Old 10th July 2013, 14:13   #1261
Top-Gear's Avatar
Thanked: 112 Times
Default Re: Honda Amaze : Official Review
@Top-Gear; I find the Civic about 12-15% optimistic, while the Brio is about 8%. Now remember you need a differential flow sensor (inflow-outflow) so a few percent error is to be expected. I am a bit surprised by the display being pessimistic, but then it may happen. In the Civic there are two displays, so while I use on for the tank the other I use as a trip meter.
Yesterday when I calculated the average using tankful to tankful method, I found that to be lesser than the digital reading as you pointed out. Don't remember exactly by how much, but it was in the 5-10 % range.
Top-Gear is offline   Reply With Quote
Old 10th July 2013, 16:44   #1262
Thanked: 87 Times
MID Average does not account for fuel evaporation due to heat. Also some MID's do not calculate when the engine is idling. Perhaps that explains the variation?
allajunaki is offline   Reply With Quote
Old 11th July 2013, 09:24   #1263
sgiitk's Avatar
Thanked: 3,797 Times
Infractions: 0/1 (5)
Could ne what you say since my Civic is driver far less than the Brio. But evaporation losses are far less in new cars since the stuff is captured in an adsorbent and then sucked back. Also, I do see the figure dropping esp. when stuck in traffic immediately after filling.
Old 11th July 2013, 09:37   #1264
Thanked: 87 Times
I'm no expert, but I think fuel tanks are still designed to vent out some fuel in order protect the tank from excess pressure. So evaporation is still a factor. Also, from what I have read, Diesel evaporation is less than petrol.
I guess most of the modern MID's do account for idling consumption (My Vento does too).
Old 11th July 2013, 16:47   #1265
Top-Gear's Avatar
Thanked: 112 Times
@ozzyrules; There is far more weight in the Front than the rear. Even the Brio has 29 and 26 recommended, even though it is a petrol
I checked the recommended pressure for my (petrol) amaze again. It's 29 psi for both front and rear tyres . Am I reading it wrong? Can somebody please confirm? Thanks!
Old 11th July 2013, 19:29   #1266
Thanked: 31 Times
Guess it depends on the car. On my A-star and Optra (petrol), the recommended pressure is the same for all 4 wheels.
But, as Sgiitk pointed out, the Brio needs a higher pressure at front.
ozzyrules is offline   Reply With Quote
Old 11th July 2013, 20:36   #1267
Top-Gear's Avatar
Thanked: 112 Times
I agree, but then, let's not forget that the Amaze is Brio's sibling and the 1.2L i-vtec is the same engine. Hence was surprised at the variation in the recommended tyre pressure. Perhaps Sgiitk can throw some light on this.
Old 12th July 2013, 10:46   #1268
sgiitk's Avatar
Quite likely to be so since their is more weight over the rear tyres.
sgiitk is offline   (1) Thanks Reply With Quote
Old 12th July 2013, 12:47   #1269
Top-Gear's Avatar
Thanked: 112 Times
Thank you! I take it to mean that as compared to the Brio, the extra weight of the Amaze at the rear would balance out that of the engine in the front?
Old 12th July 2013, 14:17   #1270
sgiitk's Avatar
Not exactly, you will not get the 50:50 front to rear ratio but it will become more favourable as compared to the Brio. Only a few Beemers and the Alfa's with rear mounted gearboxes, and of course the exotic mid engined lot are in this regime.
Old 15th July 2013, 13:20   #1271
i have a doubt. heard VW Vento ground clearance is not enough and its hitting the speed breakers with 168 mm of GC. How about Amaze with 165 mm Ground Clearance. people who are using please clarify this. I have booked an Amaze - SMT. awaiting your response.
Arjun1010 is offline   Reply With Quote
Old 15th July 2013, 15:45   #1272
mpksuhas's Avatar
Thanked: 3,376 Times
Though not sure if that is the case here, apart from ground clearance wheelbase and over- hang also are major factors.
mpksuhas is online now   Reply With Quote
Old 15th July 2013, 16:29   #1273
Top-Gear's Avatar
Thanked: 112 Times
I personally haven't scraped even once, even with 4 adults on board. Most of the time though, I am alone with my love , so chances of scraping the bottom over speedbrakers, is also low, in all fairness. But I am quite sure it's not an issue as it was with Jazz and Civic.
Old 15th July 2013, 18:08   #1274
speedsatya's Avatar
Thanked: 706 Times
Just completed a 1000 kms drive over all types of roads - 4 laned roads , 2 laned highways , ghat roads with deep potholes , winding roads ,.. With 5 adults and a boot full of luggage. Never had any issues with scrapping the underbody. FE was about 20.5 kpl overall with AC on 60%. Was sticking to 100-120 kph. Top speed is 145 kph , engine hits a limiter at 145 speedo
speedsatya is offline   (2) Thanks Reply With Quote
Old 16th July 2013, 08:32   #1275
rajshenoy's Avatar
Thanked: 641 Times
Wow 5 adults and boot full luggage, yet no under body scrapping on the ghat sections leading to Mangalore(Those who know these roads will understand) means we can officially certify the GC of the Honda amaze to be excellent even under full load
rajshenoy is online now   (1) Thanks Reply With Quote
Honda Amaze: Oil leak, engine seized! A bad experience with Honda service parimal_g Technical Stuff 165 28th March 2017 22:45
