Old 17th August 2016, 19:06   #10531
johnruben's Avatar
Thanked: 74 Times
Default Re: Ford EcoSport : Official Review
Originally Posted by Uprasenjit View Post
I used to have the ABS plastic engine guard by Ford and it worked well. Suddenly yesterday while I was checking the underbody noticed the skid plate is no longer there. A entire engine guard has disappeared.
This reminds me that the guard was attached to the body with 4 nut bolts. Last couple of days I have been driving one a very bad patch and those nuts somehow either got loosened or broke.
The skid plate is very very essential for me, hence I need another one. But I am not going to buy the same material again. In Aliexpress found one aluminium skid plate, how do you think this will be -
http://www.aliexpress.com/item/High-...a-02cf0123d97f
Anyone here has any aftermarket engine guard ?
Hey, I was told by ford guys not to put a metal one, since it has been designed in such a way that during a crash the engine will dismantle itself and fall to the ground, and equipping the bottom with metal is not recommended and tested for that. I would suggest you ask the ford guys about your old engine guard as it costs ~8k and it cannot fall by itself just like that.
johnruben is offline   Reply With Quote
Old 17th August 2016, 21:29   #10532
sunilg33's Avatar
Thanked: 130 Times
The engine guard we have made is made of aluminium and can take minor hits from stones. No engine guard can take a car crash and protect the engine. Can you then explain how sturdy metal engine guards from the company in other cars work during a crash?
sunilg33 is offline   Reply With Quote
Old 17th August 2016, 21:49   #10533
johnruben's Avatar
Thanked: 74 Times
Actually when i booked my vehicle, i told them i would fit an after market engine guard below and the metro ford guys told me something like this, i am not sure if thats right, but i got ford authorized engine guard and ended up paying ~8k. You may need to check from their customer care if that theory is true or not. All the best.
Old 18th August 2016, 12:18   #10534
hemant.kamat's Avatar
Thanked: 150 Times
I'm interested in fitting a similar one, but cannot find a metal guard anywhere in India. The ones on AliExpress work out to 12K+ with shipping, not sure how much excise duty will be levied.
Could you send me the design drawing of the aluminum guard that you fabricated; I could try getting a local workshop to fabricate one for me.
Thanks!
hemant.kamat is offline   Reply With Quote
Old 18th August 2016, 13:15   #10535
sunilg33's Avatar
Thanked: 130 Times
I service the vehicle regularly Metro ford and the Service Advisers feel it's better than the company provided one. Advantage with the metal one is after a hit it only deforms whereas the ABS plastic guard might crack.
Thanks!
I am not sure about the fit of the Aliexpress one as the Ecosport in china is slightly bigger than the one here. I have put the details of the costs and dimensions in this post. PM me if you need more assistance
http://www.team-bhp.com/forum/test-d...ml#post3484931 (Ford EcoSport TDCi - The little Beast)
sunilg33 is offline   (1) Thanks Reply With Quote
Old 18th August 2016, 14:44   #10536
ACM
ACM's Avatar
Thanked: 2,881 Times
Ford does adopt a design where in the engine drops to the ground in the event of a major accident and this is supposed to prevent the engine getting into the passenger compartment.
This is a reason to avoid putting a metal engine guard below the engine. Ford does have a PVC one as accessory and only that one must be used.
For protection from stones this is sufficient. It will not protect from damage due to hitting a major object from below but one does have higher ground clearance to start with compared to other vehicles.
Not all companies adopt this "engine dropping" technique towards crash protection so other companies may infact have a metal under body protection.
Each company many adopt a different method to arrive at good NCAP scores. EcoSport score is acceptable.
I believe even the Fiesta Classic (previous gen Fiesta) adopted a similar design. Customers would then say that they can see the bottom from the engine bay and there is no protection and this logic was presented to them.
ACM is offline   (7) Thanks Reply With Quote
Old 18th August 2016, 16:04   #10537
johnruben's Avatar
Thanked: 74 Times
@ACM, Thanks for clarifying this, even i was told the same and thats the reason i avoided after market one. when doing under chassis protection from 3M i checked the quality of the engine guard put by ford and it did not look like any cheap plastic, it was thick with proper mountings and looked it could handle the stones very well.
Old 18th August 2016, 17:08   #10538
Uprasenjit's Avatar
Thanked: 681 Times
The default engine guard isnt made of plastic, its some kind of hard paper board or similar. Please correct me if I am wrong. The one Fords sells as an accessory is made of ABS plastic.
The paper board one can stand against stone chips but not stones on high speed. It is very important that a car like EcoSport which is called Urban-Suv has a proper sump guard at least. I have also heard about the Engine design part, but then how would you save the sump from sudden craters ? The default engine cover isnt enough.
Uprasenjit is offline   Reply With Quote
Old 18th August 2016, 17:56   #10539
johnruben's Avatar
Thanked: 74 Times
Yes you are right, the stock one comes with foam like material but not that strong, the one i am talking about is a additional accessory which costs approx 8k which is made of thick ABS plastic.
ford must have given along with the vehicle at least in top end model.
johnruben is offline   (1) Thanks Reply With Quote
Old 18th August 2016, 20:24   #10540
Has anyone attempted to fit an oil catch can to the 1.5 tdci? How beneficial would it be for the engine, if it all? Here's a link for an oil catch can fitment for the 1.6 tdci : http://www.fordownersclub.com/forums...ocus-mk2-mk25/
Seems like an easy job.
An alternative idea is to (with the same purpose of not letting oil to be ingested by the air intake) block the breather on the intake side, and fit a "total loss" breather (on a long hose) that exhausts under the side of the car (so no burnt gasses/ oil droplets etc enter the engine air intake)
Any comments/suggestions from experts?
Taha Mir is offline   Reply With Quote
Old 19th August 2016, 10:25   #10541
wilful's Avatar
Thanked: 874 Times
Got my 2nd year service done yesterday (at almost 19000 kms).
It cost me Rs.4173/-
Engine oil was changed as also air filter. Attaching a copy of the detailed bill.
I have two grumbles against Malayalam Ford - they again inflicted 2 small stains (oil methinks) on the front seat - last year it was the rear seat headrest. This despite my words of caution when I gave it for service.
Secondly, I had to fork out cash because their credit card machine was kaput. Come on Mal Ford! One machine for such a large service centre - and that not working?
Luckily I had cash with me else I would have to hoof it to the nearest ATM some distance away from the workshop.
Ford EcoSport : Official Review-new-doc-35_1.jpg
Ford EcoSport : Official Review-new-doc-35_2.jpg
wilful is offline   (4) Thanks Reply With Quote
Old 19th August 2016, 12:17   #10542
arunphilip's Avatar
Thanked: 4,814 Times
Don't they put a plastic cover on the driver seat to prevent this?
I'm not sure when this soiling would have happened, but I assume it would have been during the washing and not servicing (no other reason for them to go near the rear seats). This is why I always ask them NOT to wash my car when it goes for servicing, but prefer getting it washed at my regular car wash. Not only does this avoid such hassles, but I find that they often have fewer wash bays compared to service bays, so performing a car wash inevitably adds an hour or more to the service time. Plus, the lesser others drive my vehicle, the better!
I hope you filled out the feedback form only after this, and captured this in the feedback?
Also, yours is the AT - did they tell you what they did and why they did the following items, under warranty? Were there any complaints you reported?
  • Reprogram PCM/TCM and perform Clutch Adaptive Learn Procedure
  • Diagnose and replace Transmission Control Module
Name:  New Doc 35_2.jpg
The Transmission Control Module (TCM) is an important (and expensive - costs over 700 US dollars) component of your EcoSport's automatic transmission. Its often the source of problems with the gearbox too, and Ford have been generally good in replacing it free of charge when they find it has defects. I'm curious what has triggered such a replacement.
arunphilip is offline   (2) Thanks Reply With Quote
Old 19th August 2016, 13:40   #10543
wilful's Avatar
Thanked: 874 Times
Attachment 1543655
Thanks for all those points raised by you.
Yes - I guess they do put those plastic covers (at least I've seen them do it in Honda) - but here I had to leave the car and rush to office. Maybe this one slipped a bit?
I have raised both the issues - this one and the credit card fiasco, twice - in the feedback form at the service centre and the feedback call that I received today.
Actually - re the transmission module and PCM - I didn't not pay much attention (to be honest) - assumed it is to be done for the 20 K service. There used to be an occasional judder when quick shifts took place at slow speeds and sudden stop starts.
Now that you have pointed out the importance of this, I shall give them a call and find out. Thank you again! The funny thing is the service adviser Jinu said everything is fine and the report mentions green on all issues.
wilful is offline   Reply With Quote
Old 19th August 2016, 16:11   #10544
libranof1987's Avatar
Thanked: 4,045 Times
Attachment 1543655
Another BHPian, Murugan, got his replaced under warranty at 26k kms.
http://www.team-bhp.com/forum/techni...ml#post4007133 (Ford EcoSport 1.5L AT: Transmission Control Module replaced under warranty at 26,162 km)
This is a worrying trend; more so, how quietly it was done by Ford.
Please check with your SA why it was done, and why so casually.
libranof1987 is offline   (3) Thanks Reply With Quote
Old 19th August 2016, 18:48   #10545
wilful's Avatar
Thanked: 874 Times
I called the service adviser and put this question to him. He says nothing has been replaced. They've just done the software update. Just that it's been worded wrongly. I hope so.
wilful is offline   (2) Thanks Reply With Quote
Car for Parents: Hyundai Verna vs Ford EcoSport vs Ford Classic vs Maruti Ertiga iTNerd What Car? 60 12th October 2014 07:53
Ford EcoSport DIESEL Review GTO The Indian Car Scene 0 31st May 2013 11:51
