Old 20th April 2015, 14:32   #1681
Santoshbhat's Avatar
Thanked: 3,889 Times
Default Re: Skoda Octavia : Official Review
Originally Posted by Hawkeye269 View Post
Thanks, Kapil, do you have any pics you can share of the P7 225s on the Octavia? Also, what is the approximate price differential between the 215s and the 225s?
Originally Posted by kapiljolly79 View Post
But that doesnt really change much here as you have a powerful car with all digital readouts.
What will matter is the stance. The 215 look ok and are a sufficient massage to the eyes but the 225 totally satisfy both looks and broadness of the vehicle. Price difference is huge but worth the extra. 225 is my choice and in use by me too. practically no drop in fuel average but great grip.
225/55/16 is the wrong upsize of 205/55/16 in my opinion. You are increasing the sidewall height by almost 11mm. This translates to a 22mm increase in ground clearance. That's sure to ruin the ride and handling balance. I know there are few that bat for plus sizing wheels in this manner, but I would stick to the max 2% variance rule.
The car gives out digital readouts , yes, but then you will get the wrong readouts if your tire size is off!!
225/50/16 is the ideal upsize for 205/55/16. But then this size is hard to source and you have very limited options. You can search around for Michelin Pilot Sport 3 or Yoko Advan Sport.
Santoshbhat is online now   (1) Thanks Reply With Quote
Old 20th April 2015, 15:52   #1682
Behemoth's Avatar
Thanked: 1,691 Times
Hi Santosh,
Just a small correction to what you have said - an 11mm increase in the Sidewall height only results in 11mm increase in Ground clearance and not 22mm. This is because the tyre radius practically determines the distance of the hub from the ground and not the tyre diameter. That said, even 11mm is too much for upsizing the tyre and the recommended norm is only 2%.
Behemoth
Behemoth is online now   (3) Thanks Reply With Quote
Old 20th April 2015, 22:20   #1683
kapiljolly79's Avatar
Thanked: 65 Times
Ok. So after reading here, and also trying the Tyre application on my phone and speaking to Peter Chacko, I realised 225/55 was indeed a wrong choice. So back to the tyre shop and switched over to Yokohama Decibel 215/55 16. I must say, yes, the ride quality is much better and why didnt I go for the Pirelli? Well, a sound advice from a friend running them on his 3 series. So here are new pics and the stance is good because of that extra lip this tyre has that gives its sidewall a good look on the rims.
Skoda Octavia : Official Review-20150420_185614.jpg
Skoda Octavia : Official Review-20150420_185603.jpg
kapiljolly79 is offline   (1) Thanks Reply With Quote
Old 21st April 2015, 08:15   #1684
Haren's Avatar
Thanked: 36 Times
If you increase the tyre radius, then wouldn't the car's speedometer and odometer show wrong (lower) readings? Do you have ways to correct this in the car computer?
Haren is offline   Reply With Quote
Old 21st April 2015, 08:36   #1685
Gannu_1's Avatar
Thanked: 10,516 Times
If the actual speed can be determined using a GPS, the indicated speed on the speedo can be adjusted through the MFD by opting for the winter tires selection menu which can reduce or increase the speedo reading by +-5 kmph (or 10 kmph don't remember correctly).
Gannu_1 is offline   Reply With Quote
Old 22nd April 2015, 11:01   #1686
adi_petrolhead's Avatar
Thanked: 1,069 Times
Has anyone got the K&N filter for the Octavia yet? If yes, is it worth the upgrade?
Secondly, I am experiencing quite a lot of noise when the AC is on, under hard acceleration. I am sure it is nothing related to the air filter but is everyone else also experiencing increased noise when AC is on? It is like a whining noise, i assume the AC filter needs cleaning may be.
adi_petrolhead is offline   Reply With Quote
Old 22nd April 2015, 11:24   #1687
Gannu_1's Avatar
If it's a whistling sound from the AC vents (check by turning off the blower and turning it on), it could be the air leaking from the cabin filter's housing. It should be located behind the glovebox. Try opening it and replacing it back.
Old 22nd April 2015, 11:34   #1688
amarjain's Avatar
I checked with a friend who is the distributor of K&N filters here in Mumbai - he says that the filter for the current Octavia has not come yet - will inform when it does.
I also wrote an email to Skoda India to clarify whether replacing the stock filter will affect my warranty - no response from them. I also spoke to Autobahn - they say that it will void the warranty - although I can't understand why.
What do you think?
amarjain is offline   Reply With Quote
Old 22nd April 2015, 12:07   #1689
Gannu_1's Avatar
The K&N filter that goes inside the stock air filter housing is coated with a special oil and it keeps coating the sensor element of the MAF sensor with this oil over time and requires frequent cleaning.
The CAI is a different story however. Requires new plumbing as well and the filter to be located close to the grill for fresh air suction as much as possible.
Old 24th April 2015, 15:17   #1690
Vid6639's Avatar
Thanked: 21,061 Times
Not sure how true this is but the Skoda dealer in Bangalore (Tafe), just informed me that the Zeal edition has now been stopped.
They don't have any Octavia Zeal editions and maybe able to get a Superb Zeal edition available in stock.
They were limited edition and are now no longer available.
Vid6639 is offline   (1) Thanks Reply With Quote
Old 28th April 2015, 03:59   #1691
Thanked: 1,066 Times
Octavia MY16 price list and feature list has been published here in the EU. The Elegance spec now features 6.5" Bolero audio system. Hopefully, the India-spec will be upgraded soon.
StarrySky is offline   Reply With Quote
Old 28th April 2015, 06:17   #1692
Thanked: 37 Times
Haha one can only hope, my friend.
Skoda India likes to sell only the most basic of kits. Black and white MID, no KESSY, no paddles, no reverse camera, no navigation... We might be paying among the highest of prices, but as far as features are concerned, we get the rawest deal.
Even interior color is pre-decided for India. Zeal edition looked beautiful, but it seems to be a one-off. I hope they learn a bit from Honda and offer a few more gizmos for the next model year.
A top end Honda City or Hyundai Verna offer more features than the Octavia. :(
I'm visiting the US right now, and I cannot stop drooling at even the most common of cars here. They have so many options, at such low prices....
sleepyk is offline   Reply With Quote
Old 28th April 2015, 15:23   #1693
Thanked: 65 Times
Fresh from Prague: Installed the faux exhaust imitations and the TSI badge on the rear.
Red Stitching 3 spoke DSG paddle shift steering. Droolmaal and worth every bit. Vagtune india charges 3 times the price of what its for shipped from Prague.
Skoda Octavia : Official Review-20150428_130659.jpg
Skoda Octavia : Official Review-20150428_130722.jpg
Skoda Octavia : Official Review-20150428_133312.jpg
kapiljolly79 is offline   (9) Thanks Reply With Quote
Old 28th April 2015, 16:18   #1694
Crazy_Bean's Avatar
Thanked: 198 Times
Good stuff. Could you mind sharing the link from where you bought this. Also, Did you get it to work your self. I know removing the airbag is nerve wrecking. Good show!
Crazy_Bean is offline   Reply With Quote
Old 28th April 2015, 16:22   #1695
Thanked: 65 Times
I would hands down recommend the supplier. Andrey is his name and www.skodadop.com is where you can get this stuff. Best part is all the products I received, except for the faux immitation exhaust which are manufactured by Milotec, are genuine Skoda parts. I got the TSI badge, the Steering and a Skoda Octavia Scale model, all genuine Skoda stuff. 100% great site to shop from and excellent customer service.
Before this I tried getting the same stuff from car equipment website but horrible service and they dont have stock of what they show on their website.
Installed the ex myself. Childs play. Will go to Satnam auto later when the skoda guy comes to get the wheel installed as I have conversed with Skoda and they say as long as its genuine, no lapse of warranty. So even though its a plug and play wheel, will have it installed at their workshop in the presence of a Skoda Tech.
kapiljolly79 is offline   Reply With Quote
2014 Skoda Rapid 1.5L DSG : Official Review .anshuman Official New Car Reviews 226 9th June 2018 15:01
Driven: 2nd-gen Skoda Superb (2014) moralfibre Test-Drives & Initial Ownership Reports 85 17th November 2017 14:57
Beauty of the Beast Skoda Octavia RS - 57000 km review ajmat Long-Term Ownership Reviews 203 4th February 2017 20:31
From a Skoda Octavia to a Skoda Rapid RedRapid Test-Drives & Initial Ownership Reports 28 17th March 2015 11:25
