Old 21st October 2013, 17:44   #4951
avm
avm's Avatar
Thanked: 17 Times
Default Re: Ford EcoSport : Official Review
Hi guys!
I got my Orange Baby Beast (1.5P Titamium) on Saturday will post pics soon.
Still cant get over the beauty. Infact I don't feel like parking the car and going home also !!
A couple of doubts which I would appreciate if you guys could answer:
1. The car revs up automatically to about 2.5 RPM when i put it in reverse gear and give a very slight acceleration. your experience in this ? Is it because of a brand new engine ?
2. In the 2nd gear, the car hardly has any pickup till 2 RPM. Your views on this?
3. Huge 'thuds' are faced on potholes / uneven road surface. Any chance of making the suspension more comfortable ?
4. While playing songs through the bluetooth (of the iphone), the screen only shows "connected to my iphone", any chance of removing that text and seeing the name of the song on the display ?
5. Any way to keep the Ecosport lady mum as soon as we connect the phone to the bluetooth? Everytime I connect the phone, she says "Phone connected via BT and emergency assist is set to off/on"
6. If the car switches off on the road, do we always have to turn the ignition fully off and then start again ? This takes time and the impatient population of India cannot control their horns.
Would really appreciate your help on these issues.
Cheers!
avm is offline   (1) Thanks Reply With Quote
Old 21st October 2013, 18:06   #4952
raj84's Avatar
Thanked: 146 Times
Originally Posted by ecosport rules View Post
Beware of the quality , most of them are rubber mudflaps on ebay
Thankfully the one I got from ebay.in was plastic type and matches the OEM one in look , feel and material. I have seen mud flaps in Aliexpress though, which are rubber made and flexible.
raj84 is offline   Reply With Quote
Old 21st October 2013, 18:30   #4953
ecosport's Avatar
Thanked: 164 Times
Not in my 1.5P AT.
True. Somebody even called this "turbo lag"
And to make matters worse, the AT up-shifts as soon as the rpm crosses 2K rpm. Since yours is the MT, you can work your gears to stay above the 2K range.
ecosport is offline   (1) Thanks Reply With Quote
Old 21st October 2013, 19:53   #4954
arunphilip's Avatar
Thanked: 4,761 Times
Originally Posted by penpavan View Post
Until around 1000KMS I did not cross 2500 RPM but from 1000 to 1500 I drove at around 3000-3200 RPM.
You limited yourself to 3000 rpm until 1500 kms? You must have the patience of a saint! I'm following the approach of max 3000 rpm, but allow occasional 4000 rpm in lower gears (1st - 3rd) - my rationale being that the torque multiplication through gearing in those gears ensures that the engine is not strained. The surge of acceleration in those gears - addictive, especially when combined with a muted engine sound, when compared to diesels!
Originally Posted by ecosport View Post
The MID is pretty distracting. The moment it falls below 10 kmpl, I start panicking. BTW, I reset it for every trip.
I reset the MID for fuel consumption/average speed during every tankful, not each trip. With that approach, I've found the MID is very close to the tankful calculation... close enough within the margin of error. I'm a little irritated at Ford for not offering a 2nd trip meter - my dinky old low-end Getz has two trip meters!
Originally Posted by roy_libran View Post
It somehow tends to pull my eye towards it, even while I am driving to look at the real-time kmpl bars. I go gloomy when it momentarily goes as low as 5 kmpl and start smiling the next moment when it goes over 15!
I think you're referring to the instantaneous indicator (i.e. the bar chart at the top of the MID), while I was referring to the average mileage indicator (accessed through the TRIP button on the left stalk).
I actually like the instantaneous indicator - while it is scary to see it nearly disappear during hard acceleration, it did teach me the following points:
  • Shifting down at low engine speeds improves mileage
  • Coasting in gear gives 30+, but coasting with the clutch pressed gives lesser (the latter is dangerous, but people think it helps mileage)
3. Huge 'thuds' are faced on potholes / uneven road surface. Any chance of making the suspension more comfortable?
Congratulations on your car, glad it was well worth the wait!
The huge thuds are scary - the first time I heard it I thought: "There go my alloys, there go my sidewalls". Turned out to be much ado about nothing. I get this sound despite running at the max recommended pressure (35 psi) at the front. I now try to brake before the bump/pothole to bleed speed, and release the brake just before the bump/pothole to unload the suspension and increase its travel.
I don't recall the exact setting, but I fiddled around with the options in the Sync menu on the center console, and I've turned the voice announcement off. The screen still shows the text that I've connected my phone and have emergency assistance on.
arunphilip is offline   (1) Thanks Reply With Quote
Old 21st October 2013, 20:50   #4955
HillMan's Avatar
Thanked: 401 Times
It is safer to stay in gear, than glide in neutral or clutch. Modern engines cut off fuel supply while coasting, thereby improving mileage.
We had a little discussion on another thread. Your observation with the instantaneous indicator proves the point, as well.
http://www.team-bhp.com/forum/techni...ml#post3260554 (Do High RPMs result in unburnt fuel?)
HillMan is offline   Reply With Quote
Old 21st October 2013, 20:58   #4956
ecosport rules's Avatar
Thanked: 1,342 Times
Originally Posted by TSIched'Out View Post
Whenever I park my EcoSport after driving, i see a small pool of some liquid (most likely water) under the car. Is it water coming out from AC and is it normal for EcoSport? Have checked the Owner manual but it is not covered anywhere. Also, I haven't seen this in any of my other cars or may be haven't noticed.
Dont worry it is definitely the condensation water from the airconditioner, it happens in all cars and you can see it depending on where the drain is located.
Actually, few drops are ok but I'm getting a small pool every time. Was wondering could this be because of leakage in cleaning water reservoir and also if any BHPian has experienced this kind of leakage? Will get it checked nevertheless and post if there are any issues with cleaning water reservoir.
It happens to my car also , it is completely normal
[quote=arunphilipThe huge thuds are scary - the first time I heard it I thought: "There go my alloys, there go my sidewalls". Turned out to be much ado about nothing. I get this sound despite running at the max recommended pressure (35 psi) at the front. I now try to brake before the bump/pothole to bleed speed, and release the brake just before the bump/pothole to unload the suspension and increase its travel.[/QUOTE]
The specific problem of thud was irritating me for a long time.I contacted ford and they couldnt even understand the problem.I had no choice but seek outside help, I called srinivas gopal from satya gopal auto and he send me these buffers I am attaching in the pictures below.
My problem got solved like magic.
ecosport rules is offline   Reply With Quote
Old 21st October 2013, 21:50   #4957
The buffers pictures were not uploaded due to some problem.
ecosport rules is offline   (6) Thanks Reply With Quote
Old 21st October 2013, 22:55   #4958
ecosport's Avatar
Thanked: 164 Times
Now that you know that the MID is accurate, you just rendered it redundant if you plan to continue with checking the tank full method. Checking FE of different runs is fun. At least when you are still discovering. My office commutes give me 9.7. Ecity to Silk Board gives me 20. The drive back gives me 17. etc.
Oh, if she could be silenced, it would be a huge relief. I don't use any voice commands, and don't plan to use it ever. I hate talking to machines, and don't want machines talking to me either.
ecosport is offline   Reply With Quote
Old 22nd October 2013, 00:27   #4959
adi_petrolhead's Avatar
Thanked: 1,024 Times
Hope I can post this here. Just last week I was driving quite leisurely and as I crossed a speed bump and depressed the accelerator pedal, a sign pops up in the MID. "Engine Malfunction, Service Now!" I was shocked. I went to the service center next day itself and got it checked, indeed an error was visible in the error log, a throttle error. But the sign did not appear once i had shut the car off and restarted it again. Service center could not answer me properly and said there is nothing wrong, and I can come back when I see the error again. The same error popped up again yesterday. Went to service center and gave the car for a day for a thorough check up. I don't know what to expect from the service center tomorrow! Any one else with a similar error? Pardon my ignorance if I have not read the entire thread post by post.
The error in the MID:
adi_petrolhead is offline   (2) Thanks Reply With Quote
Old 22nd October 2013, 00:56   #4960
ACM
ACM's Avatar
Thanked: 2,652 Times
Have you installed the buffers.
Price?
Where from? - Contact?
Thanks in advance.
ACM is online now   (1) Thanks Reply With Quote
Old 22nd October 2013, 01:13   #4961
johannskaria's Avatar
Thanked: 1,545 Times
Hey i'm a novice in the area.
could please tell me how does a buffer work?
I haven't faced a similar thud from my car when on puddled roads.
johannskaria is offline   Reply With Quote
Old 22nd October 2013, 09:05   #4962
arunphilip's Avatar
The specific problem of thud was irritating me for a long time.I contacted ford and they couldnt even understand the problem.I had no choice but seek outside help, I called srinivas gopal from satya gopal auto and he send me these buffers I am attaching in the pictures below. My problem got solved like magic.
Thank you, let me check into this.
OT: On the box, it says "tenacious", "and so on"... is this Chinglish or a good sense of humour on the manufacturer's part? Looking at the packaging, I suspect the former
Buffers are flexible strips of rubber (or silicone, as it appears in ecosport rules' post) that are inserted into the coil spring in the suspension, to prevent the suspension bottoming out under load/compression.
Read this excellent thread by GTO: http://www.team-bhp.com/forum/techni...uspension.html (Coil Spring Adjusters : VFM Fix for the Honda Civic's (lousy) soft rear suspension?)
I'd heard about coil spring adjusters a short while back, and was willing to try, especially since it's a cheap mod widely used by Forum'ers across the globe. Cost = Rs. 4,000 - 4,500 for a set of 4, and 1/2 of that for only the rear (including installation charges)... This part is very popular in the UK, especially amongst station wagons without self-levelling rear suspensions.
You can install coil-spring adjusters at the top of the spring (working at all times), in the middle (effective under mild to full load) or at the bottom (comes into play only under full load).
Old 22nd October 2013, 09:31   #4963
penpavan's Avatar
Thanked: 133 Times
I am wondering which roads you travel in Bangalore where you can reach 4k RPM in city? (I read that your driving is 100 percent city)
penpavan is offline   Reply With Quote
Old 22nd October 2013, 09:45   #4964
naveen.raju's Avatar
Thanked: 3,314 Times
Dude, I got the same error yesterday. I had taken the car to a ghat section this weekend and while coming back I got this error. It's supposed to be a powertrain malfunction due to sudden acceleration and deceleration. I switched off the engine and everything went back to normal and didnt notice this error during the next 120 odd kms. My car will be up for service next week so will be reporting this error to them. Any news kindly keep me posted.
naveen.raju is offline   (2) Thanks Reply With Quote
Old 22nd October 2013, 09:49   #4965
anks_at's Avatar
Thanked: 59 Times
Kindly keep us posted too regarding this here. If its occurring with a few more people, maybe its an area which Ford needs to look at for all the Ecosports.
anks_at is online now   Reply With Quote
Car for Parents: Hyundai Verna vs Ford EcoSport vs Ford Classic vs Maruti Ertiga iTNerd What Car? 60 12th October 2014 07:53
Ford EcoSport DIESEL Review GTO The Indian Car Scene 0 31st May 2013 11:51
