Old 28th January 2014, 16:59   #6391
ecosport rules's Avatar
Thanked: 1,350 Times
Default Re: Ford EcoSport : Official Review
Originally Posted by bharat4ever View Post
Read through your thread. The lamps look amazing, but at this point of time it's too expensive. I would just go for a headlamp bulb upgrade right now, and switch to that gorgeous headlamp cluster when it becomes more mainstream.
Any bulb upgrade suggestions please?
Originally Posted by sunilg33 View Post
I upgraded to Philips extreme vision and it gives an improvement of 40-50% over the stock ones. Costed me 1050 for a pair.
If you are looking for just changing stock bulbs, I would suggest Hella powerlight which is much better than Philips extreme vision.
I am so sure because I had the opportunity to compare Hella powerlight,Philips extreme and Osram night breakers.
Originally Posted by siddarthbh View Post
One of the reasons for the large waiting time is that Ford is exporting a substantial number of EcoSports. Although this was known, it kind of hit me on my recent trip to Chengdu, China where i saw more Ford EcoSports in a span of two weeks than i have seen in Bangalore!
Ford India does not export to China as they have a bigger factory in China to cater domestic and export market.
They have even started to manufacture the Ecoboost engine.
Ford China exports to more countries than Ford India.
ecosport rules is offline   (4) Thanks Reply With Quote
Old 28th January 2014, 17:28   #6392
Thanked: 13 Times
I was unaware of this.
That explains the large numbers of EcoSports i saw. Many thanks for the info.
siddarthbh is offline   (2) Thanks Reply With Quote
Old 28th January 2014, 20:28   #6393
Thanked: 25 Times
Will upgrading only the bulb help? Pardon me for the ignorance, but what else can be uprgraded other than the bulb? And how much will that upgrade cost?
I am taking the delivery in a couple of days.
Thanks.
pc1686 is offline   Reply With Quote
Old 28th January 2014, 21:24   #6394
Originally Posted by pc1686 View Post
Will upgrading only the bulb help? Pardon me for the ignorance, but what else can be uprgraded other than the bulb?.
Hello Pc1686,
I have upgraded my headlight unit with projectors, DRLs and 5000K HID kit.
Please refer to the pictures and the posts on previous page.
Also refer to all the pages of my initial ownership thread, click on the link below.
http://www.team-bhp.com/forum/test-d...red-india.html
NOTE:
Upgrading only the bulb partially solves the problem as I done it earlier but the permanent solution is projectors with HID kit.Here are some pictures for your understanding.
Hope this helps.
ecosport rules is offline   (3) Thanks Reply With Quote
Old 28th January 2014, 21:33   #6395
Thanked: 25 Times
Hello Pc1686,
NOTE:
Hope this helps.
Thanks ecosport rules
How much do projectors with HID cost?
And if I want to upgrade only the bulb, can I take the bulbs (Hella powerlight as you have suggested in a previous post) to the dealer while taking the delivery and get it changed from him only?
Old 29th January 2014, 00:45   #6396
I am not aware of the current prices of HID kits but you can contact Mr.Srinivas Gopal of Satya gopal auto. (9849314812)
Hella powerlight can be installed by the dealer or yourself
ecosport rules is offline   (2) Thanks Reply With Quote
Old 29th January 2014, 10:11   #6397
naveen.raju's Avatar
Thanked: 3,658 Times
Philips extreme vision is the most common upgrade. As the wattage is same, it's just a plug n play setup. Should cost around 1200-1300.
Another option is to upgrade to 90/100w setup. This would need extra set of relays, ceramic holders and wiring kit. Extra wattage means Ford might void the electrical warranty.
HID's alone will cost around 8k-10k. HID's on reflector headlight assembly not recommended as it will scatter the light and blind oncoming traffic.
HID's+Projectors can cost 25k-30k where 4300k (color temperature) HIDs are recommended.
I have used all the above in my Swift and found HID's + projectors the best (not good in rains though). Planning to go for extreme vision in couple of months and 1 year down the line I might go for projectors. Waiting for some cool looking aftermarket kits.
naveen.raju is offline   (1) Thanks Reply With Quote
Old 29th January 2014, 10:27   #6398
Thanked: 25 Times
Is the wattage of Hella Powerlight different? What is the specification and where can these be purchased?
What is the model of Hella and specs?
Thanks.
Old 29th January 2014, 10:53   #6399
Wattage is same (stock). AFAIK, it's 5000k (color temp) bulbs and will provide around 25-30% more light. I think you can check JC road for the bulbs.
Old 29th January 2014, 11:38   #6400
Thanked: 12 Times
Hi Everybody,
Going to get delivery of my Sea Gary 1.5P Trend by this weekend, I am very excited. I had booked it in first week of July 2013.
Can anybody help me to decode the VIN?, which I received from dealer. VIN is MAJAXXMRKAEL17134. Thanks in advance.
ksanjeev30 is offline   Reply With Quote
Old 29th January 2014, 11:49   #6401
lijodavis's Avatar
I just want to install DRL only. Can any one tell how much it will cost?
Can i get it done at kochi, kerala? Have any one of ecosport owner in kerala done this?
lijodavis is offline   Reply With Quote
Old 29th January 2014, 13:00   #6402
Thanked: 13 Times
I also have DRLs lying with me for quite sometime. Wondering if the DRLs can be installed through the headlamp/parking lamp holes without opening the lamp assembly?
Anuraj Ennai is offline   Reply With Quote
Old 29th January 2014, 13:04   #6403
Thanks.
As Naveenraju said you can buy these bulbs anywhere.
Philips extreme vision is widely available hence most commonly bought, Hella power light is a little difficult to get hold of.
The wattage is 55w, same as the original
Colour temperature is 3000 to 3500Kand not 5000K(it is not possible for halogens to emit that colour temperature)
ecosport rules is offline   Reply With Quote
Old 29th January 2014, 13:43   #6404
You can get it online for around 3k-3.5k. TBHPian johannskaria from Thrissur got projectors and DRL's. You can contact him for more details.
Are you talking out the same kind of DRLs that member ecosport rules got? If so, you will need to open the headlight assembly to install it. There's already a provision for the DRL's.
Old 29th January 2014, 14:04   #6405
Originally Posted by ksanjeev30 View Post
Hi Everybody,
Congratulations on you new car.
Wildon is our distinguished bhpian who is an expert at decoding VIN numbers.
Follow the link.
http://www.team-bhp.com/forum/buying...cture-vin.html (ARTICLE: Find your car's date of manufacture (VIN))
No kind of DRL can be installed through the parking hole.
You have to open up for any of DRL fixing unless you want to stick it outside the head lamp which will look very ugly.
Ive seen some guys do that hideous job.
ecosport rules is offline   (1) Thanks Reply With Quote
Car for Parents: Hyundai Verna vs Ford EcoSport vs Ford Classic vs Maruti Ertiga iTNerd What Car? 60 12th October 2014 07:53
Ford EcoSport DIESEL Review GTO The Indian Car Scene 0 31st May 2013 11:51
