Old 16th July 2014, 13:00   #7666
wysiwyg25's Avatar
Thanked: 37 Times
Default Re: Ford EcoSport : Official Review
Originally Posted by sunilg33 View Post
1st Service(2500KM) and 2nd service(10000km) are free. So no labor charges will be there for these 2 services but consumables like engine oil, break pads etc have to be paid.
So if its just a normal service with engine oil and oil filter change then it should be approximately 2000 Rupees.
Here is the break up:
Engine Oil 4.1L 329 per litre - 1349
Oil Filter - 474
Gasket - 64
Wiper washer fluid - 65
Wheel alignment - 400
Wheel balancing 560
Ac Disinfection - 1200
wysiwyg25 is offline   Reply With Quote
Old 16th July 2014, 13:11   #7667
sunilg33's Avatar
Thanked: 130 Times
Oil Filter - 474
Gasket - 64
Wheel balancing 560
Wheel Alignment and balancing have been billed extra, its part of the free service. Also AC disinfection in not necessary unless you are facing an issue with AC. So approximately 2200 + taxes has been billed extra.
sunilg33 is offline   Reply With Quote
Old 16th July 2014, 13:13   #7668
Thanked: 897 Times
Wheel balancing 560
In my opinion, all other costs are reasonable enough, except the two quoted above.
Rs. 560 for Wheel Balancing is very expensive, and probably could have been done outside for less than half this price. The Wheel Alignment cost is more or less fair, but was it necessary?
AC Disinfection, may also have been an optional job, and probably only entails cleaning of the cooling coil and filter, and could have been done much cheaper.
roy_libran is online now   Reply With Quote
Old 16th July 2014, 13:18   #7669
wysiwyg25's Avatar
Thanked: 37 Times
I checked with Saifee tyre in Santacruz and they are charging 1200 for Wheel balance and alignment.
Old 16th July 2014, 13:18   #7670
mayankk's Avatar
Thanked: 3,559 Times
2nd service mentions only engine oil and oil filter, in the owner's manual I believe.
gasket and washer were probably needed(which gasket, though?)
The rest, you must have been informed beforehand.
mayankk is offline   Reply With Quote
Old 16th July 2014, 13:21   #7671
wysiwyg25's Avatar
Thanked: 37 Times
I refused the Ac disinfection (not really needed) so total bill is now 3100++
Old 16th July 2014, 13:32   #7672
Thanked: 897 Times
I pay Rs. 350/400 for 3D Wheel Alignment. Typical Wheel Balancing costs around Rs. 300 (inclusive of weights) for my Truck's tires, which are inherently not very balanced.
I'm not sure about Mumbai rates, but 1200 seems very high.
Old 16th July 2014, 13:54   #7673
Thanked: 716 Times
Engine sump plug gasket. It is a crush washer and not reusable.
It is a typical wheel alignment charge even at Ford, around 1000 is standard. They charge high for the wheel weights. Inflation might have caught up with it, i guess.
For those who have time, it is better to do it outside.
ramzsys is offline   Reply With Quote
Old 16th July 2014, 16:04   #7674
ACM
ACM's Avatar
Thanked: 2,892 Times
Default Service Inerval Reset
Am not sure if the below procedure used to reset the Service Interval for the EcoSport has been shared earlier in this thread.
In case the Service interval alarm pops up in either the Infotainment display or via an amber light in the speedo display area with the comment that the Oil change is due then it can be reset as mentioned below. This is assuming that the alarm has popped up earlier than the correct interval (Say for example after the vehicle is serviced at 10,000 kms if it comes up at 15,000 kms itself and well before a year has passed instead of at 20,000 kms / 1 year. )
1) We must place the vehicle in Neutral on a flat surface. Keep the hand brake disabled
2) Switch OFF the AC and Infotainment unit(Centre Deck).
3) Switch OFF the Engine.
4) Press the Brake and Accelerator Pedals firmly right to the bottom for 5 mins. (Use left leg for brake and Right leg for Accelerator)
5) Release the Pedals.
6) Restart the vehicle in N position.
I did this for my AT it worked. Am given to understand that this is the same procedure for all the variants.
ACM is offline   (1) Thanks Reply With Quote
Old 16th July 2014, 16:19   #7675
naveen.raju's Avatar
Thanked: 3,726 Times
Default Re: Service Inerval Reset
5 min? This is what I did.
Press the start button (or turn the ignition) and wait for the service reminder to come. Once that's displayed, press the accelerator and brake together and hold it for 30 seconds. The reminder will disappear and will appear for the next service.
naveen.raju is offline   (1) Thanks Reply With Quote
Old 16th July 2014, 23:00   #7676
karan561's Avatar
Thanked: 10,549 Times
Cool, that was fast! So not much waiting period nowadays?
Anyway, get an ownership review - with appropriate attire for the Urban SUV
Took the delivery of the Ecosport today morning;
Ford EcoSport : Official Review-10533550_10152342668027762_1395660525870547482_n.jpg
Already clocked about 350 kms on her as had to take her to Gujarat for registration.
Drove the car through a massive downpour today en route Silvassa on NH8.
Initial impressions are that the car has a light steering fantastically suitable for tight traffic conditions on the other hand weighs up well on high speeds.
The DCT felt superb & gear changes were fast.
The 1.5L Petrol felt lifeless < 3k rpm, hoping it will be performing better between 3-6k rpm (haven't pushed her yet coz running in)
Disheartened by the fact that i've got MRF's as stock & not the Good Years
Music system is of good quality & good on bass.
Seats are well laid out & ideal driving position can be achieved quickly, on the other hand steering adjustment for 'reach' was missed.
Got a decent FE of 12.4 km/l for the round trip, hoping it will increase to low 14's for highway runs after the engine is free.
Rest shall update in the coming few days & shall shortly start an ownership thread
karan561 is offline   (9) Thanks Reply With Quote
Old 16th July 2014, 23:32   #7677
Thanked: 38 Times
Thanks guys this was really helpful as im getting the delivery of my Ecosport A/T tomorrow morning from the stockyard
Also this is one of the cars that i booked without a test drive nor visited the showroom to have a look, looking forward
Congrats.. I have also booked an AT and am still waiting for like a month now.. how long did u have to wait?
bharathan is offline   Reply With Quote
Old 17th July 2014, 01:34   #7678
maverickrider00's Avatar
Thanked: 12 Times
Hello, fellow bhpians, absurd it may seem but being a jerk actually pays when you are dealing with the Ford dealers as far as the ford Ecosport is concerned. During the waiting period badger them as much as possible, threaten with possible consumer forum cases if possible and finally when you get the car be adamant not to take the insurance (if not reasonably quoted) or the unwanted accessories from them. During service ensure that they actually service the vehicle and be careful about what they add in the bill. only then will you find them treating you like a proper client, expecting Maruti, Honda and Hyundai like customer service from Ford at the dealer's end is impossible but the above tricks work.
Moderators, kindly omit the above lines if it is out of topic or extreme.
By the by, I went for my first service which was basically a formality of sorts but I did insist that they do the entire service in front of me. Infact I had prepared a list(from the owners manual) as to what is supposed to be done in the first service, the inspections, replacements etc, which I gave to the service engineer. The "jerk" in me gets the better of my "gentleman" nature whenever I am in the Ford dealership, perhaps the aftereffect of a bitter waiting and later buying experience. The jerk factor worked and the service formality stretched to an entire day with me installing the fog lamps( mine is a TDci Ambiente) for a reasonable amount of Rs.8490 when initially they were quoting 9500. Overall was satisfied with the service.
As for my Ecosport, it was worth waiting every second of the 7 months and 11 anxious days peppered with numerous arguments sometimes resulting in near fist fights at the dealership. All those who are waiting, as long as Maruti Alpha, Chevrolet Adra or the Hyundai Compact suv is not out, the Ford ecosport is simply the best out there, so hold on to your booking numbers, it is definitely woth it.
maverickrider00 is offline   Reply With Quote
Old 17th July 2014, 09:57   #7679
blacksport's Avatar
Thanked: 546 Times
Reach adjustment is present, you might have missed it.
The 1.5AT gives good mileage in the highways. After being depressed that am getting sub 10kmpl in my city runs, I took my car on NICE road, and the 60km run returned me 19kmpl.
blacksport is offline   Reply With Quote
Old 17th July 2014, 10:49   #7680
TB16's Avatar
Thanked: 33 Times
What is the current waiting period for the 1.5 Automatic in New Delhi? Are they taking any new bookings?
TB16 is offline   Reply With Quote
Car for Parents: Hyundai Verna vs Ford EcoSport vs Ford Classic vs Maruti Ertiga iTNerd What Car? 60 12th October 2014 07:53
Ford EcoSport DIESEL Review GTO The Indian Car Scene 0 31st May 2013 11:51
