Old 8th September 2014, 12:52   #7996
naveen.raju's Avatar
Thanked: 3,251 Times
Default Re: Ford EcoSport : Official Review
Originally Posted by bharathan View Post
So if one decides to go for just the bulbs and not HIDs, is it better to go for a projector setup or just stick to the reflectors?
I would say normal bulbs for reflectors and HID's for projectors. This is just my personal opinion from what I have experienced from using different combinations.
naveen.raju is offline   Reply With Quote
Old 8th September 2014, 13:14   #7997
Seran Manian's Avatar
Thanked: 269 Times
I think projector arrangement has more to do with giving a focused light output that falls in the area of the road that it is designed to throw light and hence you get your area of interest getting illuminated better and other areas not so. This also helps in avoiding glare to the vehicles coming in the opposite direction.
There is website that throws more light on this topic. You may also refer to Wikipedia.
http://oppositelock.jalopnik.com/hea...ned-1262237738
Seran Manian is offline   Reply With Quote
Old 8th September 2014, 13:29   #7998
A small update: Felt covering in the wheel arch
Many owners might have noticed that there's a felt cloth covering in each wheel arch. Here's what happens in the long run. This felt cloth tends to soak up water and becomes heavy to the point where the clips wont be able to support the weight. In my cousins ride, it gave way and he found it resting on the tyre (good thing he didnt drive the car as it may end up coming off and getting stuck in the wheel causing further damage). To repair this, it's around 1k+ for a single wheel arch. Luckily it was covered under warranty and he only had to pay for the clips. After this incident, I checked my car and it seems the felt covering is a bit loose. Think I will have to fix this during my next service. So look out for this guys!
naveen.raju is offline   (4) Thanks Reply With Quote
Old 8th September 2014, 14:27   #7999
ranjithrnair's Avatar
Thanked: 81 Times
A small update: Felt covering in the wheel arch Many owners might have noticed that there's a felt cloth covering in each wheel arch. Here's what happens in the long run. This felt cloth tends to soak up water and becomes heavy to the point where the clips wont be able to support the weight. In my cousins ride, it gave way and he found it resting on the tyre (good thing he didnt drive the car as it may end up coming off and getting stuck in the wheel causing further damage). To repair this, it's around 1k+ for a single wheel arch. Luckily it was covered under warranty and he only had to pay for the clips. After this incident, I checked my car and it seems the felt covering is a bit loose. Think I will have to fix this during my next service. So look out for this guys!
It's the same with my car as well, for some reason after first service the rear left side became so loose that a portion of it scrape the tyre causing it to further loose it's stiffness . Believe that there should have been more clips to hold to prevent this from happening.
1k is to replace the whole felt with new one or to repair the old one ?
ranjithrnair is offline   Reply With Quote
Old 8th September 2014, 14:35   #8000
jojoinassi's Avatar
Thanked: 95 Times
Happened with mine too
Had taken it to the service centre.They told that they have put it across Ford and we might get a solution soon.The newer Ecosports have a slightly different material(less water absorbing and so stays more stiff).So this is going to be a problem for the early Ecosports and will be more problematic in places like Kerala with incessant rains.
What the they did for me was to put an extra screw with washer to hold the thing in place
Wish they replace it with something proper
jojoinassi is offline   (1) Thanks Reply With Quote
Old 8th September 2014, 14:43   #8001
arunphilip's Avatar
Thanked: 4,750 Times
Great - now I feel like running down to my car in the office basement just to check this
And what is the screw affixed to? The metal of the wheel well? If yes, did they take any precaution to protect the metal from rusting at the hole?
arunphilip is offline   Reply With Quote
Old 8th September 2014, 14:47   #8002
jojoinassi's Avatar
Thanked: 95 Times
I had asked them specifically about the same. They told it won't be a problem.
Keeping my fingers crossed
Old 8th September 2014, 14:50   #8003
1k to replace it with a new felt and clips for one wheel arch. This is noticeable for the rear wheel arch as the area is more.
naveen.raju is offline   (1) Thanks Reply With Quote
Old 8th September 2014, 17:19   #8004
Thanked: 37 Times
Originally Posted by blacksport View Post
Airbag compatible seat covers are available from a lot of car makers. One can be cynical about whether they are tested properly, but then, you can be cynical about almost anything, including the airbags themselves.
This seat covers they are selling looks like a genuine accessory, and has a part no. I called the dealer and checked. After trying to sell me third party covers, when I insisted that he look in the inventory for the particular part no, they confirmed that it exists, at 7100 per set plus 800 for fitting. Am going to check it out, and buy only if the airbag compatible tag is present on it.
It would take expert design and proper testing, and the testing alone would waste quite a few expensive airbags*. Call my cynical, but it doesn't seem very likely to me.
*And maybe a vehicle or three!
Originally Posted by autoenthusiast View Post
I don't think they would be from Ford, would be a ford dealer sourced option. I bet ford too wouldn't advise any kind of seat covers. Coming to the second point of whether they are tested, I'd seriously doubt that....
Check out the following URL, with the difficulty in sueing someone if something goes wrong, I doubt our seat cover makers would be too concerned about ensuring their seat covers won't adversely affect the airbag operation.
http://www.deploysafe.com.au/About_U...at_Covers.aspx
I have to agree with blacksport here. I mean testing even front airbags will cost them Airbags and cars. So adding a seat cover to test the side airbag and the seat cover compatibility will not hurt them more.
Also curious - if the front passenger airbags are strong enough to deploy though the dashboard made of plastic, why wouldn't the side airbag tear through a seat cover which has been provided by the company?
bharathan is offline   (1) Thanks Reply With Quote
Old 8th September 2014, 19:40   #8005
mooza's Avatar
Thanked: 246 Times
Finally got my Mars Red Ecosport Trend Petrol 1.5 MT, after 3 months of waiting.
It's been worth the wait, love most things about the car:
Attachment 1284753
mooza is offline   (2) Thanks Reply With Quote
Old 8th September 2014, 21:22   #8006
Thad E Ginathom's Avatar
Thanked: 7,468 Times
No, they don't, and if they did you would have shards of plastic in your face. The dashboard is designed to open up under the force of the airbag. To be honest, I have always wondered where that panel goes, but I'm pretty sure it is designed to fall away. In our faces would defeat the object of the airbag.
Old 8th September 2014, 22:07   #8007
arunphilip's Avatar
Congratulations on your car. That colour is like a chameleon... in this picture there's no hint of the orange, instead it appears like a mature red
arunphilip is offline   (1) Thanks Reply With Quote
Old 9th September 2014, 13:59   #8008
sunilg33's Avatar
Thanked: 130 Times
Completed the 30k Service at 28k and the Bill was 6564. Service was done at Metro ford hesarghatta branch.
Repairs carried out: Engine oil replacement, fuel filter replacement, Wheel alignment, balancing and tyre rotation.
Ford EcoSport : Official Review-img_20140909_134707103.jpg
Ford EcoSport : Official Review-img_20140909_134830897.jpg
sunilg33 is offline   (3) Thanks Reply With Quote
Old 9th September 2014, 15:32   #8009
jojoinassi's Avatar
Thanked: 95 Times
A small query
In my 30K service,Rs 3397 was charged under the heading, "filter assy fuel".Any difference between just oil filter and this?
Because the cost difference is significant
jojoinassi is offline   Reply With Quote
Old 9th September 2014, 15:38   #8010
Thanked: 704 Times
A small query
For you, the entire filter assembly(including water in fuel sensor) was changed; and for sunilg33, only the element inside filter assembly was changed.
ramzsys is offline   (2) Thanks Reply With Quote
Car for Parents: Hyundai Verna vs Ford EcoSport vs Ford Classic vs Maruti Ertiga iTNerd What Car? 60 12th October 2014 07:53
Ford EcoSport DIESEL Review GTO The Indian Car Scene 0 31st May 2013 11:51
