense2k6 is offline   Reply With Quote
Old 28th February 2015, 09:16   #2418
CrAzY dRiVeR's Avatar
Thanked: 17,013 Times
Default Re: Honda Amaze : Official Review
Do you mean the actual H beam itself is damaged, or some part connected to the H beam? H beam is not something that can get damaged that easily.
Anyways yes- you should try to get it replaced under warranty.
CrAzY dRiVeR is offline   (1) Thanks Reply With Quote
Old 28th February 2015, 11:32   #2419
paragsachania's Avatar
Thanked: 10,942 Times
Ertiga, Dzire and Swift had this issue with "kat kat" noise coming from rear when passing speedbreakers and potholes and MSIL recalled few batches and replaced this.
When I enquired with the ASC upon seeing this beam getting replaced on one of the bays, the mechanic said the fault was with "welding" that caused this noise.
The part costed some 13xxx. So I believe Honda Amaze's should be a bit on the higher side but like you say, Honda must cover this under warranty anyway (if it cant recall sensing it to be a one off case).
And I agree on the overall strength of the H Beam. Its super heavy and isn't one of those parts that can easily get damaged as almost the entire rear weight of the car, including passengers is supported by this.
paragsachania is offline   Reply With Quote
Old 28th February 2015, 21:55   #2420
glenmz's Avatar
Thanked: 269 Times
Could this be because of the heat emitted by the led that glows in the switch? Certain LEDs emit bit of heat.
glenmz is offline   Reply With Quote
Old 1st March 2015, 01:40   #2421
speedsatya's Avatar
Thanked: 706 Times
Check one of my earlier posts. The seat rail on my car broke off at22K kms on the RHS due to which my seat also used to shake similar to what you have described here. The dealer TD car also had a similar problem at around the same kind of usage(22-25K kms )
Got it replaces under warranty
speedsatya is offline   Reply With Quote
Old 1st March 2015, 07:21   #2422
geotracks's Avatar
Thanked: 161 Times
Agree. My 2012 Honda City V MT's AC switch also gets warm to touch when in use. I think this topic has been discussed in other forums too. They all say that their respective Honda City car AC switch gets warm, when in use.
geotracks is offline   Reply With Quote
Old 1st March 2015, 12:03   #2423
Thanked: 7 Times
They said its H beam
They have ordered H beam
Hope that it makes some difference in driving
Old 1st March 2015, 12:32   #2424
Thanked: 7 Times
They had test driven
No issues with bolts
So they are not commenting or even trying to even check what's under the seat
Dealer said it requires voice recording and has to be diagnosed by Honda
So I am waiting for the H beam to be replaced so that I can send the voice recordings
Old 1st March 2015, 20:02   #2425
Thanked: 282 Times
Angry Re: Honda Amaze : Official Review
Hi All,
This is in continuation with my earlier post :
http://www.team-bhp.com/forum/offici...ml#post3639197 (Honda Amaze : Official Review)
This was fixed during the service by the Honda guys (Atleast that what they said) 15 days back. But today, this problem has occurred again. Again the fender has gone in in exactly the same place. What should I do?
I am planning to take it to the service center tomorrow. Any advice here about how this should be handled?
This is frustrating me since this is happening repeatedly. And I have to spend so much time and effort running behind this leaving my other stuff
SwatiS is offline   Reply With Quote
Old 8th March 2015, 18:12   #2426
Thanked: 7 Times
Got my H beam replaced under warranty
21k
Thanks to honda this time
Dramatic reduction in rear noises on bad roads
Old 9th March 2015, 00:59   #2427
21k
Have they diagnosed the noises from the seat railings?
Please get that done early as well, as warranty claims regarding seats usually need approval from agents sent by the external vendor (who provides the seats to Honda). Hence the actual warranty claim and replacements might get delayed post fault diagnosis.
Old 9th March 2015, 22:33   #2428
Thanked: 7 Times
Seat noise got fixed by the dealer itself
Last time they said nothing to check or fix, honda diagnostics will only help
But now they have tightened some nut and I couldn't feel the jump this time
Didn't get time to check what fix they have actually given
Old 7th April 2015, 11:54   #2429
Thanked: 388 Times
Friends couple of question about Amaze AC
1. Does Amaza has in-cabin filter for AC ?
2. Is the cooling coil easily accessible or dashboard needs to be removed ?
AC gives foul smell at the start , tried putting it to fresh air mode and turned the setting to hot in order to kill any mould formed on the cooling coil but nothing worked.
amitk26 is offline   Reply With Quote
Old 19th April 2015, 13:11   #2430
Thanked: 7 Times
I am planning to buy a petrol compact sedan in a few weeks. I had a looked at Dzire but it is ruled out by family because of lack of back seat space and tiny boot. I am considering Amaze petrol. The SX variant is 7.27L Delhi with ABS & dual air bags. But I find it much overprice in comparison to Hyundai Xcent. For such a price Honda, isn't even offering Fog Lamps or rear parking sensors!!! Even Alloys are missing! It is certainly not value for money. One thing that certainly goes in favour of Amaze is back seat comfort and space.
Also, I test drove Xcent sometime back and found its brakes too grabby. The car grinds to half even on putting miniscule pressure on pedal. Not comfortable for passengers. It is not the kind of vehicle that you feel right at home ... takes getting used to it. Otherwise for the price it seems to be a nice car (SO petrol variant). Fairly decently loaded with features. I read in some place that although Xcent petrol is a bit down on power on Honda Amaze petrol, it is more drivable. Would be great to know more.
I have been hearing that Ford Aspire is to be launched by May-June period. My interest is again in petrol model but I read at few places that petrol engine might be around 77bhp or so. Given the weight of the car (expected to be around 1000Kg+) this will only result in subdued performance. Could anyone please shed some light on this?
Requesting Honda Amaze petrol owners for their opinion if car is really worth the premium that Honda demands! Please share you view on efficiency, maintenance, performance, OEM Stereo system & overall ownership experience. Will help in making up my mind.
Thanks!
ms_rana is offline   Reply With Quote
Honda Amaze: Oil leak, engine seized! A bad experience with Honda service parimal_g Technical Stuff 165 28th March 2017 22:45
