Old 2nd July 2016, 23:28   #3916
Thad E Ginathom's Avatar
Thanked: 7,452 Times
Default Re: Volkswagen Polo 1.2L GT TSI : Official Review
Originally Posted by BlueEyes View Post
. Don't think Polos/GTs ever came with spare remote key.
Yes, they did. My 2012 Polo came with two remote keys. When I found that my 2014 car did not, I thought it was mean cost cutting. I then recalled that the spare key for my previous car had never been out of our spare-key box!
Thad E Ginathom is online now   Reply With Quote
Old 2nd July 2016, 23:36   #3917
Tanveer_2558's Avatar
Thanked: 2,029 Times
Originally Posted by pc1686 View Post
Hi Tanveer,
Can you please suggest where exactly to buy the most genuine OEM steering with paddles as I am very keen on that?
Thanks a lot.
Cheers.
Hello! I have replied to your pm as well have a look, Also you might want to check this thread out.
http://www.team-bhp.com/forum/diy-do...l-upgrade.html (VW Polo DIY: Mk7 Flat-bottom Steering wheel upgrade)
Tanveer_2558 is offline   Reply With Quote
Old 3rd July 2016, 00:15   #3918
highwaypatrol's Avatar
Thanked: 74 Times
My polo tdi 2016 comes with 2 remote keys. By the way can u please tell me how this cornering lights work?? I have never seen my corner lights working when turning left or right with indicators, fog lights and low beam in lit condition..
highwaypatrol is offline   (1) Thanks Reply With Quote
Old 3rd July 2016, 01:00   #3919
Thanked: 51 Times
Its the fog lights that work as cornering lights. So when fog lights are on, nothing will happen Turn off fog lights and turn,you will see fog lamp of that side glowing. Not exactly how a cornering light should work,but i find it useful since i don't drive with fog lamps on.
sid93 is offline   (1) Thanks Reply With Quote
Old 3rd July 2016, 02:42   #3920
It seems like a joke to me. Turn on the fog lamps and you can turn either way!
I do us the fog lamps, a lot, in my city streets.
Thad E Ginathom is online now   (1) Thanks Reply With Quote
Old 3rd July 2016, 13:18   #3921
Thanked: 74 Times
Thanks ... now i realised that the compartment next to fog lamp is actually a dummy as i cant see any bulbs inside. I was under the impression that this corner compartment is one which acts as cornering lights along with the regular fog lamps.
One more change VW brought in the new 2016 polo is the much more brighter LED cabin lights. The new series warm white LEDs are so bright to even read comfortably at night. The one which i took delivery yesterday was a May 2016 make model. Earlier versions seems to be having normal bulbs as my friend who took delivery of the same in 2015 dec confirmed it.
Old 3rd July 2016, 22:11   #3922
redcruiser's Avatar
Thanked: 217 Times
Guys,
I was testing the Cruise Control system in Polo MPI. I observed that in some situations due to the momentum of the car the speed of the vehicle increases than that of the cruising speed. Was testing this feature in one of the ghats section assuming that the car would maintain the cruise speed but i think that does't happen that way. I have not tested it in uphill drives though.
My understanding is that the cruise control can only increase the acceleration to the set speed but it would not brake if the speed is more than the cruising speed.
Any experienced petrolhead please comment who knows the Cruise Control system in and out of VW cars.
redcruiser is offline   Reply With Quote
Old 3rd July 2016, 22:22   #3923
kat
Thanked: 52 Times
Originally Posted by redcruiser View Post
Guys,
Cruise control system doesn't apply brakes but only cuts off the fuel when the current vehicle speed goes above the set speed. So, during downhill driving the momentum of the vehicle is more than enough to create an acceleration effect even though fuel is cut off. I think this is normal functioning of all cruise control systems. And usually in such scenarios, if the vehicle speed goes above the set speed by more than a limit (like 10kmph) , then the cruise control system will automatically switch off cruise control.
kat is offline   Reply With Quote
Old 3rd July 2016, 23:12   #3924
Guys,
If you have activated the cruise control for instance on 100 kph and your going downhill the car will naturally cross the set speed and again maintain 100kph once the surface is flat, The car won't accelerate once the set cruising limit is crossed and when the surface is flat again the car will eventually slow down and again maintain the desired speed.
I actually turn off cruise control on incline and decline both just because i prefer having complete control on incline and declines.
Old 4th July 2016, 10:40   #3925
bharat4ever's Avatar
Thanked: 303 Times
The way I use the cruise control on the Jetta is, i set a speed, say 80 kph when cruising on the highway. In case I need to get a move on to overtake a truck soon, I use the buttons on the steering wheel to increase the speed by multiples of 10, so press it once, and it becomes 90 kph. Once I am done with the overtaking move, I reduce the speed to 80 kph again.
And I swear I can feel the car brake automatically. Tanveer is this how it works?
bharat4ever is offline   Reply With Quote
Old 4th July 2016, 11:12   #3926
redcruiser's Avatar
Thanked: 217 Times
Well thanks for reply.
Ok by knowing the dynamics of CC system,I think it would be best to go uphill with the cruise control set to 15KMPH(for steep incline) in second gear or say 10 KMPH in first gear (incline +traffic).
How about this for a thought. As we know a lot of clutch burnout happens on inclines where you have a stop and go traffic. Is it possible to use CC in such situations ?
Old 4th July 2016, 11:14   #3927
Thanked: 687 Times
Guys,
I was driving around a 2015 Renault Clio last week in France & this had a brilliant version of cruise control that controlled speed both downhill & uphill. It also had the ability to keep a speed limit in memory, which kicks in again automatically if you have to use the brake or accelerator for a short period (15 secs, I think) due to traffic. I thought of researching a bit & found this online:
http://www.motoring.com.au/cruise-co...behavin-17887/
gsurya is offline   Reply With Quote
Old 4th July 2016, 11:28   #3928
Thanked: 51 Times
Default Volkswagen Polo 1.2L GT TSI : Official Review
I guess Jetta has Hill Decent Control, which is why it can brake automatically. Polo can only accelerate to set speed,not decelerate. I haven't tested it by decreasing the set speed,but my GT TSI does shoot the set speed in declines. Ill check and confirm this though. BTW how do you increase speed in multiples of 10? In polo it increases by 1kmph :(
PS: i still cant figure out how CC works in manual transmission. Can we change gears after setting? Or will it disable CC? If yes, i guess its very difficult to use in India.
sid93 is offline   Reply With Quote
Old 4th July 2016, 11:41   #3929
Thanked: 687 Times
I dont think even the latest versions of CC allow changing of gear & retain limit set.
But what I have seen is a clever workaround: allow a short period of acceleration or deceleration while retaining limit. In a Renault Clio I drove last week in France, it was about 15 secs. Just enough to handle traffic & overtaking maneuvers.
Old 4th July 2016, 13:48   #3930
Thanked: 58 Times
CC can only be used for speeds above 40kmph
nova9 is offline   Reply With Quote
VW Polo GT 1.2L TSi: The baby TSi robimahanta Test-Drives & Initial Ownership Reports 324 7th January 2018 00:51
Volkswagen Jetta 1.4 TSI : Official Review Rehaan Official New Car Reviews 121 15th October 2017 21:30
Volkswagen Polo 1.6L GT TDI : Official Review GTO Official New Car Reviews 414 8th October 2017 00:43
Volkswagen Jetta TSI (petrol) spotted. Could be a 1.4L TSI? Y@SH The Indian Car Scene 133 30th June 2012 15:34
